RF69 Radio Comms Code Issue
I am having troubling getting the manager.sendtoWait and/or manager.recvfromAck functions of the RHReliableDatagram.h library working using two identical RF69 boards, and two Arduino Nanos (using the Serial Monitor). I know there are other libraries but I want to understand what I am doing wrong here please.
I have confirmed my wiring and have a working set of code without using these functions above (no acknowledgements of transmissions), but as soon as I try to use these functions above, I get sendtoWait failed when I try to use manager.sendtoWait, which I know either means the sendtoWait isn't working to produce a proper transmission, or that the recvfromAck isn't working to produce the acknowledgement that sendtoWait is waiting for (hence when it times out after the default number of retries it fails).
Please could someone help. I am just using the example libraries to build up my understanding of the RF69 boards at the moment.
Working Code (Uploaded to both Arduino Nanos using RF69 boards). Using the Serial Monitor I can send and receive messages fine. But without any acknowledgements for those messages.
// rf69 demo tx rx.pde
// -*- mode: C++ -*-
// Example sketch showing how to create a simple messaging client
// with the RH_RF69 class. RH_RF69 class does not provide for addressing
// or reliability, so you should only use RH_RF69 if you do not need the
// higher level messaging abilities.
// It is designed to work with the other example RadioHead69_RawDemo_RX.
// Demonstrates the use of AES encryption, setting the frequency and
// modem configuration.
#include <SPI.h>
#include <RH_RF69.h>
/************ Radio Setup ***************/
// Change to 434.0 or other frequency, must match RX's freq!
#define RF69_FREQ 434.0
// Arduino Nano
#define RFM69_CS     10  // "B"
#define RFM69_INT     3  // "C"
#define RFM69_RST     2  // "A"
#define LED           5
#define RFM69_IRQN   digitalPinToInterrupt(RFM69_INT)
// Singleton instance of the radio driver
RH_RF69 driver(RFM69_CS, RFM69_INT);
int16_t packetnum = 0;  // packet counter, we increment per xmission
  //while (!Serial) delay(1); // Wait for Serial Console (comment out line if no computer)
  pinMode(LED, OUTPUT);
  pinMode(RFM69_RST, OUTPUT);
  digitalWrite(RFM69_RST, LOW);
  Serial.println("Feather RFM69 TX Test!");
  // manual reset
  digitalWrite(RFM69_RST, HIGH);
  delay(10);
  delay(10);
  if (!driver.init())
    Serial.println("RFM69 radio init failed");
    while (1);
  Serial.println("RFM69 radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM (for low power module)
  // No encryption
  if (!driver.setFrequency(RF69_FREQ))
    Serial.println("setFrequency failed");
  // If you are using a high power RF69 eg RFM69HW, you *must* set a Tx power with the
  // ishighpowermodule flag set like this:
  driver.setTxPower(20, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the server
  uint8_t key[] = { 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08,
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08};
  driver.setEncryptionKey(key);
  Serial.print("RFM69 radio @");  Serial.print((int)RF69_FREQ);  Serial.println(" MHz");
  //delay(1000);  // Wait 1 second between transmits, could also 'sleep' here!
  static char sendbuffer[62];
  static int sendlength = 0;
  // SENDING
  // In this section, we'll gather serial characters and
  // send them to the other node if we (1) get a carriage return,
  // or (2) the buffer is full (61 characters).
  // If there is any serial input, add it to the buffer:
  if (Serial.available() > 0)
    char input = Serial.read();
    if (input != '\r') // not a carriage return
      sendbuffer[sendlength] = input;
      sendlength++;
    // If the input is a carriage return, or the buffer is full:
    if ((input == '\r') || (sendlength == 61)) // CR or buffer full
      // Send the packet!
      Serial.print("Transmitting [");
      for (byte i = 0; i < sendlength; i++)
        Serial.print(sendbuffer[i]);
      Serial.println("]");
      driver.send((uint8_t *)sendbuffer, strlen(sendbuffer));
      driver.waitPacketSent();
      sendlength = 0; // reset the packet
  // Now wait for a reply
  uint8_t buf[RH_RF69_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  if (driver.recv(buf, &len))
    if (!len) return;
    buf[len] = 0;
    Serial.print("Got a reply: ");
    Serial.println((char*)buf);
Not Working Code (Transmitter Side)
#include <RHReliableDatagram.h>
#include <SPI.h>
uint8_t CLIENT_ADDRESS = 1;
uint8_t SERVER_ADDRESS = 2;
//For Teensy 3.x and T4.x the following format is required to operate correctly
//This is a limitation of the RadioHead radio drivers
//----- END TEENSY CONFIG
//RH_RF69 driver(15, 16); // For RF69 on PJRC breakout board with Teensy 3.1
//RH_RF69 rf69(4, 2); // For MoteinoMEGA https://lowpowerlab.com/shop/moteinomega
// Class to manage message delivery and receipt, using the driver declared above
RHReliableDatagram manager(driver, CLIENT_ADDRESS);
  delay(100);
  //pinMode(LED, OUTPUT);
  // manual reset - added for Teensy
  delay(10);
  delay(100);
  if (!manager.init())
    Serial.println("init failed");
  driver.setFrequency(434.0);
  // If you are using a high power RF69, you *must* set a Tx power in the
  // range 14 to 20 like this:
  driver.setTxPower(20);
uint8_t data[] = "Hello World!";
// Dont put this on the stack:
  Serial.println("Sending to rf69_reliable_datagram_server");
  // Send a message to manager_server
  if (manager.sendtoWait(data, sizeof(data), SERVER_ADDRESS))
    // Now wait for a reply from the server
    uint8_t from;
    if (manager.recvfromAckTimeout(buf, &len, 2000, &from))
      Serial.print("got reply from : 0x");
      Serial.print(from, HEX);
      Serial.print(": ");
      Serial.println("No reply, is rf69_reliable_datagram_server running?");
    Serial.println("sendtoWait failed");
  delay(5);
Not Working Code (Receiver Side)
#include <SPI.h>
RHReliableDatagram manager(driver, SERVER_ADDRESS);
  delay(100);
  delay(10);
  delay(100);
  Serial.println("init pass");
uint8_t data[] = "And hello back to you";
  // Wait for a message addressed to us from the client
  uint8_t from;
  if (manager.recvfromAck(buf, &len, &from))
    Serial.print("got request from : 0x");
    Serial.print(": ");
    // Send a reply back to the originator client
    if (!manager.sendtoWait(data, sizeof(data), from))
Sorry for the irrelevant comments throughout the codes referencing to Teensy etc. I have used the same pinouts as the working code, and as I mentioned, I am trying to gain an understanding of how these boards work by practically having a go. I feel I am nearly there and am being blocked by something silly (maybe me).
The rather low level calls in the RadioHead library to functions like sendtoWait() are less easy to use than the higher level network examples.
I strongly recommend to start with the working examples built in to the library, like the RF69 reliable datagram examples: Files>Examples>RadioHead>rf69>rf69_reliable_datagram_client etc.
// rf69_reliable_datagram_client.pde
// Example sketch showing how to create a simple addressed, reliable messaging client
// with the RHReliableDatagram class, using the RH_RF69 driver to control a RF69 radio.
// It is designed to work with the other example rf69_reliable_datagram_server
// Tested on Moteino with RFM69 http://lowpowerlab.com/moteino/
// Tested on miniWireless with RFM69 www.anarduino.com/miniwireless
// Tested on Teensy 3.1 with RF69 on PJRC breakout board
#include <SPI.h>
#define CLIENT_ADDRESS 1
#define SERVER_ADDRESS 2
RH_RF69 driver;
//RH_RF69 driver(4, 2); // For MoteinoMEGA https://lowpowerlab.com/shop/moteinomega
//RH_RF69 driver(8, 7); // Adafruit Feather 32u4
  while (!Serial)
  //driver.setTxPower(14, true);
    uint8_t from;
      Serial.print(": ");
For a three link reliable datagram network with a central repeater, you may find this example useful:
Hello sir. This is very similar to the example I am trying to use. As you can see in the quote below, sendtoWait is the function that is used, and is what I am having issues with.
I have also tried changing the baud rate of the serial monitor back to 9600 but this made no difference.
Still getting this on the transmission side, and nothing on the receiver side:
17:32:04.718 -> Sending to rf69_reliable_datagram_server
17:32:05.989 -> sendtoWait failed
But your code doesn't work. Start with working code instead. That is the recommended practice with any new library.
Baud rates are irrelevant as long as they match on both ends.
I did start with an example previously, when I submitted that code.
Nevertheless, you prompting me to use the example made me completely restart with the examples, as suggested by your recent reply.
It is now working with the following code. I will try to figure out what the difference is, but I have had a niggly issue like this with the serial monitor not turning on before, and never found out with that. But I will try. I guess it was either the example that I used maybe being from a different but similar library or just me messing something up that somehow still compiled and uploaded fine.
Thank you for this:
// messaging client with the RH_RF69 class.
// It is designed to work with the other example RadioHead69_AddrDemo_RX.
#include <SPI.h>
// Who am i? (server address)
#define MY_ADDRESS   1
// Where to send packets to! MY_ADDRESS in client (RX) should match this.
#define DEST_ADDRESS 2
RH_RF69 rf69(RFM69_CS, RFM69_INT);
RHReliableDatagram rf69_manager(rf69, MY_ADDRESS);
  Serial.println("Feather Addressed RFM69 TX Test!");
  // manual reset
  delay(10);
  delay(10);
  if (!rf69_manager.init()) {
    while (1);
  // No encryption
  if (!rf69.setFrequency(RF69_FREQ)) {
  rf69.setTxPower(20, true);  // range from 14-20 for power, 2nd arg must be true for 69HCW
  // The encryption key has to be the same as the one in the client
                    0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08 };
  rf69.setEncryptionKey(key);
uint8_t data[] = "  OK";
  char radiopacket[20] = "Hello World #";
  itoa(packetnum++, radiopacket+13, 10);
  Serial.print("Sending "); Serial.println(radiopacket);
  // Send a message to the DESTINATION!
  if (rf69_manager.sendtoWait((uint8_t *)radiopacket, strlen(radiopacket), DEST_ADDRESS)) {
    uint8_t from;
    if (rf69_manager.recvfromAckTimeout(buf, &len, 2000, &from)) {
      buf[len] = 0; // zero out remaining string
      Serial.print("Got reply from #"); Serial.print(from);
      Serial.print(" [RSSI :");
      Serial.print(rf69.lastRssi());
      Serial.print("] : ");
      Serial.println("No reply, is anyone listening?");
    Serial.println("Sending failed (no ack)");
// It is designed to work with the other example RadioHead69_AddrDemo_TX.
#include <SPI.h>
// Who am i? (client address)
#define MY_ADDRESS   2
  Serial.println("Feather Addressed RFM69 RX Test!");
  // manual reset
  delay(10);
  delay(10);
    while (1);
  // No encryption
  if (rf69_manager.available()) {
    uint8_t from;
    if (rf69_manager.recvfromAck(buf, &len, &from)) {
      Serial.print("Got packet from #"); Serial.print(from);
      if (!rf69_manager.sendtoWait(data, sizeof(data), from))
