RFduino error "RFduino device required for RFduino hex file"
I'm trying to upload the basic code of
to my RFDuino. I used the additional boards manager URL "https://gist.github.com/per1234/f7822073e05276c4243740eaab4235d1/raw/9c34051294ddd54dbbdf3bec392df0afef8da938/package_rfduino166_index.json" as mentioned by Pert, and I'm using arduino 1.6.13.
The output error is:
Arduino: 1.6.13 (Windows 10), Board: "RFduino"
Sketch uses 2,560 bytes (1%) of program storage space. Maximum is 131,072 bytes.
Global variables use 416 bytes of dynamic memory.
C:\Users\uvide\AppData\Local\Arduino15\packages\RFduino\hardware\RFduino\2.3.3//RFDLoader.exe -q COM3 C:\Users\uvide\AppData\Local\Temp\arduino_build_526101/sketch_nov02a.ino.hex
____________________
fail.......fail.......fail.......
An error occurred while uploading the sketch
option enabled in File -> Preferences.
Duplicate post deleted.
Kudos for using code tags but please READ THIS POST.
It will help you get the best out of the forum.
Is that all there was in the console for error messages ?
Did you have VERBOSE turned on in preferences ?
Bob.
I turned on verbose output during upload, and that was the output I received.
Uvini.
