RF transmit-receive code not producing output
I'm following a project Antony Cartwright created (TUTORIAL: How to set up wireless RF (433Mhz) Transmitter & Receiver Module - Arduino! (RadioHead) - YouTube).
I've followed the instructions but modified them so that the transmitter is on Arduino and the receiver is on an 8266 (MCU ESP v12).
The code is below, and I'm getting no output on the monitor.
Would you check the code and help me get this de-bugged?
Sketch uploaded to Arduino
Transmitter
#include <RH_ASK.h>
#include <SPI.h> // Not actually used but needed to compile
RH_ASK driver(2000, 9, 9, 10); // ESP8266 or ESP32: do not use pin 11
Serial.begin(9600); // Debugging only
if (!driver.init())
Serial.println("init failed");
const char *msg = "Hello my name is Roger";
driver.send((uint8_t *)msg, strlen(msg));
driver.waitPacketSent();
delay(200);
Sketch uploaded to ESP 12 (MCU 6288
Receiver
#include <RH_ASK.h>
RH_ASK driver(2000, 0, 0, 10); // ESP8266 using pin 0 which is connected to the data pin on receiver
void setup(){
if (!driver.init())
uint8_t buf[RH_ASK_MAX_MESSAGE_LEN];
uint8_t buflen = sizeof(buf);
if (driver.recv(buf, &buflen)) // Non-blocking
int i;
String str = "";
for(int i=0; i<(buflen);i++){
str += (char)buf*;*
  • Serial.begin(9600);*
  • Serial.println("got some characters");*
  • driver.printBuffer("Got:", buf, buflen);*
  • Serial.println(str);*
May be start with supplying a link to the radio devices you are using and a schematic diagram (even hand drawn) of how you have connected it all up.
It looks like you have are, in both cases, using the same pin for TX and RX.
Pin 0 on the ESP8266 may be a bad choice since it is pulled high during normal operations and pin 10 is used for the internal connection and should not be used.
Maybe also post a link to the tutorial (not video) where you found this:
