RF24 Library Multi Node Communication Problem
Hello
I am trying to send and receive the data to/from two different nodes to/from the central MCU. The procedure that I am using is as follows:
The central node writes the control information to the panel1, in return panel1 sends the ADC values read and status values to the central node. Then it does the same with panel2.
The code I am using on the central node is
#include<SPI.h>
#include "nRF24L01.h"
#include "RF24.h"
//#include "printf.h"
RF24 radio(9,10);
const uint64_t w_pipe[2] = { 0xA0A0A0A0BBLL, 0xA0A0A0A0CCLL };
const uint64_t r_pipe[2] = { 0xF0F0F0A077LL, 0xF0F0F0A055LL };
struct PICO
  int power1, power2;
  boolean sh1,sh2,sh3,sh4,ma;
struct POCI
  int power1,power2;
  boolean ss1,ss2,ss3,ss4,ma;
byte sz=sizeof(POCI);
  PICO c1,c2;
  POCI p1,p2;
  pinMode(8,OUTPUT);
  //digitalWrite(8,HIGH);
  Serial.println("\n This is the Central Node \n");
  Serial.flush();
  //Setting up the nRF24L01 chip
  radio.begin();
  radio.setRetries(15,15);
  radio.setPayloadSize(sz);
  c1.power1=1000;c1.power2=500;c1.sh1=HIGH;c1.sh2=HIGH;c1.sh3=HIGH;c1.sh4=LOW;
  c2.power1=1000;c2.power2=500;c2.sh1=HIGH;c2.sh2=LOW;c2.sh3=HIGH;c2.sh4=HIGH;
  //open the pipe to write to Panel1 controller
  radio.openWritingPipe(w_pipe[0]);
  radio.write(&c1,sz);
  radio.openReadingPipe(1,r_pipe[0]);
  //Finish writing and start listening for the reply
  radio.startListening();
  //wait for reply, i.e data to be available
  while(!radio.available());
  radio.read(&p1,sz);
  radio.stopListening();
  //digitalWrite(8,LOW);
  //delay(500);
  radio.openWritingPipe(w_pipe[1]);
  radio.write(&c2,sz);
  radio.openReadingPipe(2,r_pipe[1]);
  radio.read(&p2,sz);
  //stop listening to any replies
  Serial.print("Panel 1 " );
  Serial.print("P1 ");
  serial_withz(p1.power1);
  Serial.print(" P2 ");
  serial_withz(p1.power2 );
  Serial.print(" ");
  Serial.print(p1.ss1);
  //Serial.print("\t");
  Serial.print(p1.ss2);
  Serial.print(p1.ss3);
  Serial.print(p1.ss4);
  Serial.print("\n");
  Serial.print(" Panel 2=" );
  serial_withz(p2.power1);
  serial_withz(p2.power2 );
  Serial.print(" ");
  Serial.print(p2.ss1);
  Serial.print(p2.ss2);
  Serial.print(p2.ss3);
  Serial.print(p2.ss4);
  delay(100);
The code for panel1
#include<SPI.h>
#include "RF24.h"
RF24 radio(9,10);
struct PICO
  int power1, power2;
struct POCI
  int power1,power2;
PICO c1;
POCI p1;
int panelpower;
  pinMode(2,OUTPUT);
  digitalWrite(2,LOW);
  //Serial.begin(9600);
  //Serial.println(" This is the  Panel1 \n");
  //Serial.flush();
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  digitalWrite(5,LOW);
  digitalWrite(6,LOW);
  digitalWrite(7,LOW);
  radio.begin();
  //Writing pipe 1 for central node is reading pipe for Panel 1
  radio.openReadingPipe(1,w_pipe[0]);
  //Open the Central node reading pipe 1 for the Panel 1 to write the data to central node
  radio.openWritingPipe(r_pipe[0]);
  //Temporaryly reading analog values
  p1.power1=analogRead(A0);
  p1.power2=analogRead(A1);
  panelpower=p1.power1+p1.power2;
  p1.ss1=digitalRead(5);
  p1.ss2=digitalRead(6);
  p1.ss3=digitalRead(7);
  p1.ss4=digitalRead(8);
  //Start listening on the opened reading pipe for Central Node to send information
  digitalWrite(2,HIGH);
  //Wait for the data to be available
  //Read the dat sent from Central Node into c1
  radio.read(&c1,sz);
  //Stop listening to get ready to write back to central node
  //Write the data available with Panel 1 to Central Node
  radio.write(&p1,sz);
The code for panel2
#include<SPI.h>
#include "RF24.h"
RF24 radio(9,10);
struct PICO
  int power1, power2;
struct POCI
  int power1,power2;
  PICO c2;
  POCI p2;
  int panelpower;
  //Serial.println(" This is the Panel 2 \n");
  //Serial.flush();
  pinMode(2,OUTPUT);
  pinMode(5,OUTPUT);
  pinMode(6,OUTPUT);
  pinMode(7,OUTPUT);
  pinMode(8,OUTPUT);
  radio.begin();
  //Writing pipe 2 for central node is reading pipe for Panel 2
  radio.openReadingPipe(2,w_pipe[1]);
  radio.openWritingPipe(r_pipe[1]);
  p2.power1=analogRead(A0);
  p2.power2=analogRead(A1);
  panelpower=p2.power1+p2.power2;
  p2.ss1=digitalRead(5);
  p2.ss2=digitalRead(6);
  p2.ss3=digitalRead(7);
  p2.ss4=digitalRead(8);
  //Read the data sent from Central Node into c1
  radio.read(&c2,sz);
  //Write the data available with Panel 2 to Central Node
  radio.write(&p2,sz);
The central node is an Arduino UNO clone, and the panels are Atmega8 based homemade Arduino boards.
Now coming to the problem
The code does not work the way I meant it to. When I use the same code on central node with the Panel1 or 2 related code disabled, it works. That is the code works for communication with single panel, when I add the second panel it doesn’t work. It only prints “This is the Central Node” and stops working.
I think the homemade boards are fine as I tested all possible single(Central Node-Panel) combinations with all the home made boards and they worked individually.
I used the LED for debugging the found that it was hanging at
What could be the problem?
Could somebody please help me with this problem?
I even tried ACK payload option to no advantage. Tried including delay but still no use.
P.S: Please comment if this is the wrong section to post this question. I felt it is the appropriate section.
Using RF24Network library would require Atmega16 at least. So using RF24 alone.
Could there be a synchronization problem? If so how can I solve it?
Hi. Have you solved this? I'm desperate in need of solving a situation that I ping 3-4 nodes from one main node and find the distance between the nodes. :disappointed_relieved:
Please reply!
