RF relay from 2 places
Hello guys,
i have a room with 2 doors but on one dore we have a light switch, the distence between the doors is 11 meter. Now i want to make 2 same arduino boords with:
1 arduino nano
1 push button
1 rf TX
1 rf RX
1 relay
1 RG led
the 2 boards are wired the same but i do not get the Radio Ferquentie working. The connections are
transmitter
data = D12
Receiver
data = D11
i use this code http://randomnerdtutorials.com/rf-433mhz-transmitter-receiver-module-with-arduino/ bit i do not get something on my terminal.
is it the nano?
Greathings
is it the nano?
Or the code you didn't post or the fact that you do not have the radios connected correctly. You do have to connect more than just the data pin.
You have not provided near enough information for us to determine what is wrong.
Sorry, the RF vcc and ground pins are connected right that’s the reason that i did not post them.
The code is:
Transmitter:
#include <RH_ASK.h>
#include <SPI.h> // Not actualy used but needed to compile
RH_ASK driver(2000,11,12,8,false);
    Serial.begin(9600);   // Debugging only
      pinMode(6, OUTPUT);      // sets the digital pin as output
    if (!driver.init())
         Serial.print("init failed");
    const char *msg = "Hello World!";
    driver.send((uint8_t *)msg, strlen(msg));
    driver.waitPacketSent();
    digitalWrite(6, HIGH);
        digitalWrite(6, LOW);
Recever:
#include <RH_ASK.h>
    if (!driver.init())
         Serial.println("init failed");
    uint8_t buf[12];
    uint8_t buflen = sizeof(buf);
    if (driver.recv(buf, &buflen)) // Non-blocking
      int i;
      // Message with a good checksum received, dump it.
      Serial.print("Message: ");
      Serial.println((char*)buf);
      Serial.println("Message: No");
Sorry for the incomplete post
buf is NOT a string. The println() function does not know how to print arrays except for NULL terminated arrays of chars. Your array is NOT NULL-terminated (and isn’t big enough to be NULL-terminated).
What do these magic numbers mean?
Why? This suggests that you have some SPI device attached, and SPI uses pins 10, 11, 12, and 13, which includes the pins you have the radios attached to.
