Hi all
I am new to this lingo.
Here is my problem.
I have built 3 machines all different all cut and 1 drills wood.
The one with the 2 drills I have a problem.
When the drills aren’t running the program runs fine,
When the drills are running the machine stops every now and then at random places throughout the program.en it may run ok for 1/2 hour and sometimes 30 seconds
Wrapped the drills power cables in foil also foil wrapped the arduino housing box.
Pulling hair out now!!
Thanks in advance
Turn off and on again th
Hi, @jonhyams72
Welcome to the forum.
Please read the post at the start of any forum , entitled "How to use this Forum".
This will help with advice on how to present your code and problems.
Can you please post a copy of your code?
Can you please post a circuit diagram(s)?
Include power supplies.
What voltage/power are the motors?
How are you interfacing the Arduino to the motors?
What model Arduino are you using?
Can you post picture(s) of your project, so we can see your component layout?
I know its a lot mate, but we need to know about your project.
Tom...
You don’t think it could be just bad code?
