At this point I'm honestly just as sick of talking about nRF modules as I am this stupid pandemic, but here we are.
I ordered some RF nanos from Aliexpress and I want to know a few things before they arrive.
What is their latency? I'm going to be using the receiver at a distance of 15-30 meters from the transmitter.
Should I send data with an array or a struct? I feel like struct is much easier, but people seem to use arrays much more. Are they better in some way?
How fragile are they? This one sounds irrelevant but one of them is going into a combat robot. When I used normal nRF24L01 modules, they all broke (8 of them) just because of the vibrations caused by the weapon, and around four of them were DOA.
Are they heat-sensitive or do they get hot? This also sounds irrelevant but it's going to be stuffed in a box with an L298N and a brushless ESC. It's going to be warm in there. (The L298N doesn't get very hot, but if something goes wrong it might.)
What is the maximum voltage I can pump through the VIN pins? I'm using a 25C 11.1V LiPo. Normally I would use a 7.4V LiPo but the motors are pretty slow.
Thanks in advance.
