RF Module 433MHZ
I am using two arduinos (uno R3 and arduino 328 standalone on breadboard) i have successfully connected them through a serial communication using a simple copper wire(not wire library) now i am having problem with transmitting and receiving it using the module plz any ideas on how can i do it
CODE:
TX:
void setup() { // This code will only run once, after each powerup or reset of the board Serial.begin(300); }
void loop() { // This code will loops consecutively Serial.println('a');
RX:....................................... char i ; // for incoming serial data
void setup() { Serial.begin(300); // opens serial port, sets data rate to 9600 bps }
// send data only when you receive data: if (Serial.available() > 0) { // read the incoming byte: i = Serial.read();
// say what you got:
Serial.println(i); } }
//i have tried with all baud rates ...can someone let me know where i am going wrong
Did you mean your Rx and Tx sketches to be the same? Neither of them makes any attempt to receive anything so I don't see how you'd expect anything to happen. Also, you need to explain how the two devices are connected to each other and how they are powered.
powered by arduino uno R3 5Vdc
Judging on the title and no picture or link to say exactly what you have, I can assume you using a simple RF transmitter / receiver, in which case your going to need to use the VirtualWire library. And for some reason the playground link is not working for me :confused:
thanx.....a ....lot
