RF Relay Control
First off, I am an Arduino noob but very experienced with electronics, wiring, troubleshooting etc... its the programming part that is over my head but I am starting to pick up a few things. anyway, I have a very simple application where I simply want to turn on/off devices via my computer and eventually iphone and tablet apps. seems pretty easy and it probably is...
I have an Arduino Uno r3 and I purchased a 433Mhz transmitter with 4 individual relays that will be connected to various devices that I will be able to control from a single location. (basically just a remote control but will eventually add other functions and remote access). I have began testing but with the sketch I uploaded I am not receiving an output. it looks like the program uses pin 10 to send out serial data to trigger each of the 4 RF receiver relay boards. the ebay store that I purchased the RF transmitter and relays from supplied me with a code that as far as I can tell should do exactly what I want it to at this stage. I also have a small LED array that connects an LED to pins 8-13 that helps me to troubleshoot. Pin 11 is high so I know that part of the program is working. Also I am getting the flashing pin 13 when I try to send anything thru the serial monitor although nothing displays below so it looks like nothing is actually being sent... Please let me know if you can help, thanks!
//Author: cantone-electonics
//More information welcome to : http://www.canton-electronics.com
//Arduino 1.0
//Arduino uno R3
//Making a wireless remote control with arduino
//const int data_out = 2;//encoder DOUT
 //LED pin,When receiving the key from the serial port, LED flash
const int ledPin =  13;    //LED pin
const int gnd_pin =  9;    //AS GND
const int data_out =  10;    //encoder DOUT
const int vcc_pin =  11;    //AS VCC
// OSC Resistance is 3.3M
const int Osc_4xCycle = 359; //4 oscillating time periods
const int Osc_12xCycle = 1078;//12 oscillating time periods
unsigned long Temporary[3];//Temporary storage unit
//output bit "0"
void bit_0() {
  digitalWrite(data_out, HIGH);
  delayMicroseconds(Osc_4xCycle);//4 oscillating time periods High level
  digitalWrite(data_out, LOW);
  delayMicroseconds(Osc_12xCycle);//12 oscillating time periods Low level
//output bit "1"
void bit_1() {
  delayMicroseconds(Osc_12xCycle);//12 oscillating time periods High level
  delayMicroseconds(Osc_4xCycle);//4 oscillating time periods Low level
//output bit "f"
void bit_f() {
//output synchronous bit
void bit_syn() {
  delayMicroseconds(Osc_4xCycle*31);//124 oscillating time periods Low level
//send:8 Address Bits, 4 Data Bits, Sync bit
void send_data(){
  unsigned char temp,tab,i;
  unsigned char j,k;
  for(j=0;j<4;j++)
    for(k=0;k<3;k++)//send 8 Address Bits, 4 Data Bits
      tab = Temporary[k];
      for(i=0;i<4;i++)
        temp = tab;
        temp &= 0xC0;
        if(temp == 0xC0)//11 is bit "1"
          bit_1();
        else if(temp == 0x00)//00 is bit "0"
          bit_0();
        else //01 is bit "f"
          bit_f();
        tab =  tab << 2;
   bit_syn();//send Sync bit
  // initialize the LED pin as an output:
  pinMode(ledPin, OUTPUT);
   // initialize the encoder DOUT pin as an output
  pinMode(data_out, OUTPUT);
  pinMode(gnd_pin, OUTPUT);
  pinMode(vcc_pin, OUTPUT);
  digitalWrite(vcc_pin, HIGH);//SET VCC
  digitalWrite(gnd_pin, LOW);//SET GND
  int keydata = 0;
  int receive_flag = 0;
  Temporary[0] = 0xC5;//address A7-A4
  Temporary[1] = 0x55;//address A3-A0
  digitalWrite(ledPin, LOW);//Turn off led
  while(1)
    //get key from pc serial port
    while (Serial.available() > 0)
        keydata = Serial.read();
        receive_flag = 1;
        delay(2);
    if(receive_flag == 1)//if get key,send key
    receive_flag = 0;
    if((keydata == 'a') || (keydata == 'A'))//trigger A channel relay.
      Temporary[2] = 0xC0;// 0xC0 is A button key
      digitalWrite(ledPin, HIGH);//Turn on led
      send_data();//send code word
       Serial.println(".....trigger A channel relay.....");
    else if((keydata == 'b') || (keydata == 'B'))//trigger B channel relay.
      Temporary[2] = 0x30;// 0x30 is B button key
      Serial.println(".....trigger B channel relay.....");
     else if((keydata == 'c') || (keydata == 'C'))//trigger C channel relay.
      Temporary[2] = 0x0C;// 0x0C is C button key
      Serial.println(".....trigger C channel relay.....");
     else if((keydata == 'd') || (keydata == 'D'))//trigger D channel relay.
      Temporary[2] = 0x03;// 0x03 is D button key
      Serial.println(".....trigger D channel relay.....");
    keydata = 0;
    //When receiving the key from the serial port, LED flash
    delay(50);//delay 100ms
I figured it out... I change the serial monitor setting to "no line ending" and that was it, will modify the program to work better for my application but it works as expected. thanks for reading...
