RF24 Write question
Hi
I have a small program which is running perfectly with the hardwired serial, I am trying to forward these serial commands through the RF24 library. The below code works bar one problem, at the other end numbers say 34 come out a ascii in this case 51 52. I dont have this problem when I Serial.read() straight in to an int and use it, I apologise in advance I know whats going wrong but its a little hard to put in to words if anyone has an idea how to work around this that would be great.
int incomingByte;
 if (Serial.available() > 0) {
  // read the incoming byte:
  radio.stopListening();
  incomingByte = Serial.read();
  radio.write(&incomingByte,sizeof(int));
  radio.startListening();
Here is one problem, you read one byte from the serial port and write two bytes to the radio.
