RF HC-12, run AT commands by arduino
I have a HC-12 radiofrequency module that I tested and configured using a TTL USB converter, I now connected the HC-12 to the Arduino and I am not able to execute the AT commands and see the return, when it returns it shows this:
"f⸮⸮⸮ ⸮⸮? F? ⸮⸮ "
The code I’m testing is this:
#include <SoftwareSerial.h>
// serial antena
SoftwareSerial HC12(2, 3); // RX, TX
  Serial.begin(19200);
  HC12.begin(19200);
  while (HC12.available()) {        // If HC-12 has data
    Serial.write(HC12.read());      // Send the data to Serial monitor
  while (Serial.available()) {      // If Serial monitor has data
    HC12.write(Serial.read());      // Send that data to HC-12
How can I see the return of the AT command?
(deleted)
spycatcher2k: Does the module run at 19200 BAUD? Have you set your serial monitor to 19200 BAUD?
Yes, I have set this value for both.
Try 9600 for the baud rate for the HC-12.
ieee488:
I connected the hc-12 again in the TTL and executed the AT-RX command to see the settings and it returns this:
OK + B19200
OK + RC010
OK + RP: + 20dBm
OK + FU3
I think it should be working on the Arduino in 19200, right?
But anyway I changed to 9600, change the code and the terminal to 9600 and it worked, but I’m still in doubt as to why it did not work with 19200.
