hello to all
I write because I have a problem with two 433 MHz RF modules. I would like to communicate two arduino (UNO) and (MEGA).
I used the library virtualwire and sketches present example. everything communicates, but on the receiving arduino only see the bytes but not the text. I enclose photos
TRNSMITTER
#include <VirtualWire.h>
const int led_pin = 11;
const int transmit_pin = 8;
const int receive_pin = 52;
const int transmit_en_pin = 3;
// Initialise the IO and ISR
vw_set_tx_pin(transmit_pin);
vw_set_rx_pin(receive_pin);
vw_set_ptt_pin(transmit_en_pin);
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
pinMode(led_pin, OUTPUT);
byte count = 1;
char msg[7] = {'h','e','l','l','o',' ','#'};
msg[6] = count;
digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
vw_send((uint8_t *)msg, 7);
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(led_pin, LOW);
count = count + 1;
RECEIVER
const int led_pin = 13;
const int transmit_pin = 12;
Serial.begin(9600); // Debugging only
Serial.println("setup");
vw_rx_start(); // Start the receiver PLL running
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(led_pin, HIGH); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
Serial.print(buf[i], HEX);
Serial.print(' ');
