i am facing a problem when connecting ham radio (uv-5r) to nano. The Nano should be programmed to switch on a relay to press the ham’s ppt, and i used another pin to generate signal to the mic in of ham. I used human detecting module to be sensor and if anyone moves close to this device, i can get signal by another ham.
But the problem is, when the signal cable pysically connected with ham the interference makes the nano crazy. Of course i know the cable should nit close to the ant. of ham. And i had also ground shield the 2 signal cable bur still not success. i am thinking the interference is directly come from the cable inside.
Could anyone help?
