RF controlled 220v quadbox
I'd like to start by saying hello. I got my first Arduino (Uno) 2 days ago, and I'm already loving the world of possibilities that just opened up for me.
Now onto the project.
I am looking to create a RF controlled quadbox extension cable to be controlled by another arduino. The idea is, once this is completed, I can use a second arduino with sensors and an RF transmitter to do the actual controlling, and wont need to open the quadbox to add a new sensor or bit of logic.
I have attached my current plan for wiring. (although I want to add a 220v AC to 5v DC converter directly into the box eventually)
My first question (although it's more of an electrical engineering question than an arduino question)
Do I need to split the neutral wires if the hot input is split? I tried to find a half hot wiring diagram to follow, but I see conflicting answers for this.
My second question is, does anyone have a recommendation for the relays or RF module? I only need the RF to go about 10ft and through some drywall.
I'm sure I'll have a bunch more in the next few days/weeks to come. Thanks in advance for any help, and I look forward to learning this amazing hobby with you all.
No. in your house, all of the neutrals are permanently connected together, as are the grounds. Only the hots* go through circuit breakers & switches.
I suggest you consider using some standard [u]home automation[/u] components. (That's a 120V version and only one of the outlets is switched.) They've solved all if the engineering & construction issues involved in fitting everything into an outlet box, the electrical isolation and wireless reception.
You can build or buy the controller/transmitter but there are lots of advantages to buying the outlets (and/or switches/dimmers, etc.). If you do build a transmitter/controller, you still may want to buy a basic transmitter for testing & troubleshooting purposes.
There are a few home automation protocols. X-10 has been around for 30 or 40 years and it works by sending an RF signal over the AC power lines. Insteon sends a wireless RF signal plus a signal over the wiring. (I have a combination X-10 and Insteon system, and I didn't build any of it myself.) And, there are a couple more standards/protocols.
...I have made a hard-wired controlled outlet-box (on the end of an "extension cord") for some Arduino lighting effects by essentially building solid state relays and cramming the circuitry into the box.
  • Here in the U.S., 120V has a hot, neutral, and ground, but 220V has two out-of-phase hot wires (plus neutral & ground) and both hot wires go through a ganged breaker.
