I needed this and came on this post. I adapted guide Crossroads to get it working. Sensor data is converted to uint8, send, and reconstructed. In this case, I send joystick values to a remote car.
Transmit code:
#include <VirtualWire.h>
const int transmit_pin = 12;
// Analog pins Joystick
const int joyH = 0; //horizontaal - X
const int joyV = 1; //vertikaal - Y
const int joyK = 2; //knop - K
bool test = false;
// Waarden opslaan
unsigned int Hval, Vval, Kval;
uint8_t valArray[6];
unsigned int gebruiker = 2000 * 0;
// Begin Seriele monitor
if (test) Serial.begin(9600);
vw_set_tx_pin(transmit_pin);
vw_setup(2000); // Bits per sec
void loop(){
// value between 0 en 1023
Hval = analogRead(joyH);
Vval = analogRead(joyV);
Kval = analogRead(joyK);
Kval = map(Kval, 0, 1023, 0, 1); //button joystick is 0 or 1
//convert reads: uint16 to 2 tomes uint8 :
valArray[0] = (Hval + gebruiker) >> 8;
valArray[1] = (Hval + gebruiker) % 256;
valArray[2] = (Vval + gebruiker) >> 8;
valArray[3] = (Vval + gebruiker) % 256;
valArray[4] = (Kval + gebruiker) >> 8;
valArray[5] = (Kval + gebruiker) % 256;
// send bytes. Here 6 bytes, that is 6 uint8 or 3 uint16
vw_send((uint8_t *)valArray, 6);
// wait for send to end
vw_wait_tx();
// Don't send too much the joystick values
delay(200);
if (test) {
toonWaarden();
delay(50);
void toonWaarden() {
Serial.print (" ");
Serial.print (Hval);
Serial.print (" -- ");
Serial.print (Vval);
Serial.print (Kval);
Serial.print (valArray[0]);
Serial.print (valArray[1]);
Serial.print (valArray[2]);
Serial.print (valArray[3]);
Serial.print (valArray[4]);
Serial.print (valArray[5]);
Serial.println (" -- ");
The receiver code then recreates the integer values from the uint8. Note, the variable gebruiker is too allow two cars to drive, one sends integers in the range 0 to 2000, the other from 2000 to 4000. In case of collision, both receive noise ...
Robot Auto - Remote car receives joystick values from MX-FS-03V transmitter to the XY-MK-5V receiver
// download library van http://www.pjrc.com/teensy/td_libs_VirtualWire.html
const int receive_pin = 11;
bool test = true;
// save values
// motor connections of the motor shield ar
#define motorrechtsPWM 3 //B-IB
#define motorrechtsDir 2 //B-IA
#define motorlinksPWM 5 //A-IB
#define motorlinksDir 4 //A-IA
//kalibratie variabelen, niet wijzigen als auto recht rijdt!
#define calib_speed_corrR 0 //als auto rechtdoor afwijkt, doe een correctie
#define calib_speed_corrL 0 //als auto rechtdoor afwijkt, doe een correctie
int calib_max_speed, calib_no_speed;
//internal variabeles
int right_speed;
int max_speed;
int min_speed;
int left_speed;
vw_set_rx_pin(receive_pin);
vw_setup(2000);
// Start the receiver PLL running
vw_rx_start();
calib_max_speed = 255; //maximum speed forward motors
calib_no_speed = 100; //min speed to motors that makes them stand still
max_speed = calib_max_speed;
min_speed = calib_no_speed;
pinMode(motorlinksPWM, OUTPUT);
pinMode(motorlinksDir, OUTPUT);
pinMode(motorrechtsPWM, OUTPUT);
pinMode(motorrechtsDir, OUTPUT);
//startwaarden joystick
Hval = 0;
Vval = 0;
Kval = 1;
void loop(){
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
uint16_t tmp_Hval, tmp_Vval, tmp_Kval;
// non blocking, read values when processed
if (vw_get_message(buf, &buflen)) { // Non-blocking
// Message with a good checksum received, print it.
if (test) {
Serial.print("Got: ");
for (int i = 0; i < buflen; i++) {
Serial.print(buf[i], HEX);
Serial.print(' ');
//uint8 received, convert to normal uint16:
if (buflen == 6) {
tmp_Hval = buf[0]; tmp_Hval = (tmp_Hval<<8) + buf[1];
tmp_Vval = buf[2]; tmp_Vval = (tmp_Vval<<8) + buf[3];
tmp_Kval = buf[4]; tmp_Kval = (tmp_Kval<<8) + buf[5];
// discrimate between cars using the gebruiker varible. Sensor values are 0 to 1024
if (tmp_Hval >= gebruiker && tmp_Hval < gebruiker+1025 &&
tmp_Vval >= gebruiker && tmp_Vval < gebruiker+1025 &&
tmp_Kval >= gebruiker && tmp_Kval < gebruiker+1025 ) {
// waarden van de juiste gebruiker !
Hval = tmp_Hval-gebruiker;
Vval = tmp_Vval-gebruiker;
Kval = tmp_Kval-gebruiker; // zal 0 of 1 zijn
if (test) {
Serial.print("Computed received values: ");
toonWaarden();
//now convert to a speed between -255 en 255
Hval = map(Hval, 0, 1023, -calib_max_speed, calib_max_speed);
Vval = map(Vval, 0, 1023, -calib_max_speed, calib_max_speed);
if (test) {
Serial.print("Speed values: ");
toonWaarden();
if (test) {
Serial.print("Problem, Converted to: ");
Serial.print (" ");
Serial.print (tmp_Hval);
Serial.print (tmp_Vval);
Serial.print (tmp_Kval);
Serial.print ((unsigned int) buf[0]);
Serial.print ((unsigned int) buf[1]);
Serial.print ((unsigned int) buf[4]);
Serial.print ((unsigned int) buf[5]);
Serial.println (" --");
if (test) {Serial.println("Error, buffer of wrong length received!");}
motor_drive(Vval+Hval, Vval-Hval);
Serial.print (" ");
void motor_drive(int right_speed, int left_speed){
// Motors bewegen met de gegeven snelheid.
// snelheid is een waarde tussen -255 en 255!
int sgvr = 1;
if (right_speed != 0) {sgvr = abs(right_speed)/right_speed;}
int sgvl = 1;
if (left_speed != 0) {sgvl = abs(left_speed)/left_speed;}
int vr = abs(right_speed) + calib_speed_corrR;
int vl = abs(left_speed) + calib_speed_corrL;
if (vr > calib_max_speed) {vr = calib_max_speed;}
else if (vr<0) {vr = 0;}
vr = vr * sgvr;
if (vl > calib_max_speed) {vl = calib_max_speed;}
else if (vl<0) {vl = 0;}
vl = vl * sgvl;
if (right_speed>=0){
digitalWrite(motorrechtsDir, LOW); //forward
analogWrite(motorrechtsPWM, vr);
digitalWrite(motorrechtsDir, HIGH); //backward
analogWrite(motorrechtsPWM, 255+vr);
if (left_speed>=0){
digitalWrite(motorlinksDir, LOW); //forward
analogWrite(motorlinksPWM, vl);
digitalWrite(motorlinksDir, HIGH); //backward
analogWrite(motorlinksPWM, 255+vl);
