RFduino's Bluetooth client setup [NEED HELP !!!!]
#include <RFduinoBLE.h>
#include<Wire.h>
const int MPU_addr=0x68;
int16_t axis_X,axis_Y,axis_Z;
int minVal=265;
int maxVal=402;
double x;
double y;
double z;
void setup(){
  Wire.begin();
  Wire.beginTransmission(MPU_addr);
  Wire.write(0x6B);
  Wire.write(0);
  Wire.endTransmission(true);
  RFduinoBLE.advertisementData = "xAng";
  RFduinoBLE.deviceName = "RFDUINO";
  RFduinoBLE.begin();
void loop(){
  Wire.write(0x3B);
  Wire.endTransmission(false);
  Wire.requestFrom(MPU_addr,14,true);
  axis_X=Wire.read()<<8|Wire.read();
  axis_Y=Wire.read()<<8|Wire.read();
  axis_Z=Wire.read()<<8|Wire.read();
    int xAng = map(axis_X,minVal,maxVal,-90,90);
    int yAng = map(axis_Y,minVal,maxVal,-90,90);
    int zAng = map(axis_Z,minVal,maxVal,-90,90);
       x= RAD_TO_DEG * (atan2(-yAng, -zAng)+PI);
       y= RAD_TO_DEG * (atan2(-xAng, -zAng)+PI);
       z= RAD_TO_DEG * (atan2(-yAng, -xAng)+PI);
 /* Serial.print("\n Angle x = ");
  Serial.print(x);
  Serial.println((char)176); */
  Serial.print("Angle y = ");
  Serial.print(y);
 /* Serial.print("Angle z = ");
   Serial.print(z);
I connected my RFduino with MPU6050. The problem I'm facing now is the bluetooth part. When I run this program, I can pair my computer with my rfduino. But I couldn't connect it to receive the data. What's wrong ? Do I need a specific program to activate the rfduino's bluetooth ?
