Hi all,
I am trying to control 2 dc motors attached to a Sabertooth 2X25 motor driver using a custom RF joystick controller.
Communication between joystick and Sabertooth is done using two NRF29L01 modules (one for the controller and one for the sabertooth). While I am not having trouble for controlling one motor, when it comes to control both motors, then I find it quite difficult to make the code be working.
On sabertooth the DIP switches are set as follows: 1,3,5,6 are set to ON.
The connections are as follows:
motor1 connected to M1A, M1B on sabertooth
motor2 connected to M2A,M2B on sabertooth
LiPo battery 11.1V on B+, B- on sabertooth
Sabertooth 0V to Ground bus and from there to arduino GND.
Sabertooth S1 to arduino pin 7.
Here is the code for the transmitter (JOYSTICK_TRANSMITTER.ino):
#include <nRF24L01.h>
#include <printf.h>
#include <RF24.h>
#include <RF24_config.h>
#define CE_PIN 9
#define CSN_PIN 10
RF24 radio(CE_PIN, CSN_PIN); // Create a Radio
const byte address[6] = "00001";
char xyData[32] = "";
String xAxis, yAxis;
radio.begin();
radio.openWritingPipe(address);
radio.setPALevel(RF24_PA_MIN);
radio.stopListening();
xAxis = analogRead(A1); // Read Joysticks X-axis
yAxis = analogRead(A0); // Read Joysticks Y-axis
// X value
xAxis.toCharArray(xyData, 5); // Put the String (X Value) into a character array
radio.write(&xyData, sizeof(xyData)); // Send the array data (X value) to the other NRF24L01 modile
// Y value
yAxis.toCharArray(xyData, 5);
delay(20);
And here is the code (working) for one motor: (receiver_simple_with_joystick_sabertooth.ino)
#include <printf.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
char receivedData[32] = "";
int xAxis, yAxis;
#include <SoftwareSerial.h>
#include <SabertoothSimplified.h>
SoftwareSerial SWSerial(NOT_A_PIN, 7); // RX on no pin (unused), TX on pin 11 (to S1).
SabertoothSimplified ST(SWSerial); // Use SWSerial as the serial port.
radio.begin();
radio.openReadingPipe(0, address);
radio.startListening();
SWSerial.begin(9600); // This is the baud rate you chose with the DIP switches.
if (radio.available()) {
radio.read(&receivedData, sizeof(receivedData)); // Read the data and put it into character array
xAxis = atoi(&receivedData[0]); // Convert the data from the character array (received X value) into integer
delay(10);
yAxis = atoi(&receivedData[0]);
delay(10);
// Y-axis used for left and right control
if (yAxis < 470) {
ST.motor(1,10);
Serial.println("Left pressed");
else if (yAxis > 550) {
ST.motor(1,-10);
Serial.println("Right pressed");
// If joystick stays in middle the motors are not moving
else {
Serial.println("nothing pressed");
ST.motor(1,0);
// X-axis used for upwards and backwards control
if (xAxis < 470) {
ST.motor(1,-10);
Serial.println("down pressed");
if (xAxis > 550) {
ST.motor(1,10);
Serial.println("up pressed");
I tried to do this for controlling the two motors but it is wrong:
#include <printf.h>
#include <RF24.h>
#define CE_PIN 9
#define CSN_PIN 10
int xAxis, yAxis;
int motorSpeedA = 0;
int motorSpeedB = 0;
SoftwareSerial SWSerial1(NOT_A_PIN, 7); // RX on no pin (unused), TX on pin 7 (to S1).
SoftwareSerial SWSerial2(NOT_A_PIN, 8); // RX on no pin (unused), TX on pin 8 (to S2).
SabertoothSimplified ST1(SWSerial1); // Use SWSerial as the serial port.
SabertoothSimplified ST2(SWSerial2); // Use SWSerial as the serial port.
radio.begin();
SWSerial1.begin(9600); // This is the baud rate you chose with the DIP switches.
SWSerial2.begin(9600); // This is the baud rate you chose with the DIP switches.
delay(10);
delay(10);
if (yAxis < 470) {
// Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(yAxis, 470, 0, 0, 10);
motorSpeedB = map(yAxis, 470, 0, 0, 10);
ST1.motor(1,motorSpeedA);
ST2.motor(2,motorSpeedB);
motorSpeedA = map(yAxis, 550, 1023, 0, -10);
motorSpeedB = map(yAxis, 550, 1023, 0, -10);
else {
motorSpeedA=0;
motorSpeedB=0;
ST2.motor(2,motorSpeedA);
if (xAxis < 470) {
ST1.motor(1,-10);
ST2.motor(2,-10);
if (xAxis > 550) {
ST1.motor(1,10);
ST2.motor(2,10);
Please, any ideas on how to make the code for two motors working?
The setup:
