I am hoping somebody can help point me in the right direction.
I am trying to send a data batch to node1, a different data batch to node2 etc. I have played for over a week with everything I can find on the forum and web. Several sites tell how to send data from several nodes back to master node, but I can't seem to do it in reverse.
Can anyone please suggest a site where I can look preferably with working sketch.
Many Thanks
Let each batch contain the identity of the receiver and send the batches one by one.
Thanks for your reply, much appreciated.
I am trying to achieve just that, I can send to any node but when I try to create a seperate data package like
struct Data_Package {
"input"
Data_Package date:
If I try to create a Data_Package2 etc, I get the brakes slam on hard and steam comes out of my relief valve, I get the message "conflicting declaration 'Data_Package2 data'
I am trying to make node 1 Loco1, node2 Loco2, node 3 Junction points control, node 4 Station points control etc.
Do you know of any sketches that I can peruse to find out the method i should be looking at?
I am 77 and just starting out on G gauge after a lifetime of 71/4 live steam.
Google is your friend, Have a look here very well explained, This sounds like what your after
https://howtomechatronics.com/tutorials/arduino/how-to-build-an-arduino-wireless-network-with-multiple-nrf24l01-modules/
Hello Steve,
Thanks you for your suggestion. This is one of the sites I have been trying to implement. It works fine, but my problem is that the mechatronics sketches only send one command between nodes.. I am failing to find a way to send a batch of commands (Data_Package) , every way I try to include different batches to different nodes it won't compile.
All the best from a cold and wet Kent.
If you upload your code then others may be able to help or spot where your going wrong. I'm no expert and still learning new stuff all the time.
I followed that tutorial and had 3 nodes talking to each other sending data between the 3
In what way wont your code compile ?
