I need some help. I use function rx_setup() оf library VirtualWire.h which is used to transmit information wirelessly. The function use timer аnd there is conflict with any of the other libraries. Does anyone know how I can change the timer, which uses function?
This is the function:
void vw_setup(uint16_t speed)
uint16_t nticks; // number of prescaled ticks needed
uint8_t prescaler; // Bit values for CS0[2:0]
#ifdef __AVR_ATtiny85__
// figure out prescaler value and counter match value
prescaler = _timer_calc(speed, (uint8_t)-1, &nticks);
if (!prescaler)
return; // fault
TCCR0A = 0;
TCCR0A = _BV(WGM01); // Turn on CTC mode / Output Compare pins disconnected
// convert prescaler index to TCCRnB prescaler bits CS00, CS01, CS02
TCCR0B = 0;
TCCR0B = prescaler; // set CS00, CS01, CS02 (other bits not needed)
// Number of ticks to count before firing interrupt
OCR0A = uint8_t(nticks);
// Set mask to fire interrupt when OCF0A bit is set in TIFR0
TIMSK |= _BV(OCIE0A);
#elif defined(__arm__) && defined(CORE_TEENSY)
// on Teensy 3.0 (32 bit ARM), use an interval timer
IntervalTimer *t = new IntervalTimer();
t->begin(TIMER1_COMPA_vect, 125000.0 / (float)(speed));
#else // ARDUINO
// This is the path for most Arduinos
prescaler = _timer_calc(speed, (uint16_t)-1, &nticks);
if (!prescaler)
return; // fault
TCCR1A = 0; // Output Compare pins disconnected
TCCR1B = _BV(WGM12); // Turn on CTC mode
// convert prescaler index to TCCRnB prescaler bits CS10, CS11, CS12
TCCR1B |= prescaler;
// Caution: special procedures for setting 16 bit regs
// is handled by the compiler
OCR1A = nticks;
// Enable interrupt
#ifdef TIMSK1
// atmega168
TIMSK1 |= _BV(OCIE1A);
#else
// others
TIMSK |= _BV(OCIE1A);
#endif // TIMSK1
#endif // __AVR_ATtiny85__
// Set up digital IO pins
pinMode(vw_tx_pin, OUTPUT);
pinMode(vw_rx_pin, INPUT);
pinMode(vw_ptt_pin, OUTPUT);
digitalWrite(vw_ptt_pin, vw_ptt_inverted);
#endif // ARDUINO
// Start the transmitter, call when the tx buffer is ready to go and vw_tx_len is
// set to the total number of symbols to send
thanks in advance
