RF24L01 and motor connected. Get char from RF24L01 and run a motor.
Hello everyone! I would like to get a message and compare it to . The transmitter is working properly, but the receiver only gets message and transmit it over Serial. I want to get message directly from received text.
#include <SPI.h>
#include <nRF24L01.h>
#include <RF24.h>
RF24 radio(7, 8); // CE, CSN
const byte address[6] = "00001";
 MOTOR PARAMETERS
const int pinMA1=2;
const int pinMA2=3;
const int Enable1=4;
float val=255;
  radio.begin();
  radio.openReadingPipe(0, address);
  radio.setPALevel(RF24_PA_MAX);
  radio.startListening();
MOTOR PIN CONFIGURATION
  pinMode(pinMA1, OUTPUT);
  pinMode(pinMA2, OUTPUT);
  pinMode(Enable1, OUTPUT);
  digitalWrite(pinMA1, LOW);
  digitalWrite(pinMA2, LOW);
  analogWrite(Enable1, 0);
  if (radio.available()) {
    char text[12] = "";
    radio.read(&text, sizeof(text));
    Serial.println(text);
    if(text=="HELLO WORLD"){
  Serial.println("forward A");
  digitalWrite(pinMA1, HIGH);
  analogWrite(Enable1, val);
  delay(6000);
Thank you!
Have a look at this Simple nRF24L01+ Tutorial.
Wireless problems can be very difficult to debug so get the wireless part working on its own before you start adding any other features.
The examples are as simple as I could make them and they have worked for other Forum members. If you get stuck it will be easier to help with code that I am familiar with. Start by getting the first example to work
...R
    char text[12] = "";
text is NOT a string, so you should not be passing it to a function that expects a string.
Learn what makes a char array a string (Hint: There MUST be a NULL terminator), and make text a string BEFORE you pass it to a function that expects a string.
Learn how to compare strings, too. The == operator is NOT the way.
PaulS:
When using Cstrings you must use strcmp() to compare values rather than ==
...R
