aisc
June 19, 2015, 7:31am
1
Do any of the core libraries support CC1101?
I am using IDE 1.5.7
Otherwise any other suggestion for a solid CC1101 library?
FWIW
Radiohead does not appear to support CC1101.
I hate the ELECHOUSE library just because they have their name strewn all over the code and there is absolutely no need for it.
Panstamp requires Arduino IDE 1.6 and from what I have read 1.6 can give a lot of grief, so not ready to update.
But I guess I am going to choose something...
Hi aisc
Are you running on Windows? If so, you could download 1.6.n in the zip file version, extract it to a folder and run it directly from there, rather than installing it over your current version.
Regards
Ray
aisc
June 19, 2015, 11:18am
3
@Hacksribble : if I did that, would it automatically use the same libraries, or would I need to create a new sketchbook/library structure?
FWIW it seems the panstamp library is quite buggy because of so many immature updates, so I would prefer to steer clear of it.
I found a few other libraries (e.g. StampTeddy), but there is no documentation
Is there any way to use the TI libraries with Arduino?
The naming structure is all different.
