RF communication between multiple devices
Hi. I'm concocting a game-based project which will involve up to 8 individual Arduino Nanos, placed within a few feet of each other on a table, all communicating with each other wirelessly. They will need to pass fairly basic information back and forth, perhaps once or twice a second, changing the state of LEDs based on user input on each of the devices. Not all 8 units would necessarily be used at the same time - anywhere between 2 and 8 would be in use at a time.
I've just purchased a couple of cheap RF transmitters and receivers so I can start experimenting.
My question is twofold:
  1. Will these transmitters and receivers allow multi-way communication between a number of devices?
  2. Is it realistic to do this without some kind of 'base station' centrally controlling the devices?
All advice and suggestions very gratefully received!
  1. Unfortunately, no.
    You need something along the lines of Xbee or:
    http://www.kickstarter.com/projects/545073874/radioblock-simple-radio-for-arduino-or-any-embedde
  2. Maybe:
    Arduino Yún as a possible Mesh Extender Platform | Arduino Blog
Resources:
Ray
Those little transmitters and receivers are great fun, and you should try the VirtualWire library.
However, they operate on only one channel and will interfere with each other. So, to have multiple communications pathways you must pass short messages that in addition to any data, identify the transmitter and intended receiver. Each receiver has to be programmed to respond to only messages intended for it. The messages also require some sort of error-detecting capability (already built in to VirtualWire) in case of message collisions and other interference.
Other alternatives include inexpensive, short range radios that can operate on hundreds of different channels, for example the Pololu Wixels Pololu - Wixel Pair (Fully Assembled) + USB Cable I have heard of some attempts at network communications using the RFM12B, but have no experience with them. http://panther.pinkboard.com.au/?p=89
Edit: "Radioblocks" certainly looked and sounded interesting. A successful Kickstarter campaign raised a fair bit of money http://www.kickstarter.com/projects/545073874/radioblock-simple-radio-for-arduino-or-any-embedde but there seems to be no place to buy them. I wonder what happened.
Thanks, folks - that's incredibly helpful.
Radioblocks do look perfect, but I also can't find anywhere to buy - the links to the shop are dead.
Cost is an important factor for me, which is why the devices I've bought are so intriguing. I could be building each unit for £10-15 – perhaps considerably less if I built my own controller. That prohibits things like the Xbee.
It sounds like I could do this with these devices with a central base station. That base station could poll each of the devices in turn, await a response with any updates on user input, then send back instructions to change the state of the LEDs. I guess the speed at which this could happen with eight slave devices would be the determining factor - any more than a second per update would make it too clunky.
You could use these radios:
RFM22B-S2 SMD Wireless Transceiver - 434MHz - WRL-10153 - SparkFun Electronics or the more expensive breakout board
SparkFun RF Transceiver Breakout - RFM22B-S2 (434 MHz) - WRL-10154 - SparkFun Electronics
and the excellent library:
http://www.airspayce.com/mikem/arduino/RF22/
This library allows everything from unaddressed, unreliable messages to multi hop delivery with automatic route discovery and rediscovery (meshing).
I think Mike also has a library for the lower powered and less demanding RFM23.
More options - excellent, thanks.
I'm going to test out the extremely cheap eBay approach in a few weeks time, with 2-3 slave devices and one master, to see how practical it might be as an approach. Will report back...
With the Ebay units you can also use Mikes Virtual Wire library:
