Rf interferance?
hi, im having an issue with a project im working on, its a display with esp32 to measure water usage in our camper. iv got the code working fine inside but when i connect it to the camper im getting timing issues and general hokey stuff. so the pump is a 12v pump on a battery with a momentary button to turn it on, the esp is powered from a 12v to 5v usb converter( supposedly regulated). the input pin for the esp comes from a simple voltage divider down to around 2.8v for input pin into the esp. there is also a 4.7k pulldown on this line because when the pump is on its a high input into the esp. i have a basic drawing. my question is, is the pump giving off some sort of interferance because the timing for the consumption calculations stops randomly even though i have the button pressed. if there is some sort of rf interferance what can i do to stop it. everything works as it should inside, so it has to be the pump doing something. this is the first time ive come across this and am unsure what to do. ive read that caps af various sizes can help. im really hoping someone nice can give me some insight.
This is not be needed if you are using a voltage divider. This makes me wonder if you understand what a voltage divider is, especially since it is not shown in your diagram.
Please draw a schematic showing all components and post that for the forum to check.
Is there a flyback diode connected to the pump motor terminals? Or a suppression capacitor?
The 4.7 k pulldown just pulling the pin low. Then when the pump button is pressed it takes it high. The voltage divider is a 10k on the 12v side and 3 k to the ground and the middle of the two is the lead that goes to the input for the esp to read. Im not sure if there is any caps on the motor as its just a commercial brought pump. I did however get a usb power bank and ran the esp from that and got much better results but thats not really practical.
Is it? How are you preventing it from affecting the voltage divider?
Isn't that 4K7 pulldown resistor, in fact, in parallel with the 3K resistor giving a combined resistance of about 1.8K?
So the output of your voltage divider, when the button is pressed will be about 1.8V. Is that enough to read HIGH?
Hi, @tezzatron81
Sorry but had to spread it out.
Can you please post your code?
Are you calculating water usage by measuring the ON time of the pump?
How long are your connecting wires?
Can you please post some images of your project?
So we can see your component layout.
Thanks.. Tom.. :smiley: :+1: :coffee: :australia:
I think an opto-isolator would be a good idea.
Put a 1K or 2K2 resistor in series with the opto's anode. Connect the opto's collector to your Arduino input pin and use INPUT_PULLUP mode.
The opto's cathode would connect to -12V and it's emitter to the -5V from the regulator/converter.
Hopefully this will give your Arduino some additional protection against electrical noise from the pump.
You are probably correct and i will take it out today and report back. I did not consider it affecting the voltage divider. Im relatively new as we all were at some point.
Ive posted a pic of the circut and ill get the pic if the pump shortly. This is the so called regulated converter. Yes im measuring the flow with time the pump is on. Its accurate enough. I has a hall effect flow sensor at the start and the pulse count varied so much it made it unreliable. Ill post the code as well but reluctant as some of the geniuses here seem to berate and pull it apart, and don’t actually help.
//#define ESP32_RTOS  // Uncomment this line if you want to use the code with freertos only on the ESP32
                    // Has to be done before including "OTA.h"
#include "OTA.h"
#include "credentials.h"
#include <Adafruit_GFX.h>
#include <Adafruit_ST7789.h> // Change to ST7789 library
#include <Fonts/FreeSansBold12pt7b.h>  // FreeSansBold, size 12pt
#include <SPI.h>
// adding webserial monitor  192.168.0.144/webserial
#include <Arduino.h>
#if defined(ESP8266)
  #include <ESP8266WiFi.h>
  #include <ESPAsyncTCP.h>
#elif defined(ESP32)
  #include <WiFi.h>
  #include <AsyncTCP.h>
#endif
#include <ESPAsyncWebServer.h>
#include <WebSerialLite.h>
#include <ESP32TimerInterrupt.h>
ESP32Timer ITimer(0);  // Using Timer 0
//////----------------------------define pins to turn on or off below-------------------------------------
AsyncWebServer server(80);
const char* ssid = "TelstraA857CE"; // Your WiFi SSID
const char* password = "fuateu9u4t"; // Your WiFi Password
unsigned long lastPrintTime = 0; // Tracks the last time data was printed
const unsigned long printInterval = 60000; // Interval in milliseconds (1 second)
// TFT Pins
#define TFT_CS    38
#define TFT_RST   33
#define TFT_DC    34
#define TFT_MOSI  35
#define TFT_SCLK  36
#define TFT_BACKLIGHT 37  // Define backlight pin
Adafruit_ST7789 tft = Adafruit_ST7789(TFT_CS, TFT_DC, TFT_MOSI, TFT_SCLK, TFT_RST);
// Button Pins
#define BUTTON_ADD_litre 9
#define BUTTON_CYCLE_DISPLAY 11
#define BUTTON_RESET 7
//#define FLOW_BUTTON 5
// Debounce settings
unsigned long debounceDelay = 100; // Debounce time in milliseconds
unsigned long lastCycleDisplayPress = 0;
unsigned long lastDebounceTime = 0;
int lastButtonState = LOW;        // Last stable state
int currentButtonState = LOW;     // Current stable state
volatile bool isFlowing = false;
volatile unsigned long flowDuration = 0; // Flow duration in milliseconds
const int FLOW_BUTTON = 5; // Example button pin for flow button (adjust accordingly)
// Inactivity timer
unsigned long lastInputTime = 0;
unsigned long inactivityTimeout = 20000; // 15 seconds of inactivity
// Long press settings
const unsigned long shortLongPressDuration = 1000; // 1 second
const unsigned long fullLongPressDuration = 3000; // 3 seconds
unsigned long addlitrePressStart = 0;
unsigned long resetPressStart = 0;
bool addlitreButtonHeld = false;
bool resetButtonHeld = false;
unsigned long flowStart = 0;
unsigned long flowStop = 0;
//unsigned long flowDuration = 0;
//bool isFlowing = false;
float timePerlitre = 18.0; // Time in seconds for 1 litre change as needed ////////////////////////////////////////////////////
float flowRateLpm = 0.0;  // Global variable to store flow rate in L/min
bool IRAM_ATTR updateFlowTime(void* arg) {
    if (isFlowing) {
        flowDuration++;  // Increment the flow timer every millisecond
    return true;  // Return true to keep the timer running
// Tank properties
#define TANK_CAPACITY 80.0 // Maximum capacity
float litresRemaining = 80.0; // Initial litres remaining
float litresUsed = 0.0;       // Total litres used
// Display mode
int displayMode = 3;
// Thermistor Constants
#define THERMISTOR_PIN 2 // GPIO2 for thermistor
const float R_FIXED = 100000.0; // 100k resistor value
const float BETA = 3950.0; // Beta value for the thermistor
const float T0 = 298.15; // Reference temperature (25°C in Kelvin)
const float R0 = 100000.0; // Thermistor resistance at 25°C
float tempv = 1.700; // changing the temp voltage
float lastTemperature = -999.0; // Stores the last temperature reading
unsigned long lastTempRead = 0; // Timestamp for the last temperature reading
const unsigned long tempReadInterval = 5000; // Read temperature every 1 second
void handleWebSerialMessage(uint8_t *data, size_t len) {
    String message = "";
    for (size_t i = 0; i < len; i++) {
        message += (char)data[i];
    // Debugging: Print the received message to WebSerial
    WebSerial.println("Received message: " + message);
    if (message.startsWith("timeperlitre ")) { // Command to update timePerlitre
        float newTime = message.substring(13).toFloat(); // Start after "timeperlitre "
        if (newTime > 0) {
            timePerlitre = newTime;
            WebSerial.println("timePerlitre updated to: " + String(timePerlitre));
            WebSerial.println("Invalid time value. Please provide a positive number.");
    } else if (message.startsWith("tempv ")) { // Command to update tempv
        float newTempv = message.substring(6).toFloat(); // Start after "tempv "
        if (!isnan(newTempv)) {
            tempv = newTempv;
            WebSerial.println("tempv updated to: " + String(tempv));
            WebSerial.println("Invalid tempv value. Please provide a valid number.");
    } else if (message.equalsIgnoreCase("printtemp")) { // Command to call printTemp
        WebSerial.println("Calling printtemp...");
        printtemp();
    } else if (message.equalsIgnoreCase("printwater")) { // Command to call printWater
        WebSerial.println("Calling printwater...");
        printwater();
    } else if (message.equalsIgnoreCase("printtime")) { // Command to call printTime
        WebSerial.println("Calling printtime...");
        printtime();
        WebSerial.println("Unknown command: " + message);
void printCommandList() {
    WebSerial.println("======== Command List ========");
    WebSerial.println("1. timeperlitre <value> - Update time per liter (e.g., timeperlitre 10)");
    WebSerial.println("2. tempv <value> - Update tempv variable (e.g., tempv 25.5)");
    WebSerial.println("3. printtemp - Print temperature data");
    WebSerial.println("4. printwater - Print water flow and usage data");
    WebSerial.println("5. printtime - Print system timing information");
    WebSerial.println("================================");
Serial.begin(115200); // Initialize Serial
  setupOTA("water flow meter", mySSID, myPASSWORD);
  // setup for web seial ////////////
  WiFi.mode(WIFI_STA);
    WiFi.begin(ssid, password);
    if (WiFi.waitForConnectResult() != WL_CONNECTED) {
        Serial.printf("WiFi Failed!\n");
        return;
 WebSerial.begin(&server);
    /* Attach Message Callback */
    WebSerial.onMessage(handleWebSerialMessage);
    server.begin();
  // Initialize buttons
  pinMode(BUTTON_ADD_litre, INPUT_PULLUP);
  pinMode(BUTTON_CYCLE_DISPLAY, INPUT_PULLUP);
  pinMode(BUTTON_RESET, INPUT_PULLUP);
  pinMode(FLOW_BUTTON, INPUT);
  ITimer.attachInterruptInterval(1000, updateFlowTime); // 1000 ms interval = 1 second
  // Initialize backlight pin (set as output)
  pinMode(TFT_BACKLIGHT, OUTPUT);
  digitalWrite(TFT_BACKLIGHT, HIGH); // Turn on backlight initially
  // Initialize thermistor pin
  analogReadResolution(12); // ESP32-S2 uses a 12-bit ADC
  pinMode(THERMISTOR_PIN, INPUT);
  // Initialize display
  tft.init(240, 320);  // Initialize ST7789 with correct screen size (240x240 or 240x320)
  tft.setRotation(1);  // Adjust the rotation if needed
  tft.fillScreen(ST77XX_BLACK);
  tft.setTextColor(ST77XX_WHITE);
  tft.setTextSize(2);
  // Initial display
  updateDisplay();
void handleFlowButton() {
    int reading = digitalRead(FLOW_BUTTON); // Read the button state
    // Debounce logic
    if (reading != currentButtonState) {
        lastDebounceTime = millis();
    if ((millis() - lastDebounceTime) > debounceDelay) {
        if (reading != lastButtonState) {
            lastButtonState = reading;
            if (lastButtonState == HIGH) { // Button pressed
                if (!isFlowing) { // Start the flow timer
                    flowDuration = 0; // Reset the flow duration
                    isFlowing = true;
                    Serial.println("Flow started");
            } else { // Button released
                if (isFlowing) { // Stop the flow timer
                    isFlowing = false;
                    // Calculate the elapsed time in seconds
                    float elapsedSeconds = flowDuration / 1000.0;
                    float litresUsedThisCycle = elapsedSeconds / timePerlitre; // Convert time to litres
                    // Update the total litres used
                    litresUsed += litresUsedThisCycle;
                    // Update the litres remaining
                    litresRemaining = TANK_CAPACITY - litresUsed;
                    // Output the results
                    Serial.print("Flow Duration: ");
                    Serial.print(elapsedSeconds);
                    Serial.println(" seconds");
                    Serial.print("Litres Used This Cycle: ");
                    Serial.print(litresUsedThisCycle, 2);
                    Serial.println(" litres");
                    Serial.print("Total Litres Used: ");
                    Serial.print(litresUsed, 2);
                    Serial.print("Litres Remaining: ");
                    Serial.print(litresRemaining, 2);
                    // Reset flow time
                    flowDuration = 0;
                    // Update the display
                    updateDisplay();
    currentButtonState = reading;
handleFlowButton();
unsigned long currentTime = millis();
    // Check if the desired interval has passed
    if (currentTime - lastPrintTime >= printInterval) {
        lastPrintTime = currentTime; // Update the last print time////////////////////////////////////////////////////////////////////////////////////////////
       printCommandList();
if (millis() - lastTempRead >= tempReadInterval) {
    lastTempRead = millis();
    float currentTemperature = readTemperature();
    if (abs(currentTemperature - lastTemperature) > 3) { // Update if significant change
      lastTemperature = currentTemperature;
      updateDisplay(); // Update display only if temperature changes
#ifdef defined(ESP32_RTOS) && defined(ESP32)
#else // If you do not use FreeRTOS, you have to regularly call the handle method.
  ArduinoOTA.handle();
#endif
  // Handle button presses
  handleAddlitreButton();
  handleCycleDisplayButton();
  handleResetButton();
  // Check inactivity
  if (millis() - lastInputTime > inactivityTimeout) {
    // No input for 5 seconds, turn off the backlight
    digitalWrite(TFT_BACKLIGHT, LOW);
void handleAddlitreButton() {
  int buttonState = digitalRead(BUTTON_ADD_litre);
  if (buttonState == LOW) { // Button is pressed
    if (!addlitreButtonHeld) {
      addlitreButtonHeld = true;
      addlitrePressStart = millis();
      // Turn on backlight on any input
      lastInputTime = millis(); // Reset inactivity timer
  } else if (addlitreButtonHeld) { // Button released after being held
    unsigned long pressDuration = millis() - addlitrePressStart;
    if (pressDuration >= fullLongPressDuration) {
      addRemaininglitre(1.0);
    } else if (pressDuration >= shortLongPressDuration) {
      addUsedlitre(0.5);
void handleCycleDisplayButton() {
  int buttonState = digitalRead(BUTTON_CYCLE_DISPLAY);
  if (buttonState == LOW && (millis() - lastCycleDisplayPress > debounceDelay)) {
    lastCycleDisplayPress = millis();
    cycleDisplay();
    digitalWrite(TFT_BACKLIGHT, HIGH); // Turn on backlight on input
void handleResetButton() {
  int buttonState = digitalRead(BUTTON_RESET);
  if (buttonState == LOW) { // Button pressed
    if (!resetButtonHeld) {
      resetButtonHeld = true;
      resetPressStart = millis();
    } else if (millis() - resetPressStart >= fullLongPressDuration) {
      resetCounter();
void addRemaininglitre(float amount) {
  litresRemaining += amount;
  if (litresRemaining > TANK_CAPACITY) {
    litresRemaining = TANK_CAPACITY;
  updateDisplay();
void addUsedlitre(float amount) {
  if (litresRemaining >= amount) {
    litresUsed += amount;
    litresRemaining -= amount;
    updateDisplay();
void cycleDisplay() {
  displayMode = (displayMode + 1) % 4; // Now cycles through 4 modes
  updateDisplay();
void resetCounter() {
  litresUsed = 0.0;
  updateDisplay();
float getAverageADC(int pin, int numSamples) {
  long sum = 0;
  for (int i = 0; i < numSamples; i++) {
    sum += analogRead(pin);
    delay(1); // Small delay between readings
  return sum / (float)numSamples;
float readTemperature() {
  int numSamples = 10; // Number of samples for averaging
  float adcValue = getAverageADC(THERMISTOR_PIN, numSamples);
  float voltage = adcValue * (tempv / 4095.0); // Convert ADC value to voltage
  if (voltage == 0) return -999.0; // Avoid divide by zero
  float rThermistor = R_FIXED * (3.3 / voltage - 1.0);
  float temperatureK = 1 / ((1 / T0) + (log(rThermistor / R0) / BETA));
  return temperatureK - 273.15; // Convert Kelvin to Celsius
 void updateDisplay() {
  tft.setFont(&FreeSansBold12pt7b);  // Set FreeSansBold as the font
  tft.setTextSize(1);
  float temp = readTemperature();
  //uint16_t sunColor = temperatureToColor(temp);
  switch (displayMode) {
    case 0: // Percent remaining
   drawSun(240, 160, 40, 15, 12, lastTemperature); // Pass color
      tft.setCursor(20, 80);
      tft.print("Remaining: ");
      tft.print(litresRemaining / TANK_CAPACITY * 100, 1);
      tft.println("%");
       tft.setTextColor(ST77XX_BLACK);
       tft.setCursor(202, 162);
      //tft.print("Temp: ");
      tft.print(readTemperature(), 1);
      tft.println(" °C");
    case 1: // litres used and remaining
      tft.setCursor(20, 40);
      tft.print("Used: ");
      tft.print(litresUsed, 2);
      tft.println(" L");
      tft.setCursor(20, 100);
      tft.print(litresRemaining, 2);
      tft.println(" L");
      tft.println(" °C");
    case 2: // Flow rate
      tft.setCursor(20, 60);
      tft.println("Flow Rate:");
      tft.println("l/m"); // Replace with actual data
      tft.println(flowRateLpm, 2); // Display flow rate with 2 decimal places
      tft.println(" °C");
    case 3: // Temperature
    //drawSun(120, 160, 40, 15, 12, lastTemperature); // Pass the current temperature
      tft.setTextSize(2);
      tft.println(" °C");
void drawSun(int x, int y, int radius, int rayLength, int rayCount, float temperature) {
  // Map temperature to color (favor yellow until 30°C, then quickly transition to red)
  uint16_t color;
  if (temperature < 15) {
    color = tft.color565(0, 0, 255); // Blue
  } else if (temperature < 30) {
    float fraction = (temperature - 15) / 15.0; // Normalize temperature to range 15-30
    fraction = pow(fraction, 1.5); // Apply a curve to make the gradient steeper
    uint8_t red = 255 * fraction;
    uint8_t green = 255 - (128 * fraction);
    uint8_t blue = 0;
    color = tft.color565(red, green, blue);
    color = tft.color565(255, 0, 0); // Red
  // Draw the main circle
  tft.fillCircle(x, y, radius, color);
  // Draw the rays
  for (int i = 0; i < rayCount; i++) {
    float angle = i * (360.0 / rayCount);
    float rad = angle * PI / 180.0;
    int x1 = x + cos(rad) * radius;
    int y1 = y + sin(rad) * radius;
    int x2 = x + cos(rad) * (radius + rayLength);
    int y2 = y + sin(rad) * (radius + rayLength);
    tft.drawLine(x1, y1, x2, y2, color);
    int reading = digitalRead(FLOW_BUTTON); // Read the button state in each loop
    // Debounce logic
        // Button press detection (LOW -> HIGH transition)
                if (!isFlowing) {      // Start timing only if not already started
                    flowStart = millis();
                    isFlowing = true;
                    Serial.println("Button Pressed: Starting flow timer");
                if (isFlowing) {       // Stop timing if it was active
                    unsigned long flowStop = millis();
                    flowDuration = flowStop - flowStart; // Calculate elapsed time in milliseconds
                    // Convert duration to litres
                    float elapsedSeconds = flowDuration / 1000.0;      // Convert ms to seconds
                    float newlitresUsed = elapsedSeconds / timePerlitre; // Calculate litres used
                    // Update total litres used and adjust remaining litres
                    litresUsed += newlitresUsed;
                    litresRemaining -= newlitresUsed;
                    // Calculate Flow Rate in litres per Minute (L/min)
                    float elapsedMinutes = elapsedSeconds / 60.0; // Convert seconds to minutes
                    flowRateLpm = newlitresUsed / elapsedMinutes;  // Calculate flow rate
                    // Print results
                    WebSerial.print("Flow Duration: ");
                    WebSerial.print(elapsedSeconds);
                    WebSerial.println(" seconds");
                    WebSerial.print("Water Used: ");
                    WebSerial.print(litresUsed);
                    WebSerial.println(" litres");
                    WebSerial.print("Flow Rate: ");
                    WebSerial.print(flowRateLpm, 2); // Print flow rate with 2 decimal places
                    WebSerial.println(" L/min");
                    // Reset state
                    isFlowing = false;
                    displaytotal();  // Update display to show total (assuming displayTotal() is defined)
    // Update the stable current state
void printtemp() {
  // Read ADC value and calculate voltage
 int adcValue = analogRead(THERMISTOR_PIN);  // You can use any ADC pin
  float adcVoltage = (adcValue / 4095.0) * 3.3;  // Assuming a 12-bit ADC with a 3.3V reference voltage
  WebSerial.print("Temperature: ");
  WebSerial.print(readTemperature(), 1);
  WebSerial.println(" °C");
  WebSerial.println("ADC Value: ");
  WebSerial.print(adcValue);
 WebSerial.println(" | Voltage: ");
  WebSerial.print(tempv, 3); // Print with three decimal places
  WebSerial.println(" V");
void printwater(){
  WebSerial.print("litres Used: ");
  WebSerial.print(litresUsed, 2);
  WebSerial.println(" L");
  WebSerial.print("litres Remaining: ");
  WebSerial.print(litresRemaining, 2);
  WebSerial.print("Tank Capacity: ");
  WebSerial.print(TANK_CAPACITY);
void printtime(){
                   // WebSerial.print(elapsedSeconds);
void displaytotal (){
  displayMode = 1;
  updateDisplay();
here is the code. remember im not as adept at this as some.
This is the pump, and a very unclear pic of the actual wiring.
You must be aware that RV water pumps are designed to stop when the output pressure reaches a certain amount. Is that what is happening?
No this is just on or off i believe. Its how we purchased the camper. It just runs when the button is pressed
Probably not THE problem but GPIO2 is not a good choice for ADC.
Its a lolin s2 mini. Why is that pin not a good choice? Can you explain a bit
--ADC2_CH2 (GPIO 2)
--The ADC2 pins cannot be used when Wi-Fi is enabled. If your project requires Wi-Fi, consider
using the ADC1 pins instead.
--must be LOW during boot and also connected to the on-board LED
///disregard probably wrong esp32///
I see, i didnt think of that either. Not sure thats the reason for the interference. Ive noticed that i get better results when i took out the 4.7k pulldown as suggested and the usb plug is outside the draw as pictured earlier and plugged into that particular usb seems to work better than having it run into the terminal junction as before. Need to test more buts it’s raining right now
I just checked the docs and it says gpio2 is adc1
Yes I had the wrong esp32, sorry
This might help.
https://escapingoutdoors.com.au/fl2202-camping-pump-35psi-4-3-l-min-detail?srsltid=AfmBOoohU9L_zD-5PX5fTbFWuWPpaSMcAUzZKp7POOWFOX3psu4gaX7G
Sorry, it would be clearer if you drew it by hand.
I did post a schematic in the original post. Ive since removed the pulldown resistor. There is only 2 wires from the pump, unless the pressure switch is inside. But its a moot point because it runs off a button right now. The pump was not causing the timing issue unless it was rf. Thanks for the info though.
