RF24 Network
i,
I am trying to make a network for RF24 modules but could not achieve. I loaded github RF24Network softwares but it gives error. What can i do ?
Regards
Bulent
What error?
Post the program YOU uploaded to your Arduinos and post the actual error message.
Have you got simple 1 to 1 communication between a pair of nRF24s working? If not that should be the first step.
Do you really need to use the Network feature?
…R
Simple nRF24L01+ Tutorial
Hello Robin2,
I want to make an Arduino network which 5 modules send data recpectively and one module receives data. I loaded the RF24Network files from github(Rf24Network.h, RF24Network.cpp) and when I load the example file (helloworld_rx) in RF24Network file I receives following messages and system gives "Error compiling for board Arduino Nano" messages.
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'uint16_t RF24Network::read(RF24NetworkHeader&, void*, uint16_t)':
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp:682:35: error: 'rf24_min' was not declared in this scope
maxlen = rf24_min(maxlen,bufsize);
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'bool RF24Network::write(RF24NetworkHeader&, const void*, uint16_t, uint16_t)':
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp:782:79: error: 'rf24_min' was not declared in this scope
uint16_t fragmentLen = rf24_min((uint16_t)(len-offset),max_frame_payload_size);
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp:815:16: error: 'class RF24' has no member named 'txStandBy'
ok = radio.txStandBy(txTimeout);
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'bool RF24Network::write(uint16_t, uint8_t)':
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp:962:11: error: 'class RF24' has no member named 'txStandBy'
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp: In member function 'bool RF24Network::write_to_pipe(uint16_t, uint8_t, bool)':
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp:1071:14: error: 'class RF24' has no member named 'writeFast'
ok = radio.writeFast(frame_buffer, frame_size,0);
D:\BULENT\Arduino\libraries\RF24Network\RF24Network.cpp:1074:16: error: 'class RF24' has no member named 'txStandBy'
exit status 1
Error compiling for board Arduino Nano.
bmkaya:
Hello Robin2,
You have posted the error messages but you did not post the program - without which the messages are meaningless.
And you did not answer my other 2 questions.
Now, here are two more questions (making 4, in all)
  • how far apart are the 5 Arduinos?
  • how much data needs to be transmitted (number of bytes per second)?
PS … To make it easy for people to help you post code and error messages using the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
The program is standart Arduino/RF24Network/examples/helloworld_rx/helloworld_rx.ino. I just only tried this program. If there was no error message, i was going to make a network. Fisrt of all I wanted to check RF24Network software whether there wae any problem or not. But when I saw the error messages, i could not proceed for network.
Regards
Bulent
My 4 questions are still awaiting an answer.
But I am not in any hurry. My nRF24s work fine.
...R
