RF24 Module Receiving with no sender?
I have two RF modules that I am trying to communicate between; the problem is that when I try to communicate with one of the examples; it spits back this weird y with umlauts on it.
If I take the sender offline then the receiver still picks up a signal. I think that the code isn’t setting up the module correctly, as I have seen on other websites, but I am unsure because I have never used something like this before.
I don’t want to have to remake the entire template if its the hardware and not the software, and I really dont know where the problem could lie.
Here is the code and the configuration.
#include <SPI.h>
#include <avr/sleep.h>
#include <avr/power.h>
#include "nRF24L01.h"
#include "RF24.h"
#include "printf.h"
// Hardware configuration
// Set up nRF24L01 radio on SPI bus plus pins 9 & 10
RF24 radio(9,10);
// sets the role of this unit in hardware.  Connect to GND to be the 'pong' receiver
// Leave open to be the 'ping' transmitter
const int role_pin = 7;
// Topology
// Radio pipe addresses for the 2 nodes to communicate.
const uint64_t pipes[2] = { 0xF0F0F0F0E1LL, 0xF0F0F0F0D2LL };
// Role management
// Set up role.  This sketch uses the same software for all the nodes
// in this system.  Doing so greatly simplifies testing.  The hardware itself specifies
// which node it is.
// This is done through the role_pin
// The various roles supported by this sketch
typedef enum { role_ping_out = 1, role_pong_back } role_e;
// The debug-friendly names of those roles
const char* role_friendly_name[] = { "invalid", "Ping out", "Pong back"};
// The role of the current running sketch
role_e role;
// Sleep declarations
typedef enum { wdt_16ms = 0, wdt_32ms, wdt_64ms, wdt_128ms, wdt_250ms, wdt_500ms, wdt_1s, wdt_2s, wdt_4s, wdt_8s } wdt_prescalar_e;
void setup_watchdog(uint8_t prescalar);
void do_sleep(void);
const short sleep_cycles_per_transmission = 4;
volatile short sleep_cycles_remaining = sleep_cycles_per_transmission;
// Normal operation
void setup(void)
  // Role
  // set up the role pin
  pinMode(role_pin, INPUT);
  digitalWrite(role_pin,HIGH);
  delay(20); // Just to get a solid reading on the role pin
  // read the address pin, establish our role
  if ( digitalRead(role_pin) )
    role = role_ping_out;
    role = role_pong_back;
  // Print preamble
  Serial.begin(57600);
  printf_begin();
  printf("\n\rRF24/examples/pingpair_sleepy/\n\r");
  printf("ROLE: %s\n\r",role_friendly_name[role]);
  // Prepare sleep parameters
  // Only the ping out role sleeps.  Wake up every 4s to send a ping
  if ( role == role_ping_out )
    setup_watchdog(wdt_1s);
  // Setup and configure rf radio
  radio.begin();
  // Open pipes to other nodes for communication
  // This simple sketch opens two pipes for these two nodes to communicate
  // back and forth.
  // Open 'our' pipe for writing
  // Open the 'other' pipe for reading, in position #1 (we can have up to 5 pipes open for reading)
    radio.openWritingPipe(pipes[0]);
    radio.openReadingPipe(1,pipes[1]);
    radio.openWritingPipe(pipes[1]);
    radio.openReadingPipe(1,pipes[0]);
  // Start listening
  radio.startListening();
  // Dump the configuration of the rf unit for debugging
  radio.printDetails();
void loop(void)
  // Ping out role.  Repeatedly send the current time
  if (role == role_ping_out)
    // First, stop listening so we can talk.
    radio.stopListening();
    // Take the time, and send it.  This will block until complete
    unsigned long time = millis();
    printf("Now sending %lu...",time);
    radio.write( &time, sizeof(unsigned long) );
    // Now, continue listening
    // Wait here until we get a response, or timeout (250ms)
    unsigned long started_waiting_at = millis();
    bool timeout = false;
    while ( ! radio.available() && ! timeout )
      if (millis() - started_waiting_at > 250 )
        timeout = true;
    // Describe the results
    if ( timeout )
      printf("Failed, response timed out.\n\r");
      // Grab the response, compare, and send to debugging spew
      unsigned long got_time;
      radio.read( &got_time, sizeof(unsigned long) );
      // Spew it
      printf("Got response %lu, round-trip delay: %lu\n\r",got_time,millis()-got_time);
    // Shut down the system
    // Experiment with some delay here to see if it has an effect
    // Power down the radio.  Note that the radio will get powered back up
    // on the next write() call.
    radio.powerDown();
    // Sleep the MCU.  The watchdog timer will awaken in a short while, and
    // continue execution here.
    while( sleep_cycles_remaining )
      do_sleep();
  // Pong back role.  Receive each packet, dump it out, and send it back
  // This is untouched from the pingpair example.
  if ( role == role_pong_back )
    // if there is data ready
    if ( radio.available() )
      // Dump the payloads until we've gotten everything
      bool done = false;
      while (!done)
        // Fetch the payload, and see if this was the last one.
        done = radio.read( &got_time, sizeof(unsigned long) );
        // Spew it.  Include our time, because the ping_out millis counter is unreliable
        // due to it sleeping
        printf("Got payload %lu @ %lu...",got_time,millis());
      // Send the final one back.
      radio.write( &got_time, sizeof(unsigned long) );
      printf("Sent response.\n\r");
      // Now, resume listening so we catch the next packets.
// Sleep helpers
// 0=16ms, 1=32ms,2=64ms,3=125ms,4=250ms,5=500ms
// 6=1 sec,7=2 sec, 8=4 sec, 9= 8sec
  prescalar = min(9,prescalar);
  uint8_t wdtcsr = prescalar & 7;
  if ( prescalar & 8 )
    wdtcsr |= _BV(WDP3);
  MCUSR &= ~_BV(WDRF);
  WDTCSR = _BV(WDCE) | _BV(WDE);
  WDTCSR = _BV(WDCE) | wdtcsr | _BV(WDIE);
ISR(WDT_vect)
  --sleep_cycles_remaining;
void do_sleep(void)
  set_sleep_mode(SLEEP_MODE_PWR_DOWN); // sleep mode is set here
  sleep_enable();
  sleep_mode();                        // System sleeps here
  sleep_disable();                     // System continues execution here when watchdog timed out
// vim:ai:cin:sts=2 sw=2 ft=cpp
ROLE: Pong back
STATUS = 0xff RX_DR=1 TX_DS=1 MAX_RT=1 RX_P_NO=7 TX_FULL=1
RX_ADDR_P0-1 = 0xffffffffff 0xffffffffff
RX_ADDR_P2-5 = 0xff 0xff 0xff 0xff
TX_ADDR = 0xffffffffff
RX_PW_P0-6 = 0xff 0xff 0xff 0xff 0xff 0xff
EN_AA = 0xff
EN_RXADDR = 0xff
RF_CH = 0xff
RF_SETUP = 0xff
CONFIG = 0xff
DYNPD/FEATURE = 0xff 0xff
Data Rate = 1MBPS
Model = nRF24L01
CRC Length = 16 bits
PA Power = PA_HIGH
EN_AA = 0xff
EN_RXADDR = 0xff
RF_CH = 0xff
RF_SETUP = 0xff
CONFIG = 0xff
Data Rate = 1MBPS
Model = nRF24L01
PA Power = PA_HIGH
Radio is not initialized correctly, also do make sure inputs/outputs are "stated" or they will be floating and appear to be TX/RXing and can also be affected by noise/capacitance etc.
ie pinMode(1, INPUT,OUTPUT);
Essef :8)
ESSEF:
EN_AA = 0xff
EN_RXADDR = 0xff
RF_CH = 0xff
RF_SETUP = 0xff
CONFIG = 0xff
Data Rate = 1MBPS
Model = nRF24L01
PA Power = PA_HIGH
Essef :8)
So I guess that means that the test code is wrong, thanks.
The joys of building up programs from nothing, lol.
Thank you.
If you believe your hardware connections are correct then run one of the example programs from the rf24 folder, they all function correctly i use the pingpairdyn sketch which sends chunks of the alphabet back and forth repeatedly.
Get the above operational first then, sketch in your own work and debug it. Essef :8)
