``Hi all!
I am totally new to the us of RF modules and I just got a pair of 315mhz from cutedigi.
And I am using an arduino Mega for the transmitter and an arduino UNO for the receiver.
I followed the example code given in the virtualwire.h library given below:
Transmitter
// transmitter.pde
// Simple example of how to use VirtualWire to transmit messages
// Implements a simplex (one-way) transmitter with an TX-C1 module
// See VirtualWire.h for detailed API docs
// Author: Mike McCauley (mikem@open.com.au)
// Copyright (C) 2008 Mike McCauley
// $Id: transmitter.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
#include <VirtualWire.h>
Serial.begin(9600); // Debugging only
Serial.println("setup");
// Initialise the IO and ISR
vw_set_ptt_inverted(true); // Required for DR3100
vw_setup(2000); // Bits per sec
const char *msg = "hello";
digitalWrite(13, true); // Flash a light to show transmitting
vw_send((uint8_t *)msg, strlen(msg));
vw_wait_tx(); // Wait until the whole message is gone
digitalWrite(13, false);
delay(200);
The receiver code:
// receiver.pde
// Simple example of how to use VirtualWire to receive messages
// Implements a simplex (one-way) receiver with an Rx-B1 module
// $Id: receiver.pde,v 1.3 2009/03/30 00:07:24 mikem Exp $
vw_rx_start(); // Start the receiver PLL running
uint8_t buf[VW_MAX_MESSAGE_LEN];
uint8_t buflen = VW_MAX_MESSAGE_LEN;
if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
digitalWrite(13, true); // Flash a light to show received good message
// Message with a good checksum received, dump it.
Serial.print("Got: ");
for (i = 0; i < buflen; i++)
Serial.print(buf[i], HEX);
Serial.print(" ");
Serial.println("");
My problem is that I do not get anything at all on the serial monitor, except for “setup”. I do get the led in 13 to be completely lit up on both arduino boards. But I get no message at all… Can anyone help me out? I am programming the Mega (transmitter) then I am plugging it into an alternate power source. Then I upload the receiver code in the UNO and leave it plugged into the computer, so I can monitor the serial window… But there is nothing!
Any help would be greatly appreciate it… I just need to pass a single character or number from transmitter to receiver… nothing major…
Thanks!
Totally lost!
