RF433 MHz transmitter does not send
Hi everybody,
I am trying to get a 433 MHz transmitter to send commands to activate and deactivate RC power outlets.
I am using the RCswitch library with an arduino Uno (http://code.google.com/p/rc-switch/).
The receiver works fine, I can receive signals send via the remote control that came with the power sockets. However, the transmitter does not work yet.
Receiver module: RF Link Receiver - 4800bps (434MHz) - WRL-10532 - SparkFun Electronics
Transmitter module: RF Link Transmitter - 434MHz - WRL-10534 - SparkFun Electronics
Receiver Code (receive example from the rcswitch library...):
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
  mySwitch.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
  if (mySwitch.available()) {
    output(mySwitch.getReceivedValue(), mySwitch.getReceivedBitlength(), mySwitch.getReceivedDelay(), mySwitch.getReceivedRawdata(),mySwitch.getReceivedProtocol());
    mySwitch.resetAvailable();
Transmitter Code:
int led = 11;
  Serial.begin(4800);
  Serial.println("Setup");
  // Transmitter is connected to Arduino Pin #10
  mySwitch.enableTransmit(10);
  // Optional set pulse length.
   mySwitch.setPulseLength(360);
  // Optional set protocol (default is 1, will work for most outlets)
  // mySwitch.setProtocol(2);
  // Optional set number of transmission repetitions.
   mySwitch.setRepeatTransmit(15);
  pinMode(led, OUTPUT);
  // STECKDOSE: ELRO, A
  /* Same switch as above, but using binary code */
  mySwitch.send("010001000000010101010001");
  digitalWrite(led, HIGH);
  Serial.println("ON");
  mySwitch.send("010001000000010101010100");
  digitalWrite(led, LOW);
  Serial.println("OFF");
Has anybody similar problems with the transmitter? Can anybody help me out?
Any help is greatly appreciated!
Papillon
I can't help you, but:
That is NOT sending binary data.
i want to use one Arduino hooked up to an Quasar AM transmitter and it has to communicate with an AM Receiver. I want to control LEDs wirelessly using this cheap method, Please help
