RF24 library and arduino DUE
Hi amazing Arduino community,
I’m starting to loose my mind on a problem regarding the RF24 library and two arduino DUE.
I’ve cleaned my code so you can have a look at it. I work on an arduino DUE with nRF24L01+ modules.
There is one master device that initiates the communication and then the system follows the followin pattern :
Master sends message 1
Salve answers with message 2
Master answers with message 3
Master sends second answer with message 4
And the loop starts again.
Here is my code :
#include <SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
RF24 globalRadio(57,77);                          // Set up nRF24L01 radio on SPI bus plus pins 7 & 8
// Defines the attirbutes of the RF24Controller class that I use for my radio communication
class RF24Controller
	public:
	virtual ~RF24Controller();
	void			begin(int device);
	void	        Send(byte id);
	RF24			&_radio;
	//protected:
	RF24Controller(uint8_t IRQPin, uint8_t CEPin, uint8_t CSPin, RF24 & radio = globalRadio);
	uint32_t	_timeSync;
	byte	doInterrupt();
	bool	_isDoneTransmitting;
	uint8_t	_IRQPin;
//   Other variables that will be used throughout the code
// Demonstrates another method of setting up the addresses
byte address[][5] = { 0xCC,0xCE,0xCC,0xCE,0xCC , 0xCE,0xCC,0xCE,0xCC,0xCE};
volatile uint32_t emissionTimeStamp = 0;
volatile uint32_t receptionTimeStamp = 0;
volatile bool failed = false;
RF24Controller testRadio(55,57,77);
//   Defines the role of the bord : set to 1 to act as the master or to 2 to act as a slave
int role = 1;
/********************** Setup *********************/
void setup(){
	pinMode(55, INPUT);
	delay(20);
	SerialUSB.begin(115200);
	testRadio.begin(role);
/********************** Main Loop *********************/
	static uint32_t timer = 0;
	static bool resendInfo = false;
	static uint32_t lastSent = 0;
        //   Master sends message 1 every 100 ms
	if (role == 1)  {
		if(millis() - timer > 100)
			SerialUSB.print(F("Now sending "));
			SerialUSB.println(timer);
			testRadio.Send(1);
			timer = millis();
	byte id = testRadio.doInterrupt();
        //   Depending on the received message, we answer with another message
	if(id != 0)
		SerialUSB.println("Received " + String(id));
		if(id == 1)
		testRadio.Send(2);
		if(id == 2)
			testRadio.Send(3);
			resendInfo = true;
			lastSent = millis();
	if(millis() - lastSent > 10 && resendInfo)
		testRadio.Send(4);
		resendInfo = false;
//  Definition of the methods of the RF24Controller class
RF24Controller::RF24Controller(uint8_t IRQPin, uint8_t CEPin,
uint8_t CSPin, RF24 & radio) : _radio(radio)
	_IRQPin = IRQPin;
	_timeSync = 0;
RF24Controller::~RF24Controller() {}
void		catchInterrupt()
	uint32_t interruptTime = micros();
	bool tx,fail,rx;
	globalRadio.whatHappened(tx,fail,rx);
	if ( tx || fail)
		emissionTimeStamp = interruptTime;
		failed = fail;
	else if ( rx || globalRadio.available())
		receptionTimeStamp = interruptTime;
byte     RF24Controller::doInterrupt()
	static uint32_t lastReceptionTime = 0;
	static uint32_t lastEmissionTime = 0;
	byte		tmp[32];
	uint8_t		size;
	if (lastReceptionTime != receptionTimeStamp)
		lastReceptionTime = receptionTimeStamp;
		while (_radio.available())
			size = _radio.getDynamicPayloadSize();
			_radio.read(tmp, size);
		return (tmp[0]);
	else if (emissionTimeStamp != lastEmissionTime)
		lastEmissionTime = emissionTimeStamp;
		_radio.flush_tx();
		_radio.startListening();
		SerialUSB.println("Emission\t" + String(failed));
	return 0;
void		RF24Controller::begin(int device)
	pinMode(_IRQPin, INPUT);
	byte address2[][5] = { 0xCC,0xCE,0xCC,0xCE,0xCC , 0xCE,0xCC,0xCE,0xCC,0xCE};
	_radio.begin();
	_radio.setPALevel(RF24_PA_MAX);
	//globalRadio.setDataRate(RF24_250KBPS);
	_radio.setRetries(0, 0);
	_radio.enableDynamicPayloads();
	//_radio.setChannel(108);
	_radio.setAutoAck(true);
	if(device == 1)
		_radio.openReadingPipe(1, address2[1]);
		_radio.openWritingPipe(address2[0]);
	else if(device == 2)
		_radio.openReadingPipe(1, address2[0]);
		_radio.openWritingPipe(address2[1]);
	delay(50);
	attachInterrupt(digitalPinToInterrupt(_IRQPin),
	catchInterrupt, LOW);
void			RF24Controller::Send(byte id)
	_radio.stopListening();
	byte buffer[30]= {0};
	buffer[0] = id;
	_radio.startWrite(buffer, 30, false);
I have defined a class that is supposed to deal with the RF24 messages.
Before the Setup you can define a role : 1 is master and 2 is slave.
I print each time i receive a message and also I print the fail status each time I send a message.
Now when I have both devices communicating I should get the following information :
On the master side :
Now sending 54641
Emission 0
Received 2
Emission 0
Emission 0
And on the slave side:
Received 1
Emission 0
Received 3
Received 4
But almost every two messages, I have the “Emission 0” on the slave side (which means that the message went over and the ACK was received) but I don’t have any “Received 2” on the master side.
And more incredibly, when I comment the “Send(4)” line everything works normally…
I would really appreciate your help on this matter :smiley:
If you need any more explanation or details I will be glad to provide them.
Thanks a lot,
Regards
