RF24 / NRF24L01 - Can I set "setPALevel" on the fly ??
I have been using the basic PCB antenna NRF24L01+ devices with the 8 pin header for a lot of testing
I have found a situation where these jiggers put out too much power for my application, but only sometimes (its complex to go into right now)
I have been setting radio.setPALevel(RF24_PA_HIGH); but I believe the HIGH setting is only available on the PA+LNA version
So then I guess it drops back to a default setting,
so for powerLevels we have ...
RF24_PA_MIN = -18dBm, RF24_PA_LOW = -12dBm, RF24_PA_HIGH = -6dBm, RF24_PA_MAX = 0dBm
If I want to swap between two power levels would I need to powerDown the radio first ?
Can I just change it on the fly ?
Does anyone have any other info ?
and the answer is YES !
Snippet....
  if (millis() - refreshTimer > 5000) {
    radio.powerUp();
    refreshTimer = millis();
    digitalWrite(LED,HIGH);
    delay(100);
    for (x=0; x<3; x++) {
      radio.setPALevel(POWER[x]);    // POWER[0] = RF24_PA_MIN, [1] = LOW, [2] = HIGH
      radio.openWritingPipe(RXTXaddress[0]);
      payload[1] = x; // just a byte containing the power level
      radio.stopListening();
      radio.write( payload, sizeof(payload) );
      radio.startListening();
      radio.openWritingPipe(RXTXaddress[1]);
      delay(10);
    radio.powerDown();
    digitalWrite(LED,LOW);
Alternate addressing used to communicate with the pingPair example (not important for this example)
