RF24 and PWM on pins D9 and D10
Hey everyone,
I'm having an issue where my code is able to get messages correctly from an nrf24l01, but I can't use pins D9 and D10.
  • Arduino Nano
  • I'm using A2 and A3 for CE and CSN.
  • I can get messages without any problems, but I can't seem to be able to use D9 and D10
  • D9 and D10 work perfectly when not using RF24.
Any ideas would be appreciated!
Thanks
You don't need to use pins 9 and 10 for the nRF24 - you can use any other pins. However for SPI to work pin 10 must be set as OUTPUT even if it is not being used for SPI. I think that requirement will be satisfied if you use pin 10 for analogWrite().
...R
Simple nRF24L01+ Tutorial
Hi Robin2, yes, read your tutorial, it was very helpful. Thanks for writing it!
However, I can’t seem to find an answer to my problem.
D10 is explicitly set to an output, yes. However, I can’t use it nor D9 while rf24 is initiated. I need both D9 and D10 for PWM in my project.
egaralmeida:
Please post your program and describe in detail what happens when your run it and what you want it to do that is different.
...R
egaralmeida:
It works for me with a Nano.
Just recently installed a soft starting PIR and radar controlled illumination for my attic
that uses PWM on 10, 9, 6, 5 and 3 and a NRF24L01 for reports and configuration.
Works like a charm.
