RF communication Real Distances measured by users and avice
Hey. I need to communicate between 2 arduinos , ground and air.
I've been researching for some time and i guess RF is what will suit me, and everywhere i go, i see diferent claims of distances that a pair of modules does. I know it depends on a lot of factors, frequency , objects , power , antenas....
I would be happy with 1km , very happy with 2km and so on. I also have seen that zigbee/xbee are a good deal , but buying 2 modules + 2 shields may got a bit expensive.
What could you advise me , and if you have tested , what range can it get ?
RFM69, over 1Km line of sight using the high power version and small whip or 1/4 wire antenna.
If you have line of sight you can easily double that with 7dBi directional yagi antennas, but those are quite big and you need to have it aimed to the other node all the time.
Some other projects/links reporting experience with the same radio:
https://plus.google.com/113289611175907823715/posts/NLMpdDVLEeL
The range you get depends on many things, but mostly on antennas and obstructions.
With excellent antennas and completely open line of site, it is easy to get many km range with very little transmit power.
In situations with lots of obstructions, it may be impossible to get even 10 meters range, using the same equipment.
Tell us about your situation.
The place where the i intend to comunicate doesnt have tall buildings or anything like that, and as i mencioned , its ground - air most of the times it wont have anything blocking line of sight.
If i want to go a litle more distant , the objects that i will get are trees and a litle elevation "mountains".
Well, mountains will certainly play hell with "line of sight" unless you can see through mountains.
Radio waves can't, so it doesn't really matter whether you can, or not.
This Youtube video shows tests with an nRF24 transceiver IIRC they had communication over a range of 1km.
I reckon if you are just using wireless equipment that does not require a licence you will have to do some experimentation to find what range you can rely on.
If the wireless system will be controlling a flying machine and if the machine will crash without a reliable signal I suspect 1km would be stretching things. It would be very different if the machine can fly autonomously and can return to base if it loses the signal. Or if the wireless was being used for something unconnected with the control system - for example to relay data.
...R
In the US, any unmanned aerial vehicle must be visible to the operator at all times. Personally, I couldn't see anything smaller than a 747 at 2km. Using an Arduino in the process of flying a 747 somehow escapes me.
I hope that flying an aircraft using an Arduino is not what OP plans.
PaulS:
I dont live in the US but the law is quite the same.
I am obviously concerned about security. First i will make the tests range on the ground, then calculate distance i can fly at a certain altitude ( phythagoras ). If arduino on air senses singal loss, it will return to space within range. I will not fly over crouded ares, the place have almost 0 people and houses.
Robin2:
...R
This guy as a video where he tries to go 10km with those nrf , of course perfect conditions , and as said in the coments , he has the receiver attach to the roof of the car and the car body acts like a plate i guess.
With the transmitter in the air? Bizarre.
PaulS:
Not bizarre. Just watch the video. The Tx is also on the ground at the other end of a long straight road.
...R
Robin2:
...R
He also attach an antena to the Tx , and put it about 2 meters from the ground , not a bad idea.
Maybe i will first try those nrf24l01 pa lna , let's see how it goes.
sandorrrh:
There are two types of nRF24L01+. The low power ones have the antenna as part of the PCB. The high power ones have the external antenna.
...R
Robin2:
...R
that's what i said. The high power ones are labeled as pa+lna+sma output.
As soon as i make the tests i will put here the results.
sandorrrh:
that's what i said.
Sorry, I misunderstood. When you said "He also attach an antena to the Tx" I was concerned that you might have thought that it was possible to add an antenna to the low power version.
Looking forward to reading your results.
...R
PS. I suspect some of the regular Radio Control systems for model planes use nRF24 transceivers or the similar (but not interchangeable) Cypress equivalent.
Robin2:
...R
What do you mean by interchangeable ?
sandorrrh:
To the best of my knowledge a Nordic transceiver cannot talk to a Cypress transceiver (and vice versa).
...R
