If you look at the code I posted it is in there.
I still want to know how you would fix your broken code example to help me understand it.
OK I changed it a bit hoping to eliminate the pause but it didn't help. it did however put the printed messages through SoftSerial.
#include <SoftwareSerial.h>
#include <Keypad.h>
#define rxPin 2
#define txPin 3
#define ledpin 19const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'#','0','*'}
};byte rowPins[ROWS] = { 11, 6, 7, 9 }; // Connect keypad ROW0, ROW1, ROW2, ROW3 to these pins.
byte colPins[COLS] = { 10, 12, 8 }; // Connect keypad COL0, COL1 and COL2 to these pins.// Create the Keypad
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );#define ledpin 19
SoftwareSerial LCD = SoftwareSerial(rxPin, txPin); //create a Serial object LCD
char code[20];int val = 0;
int bytesread = 0;char Red[] = "3900A502C35D"; // Define valid tags
char Blue[] = "39009F2DAD26"; // "
char Yellow[] = "39005082A843"; // "
char Card1[] = "140029A6079C"; // "
char Card2[] = "14002943BFC1"; // "int tagCnt = 5;
int LOCK = 4;void setup()
Serial.begin(9600); //open serial hardware
LCD.begin(9600); //open serial softwarepinMode(rxPin, INPUT); //set pin on arduino for receiving RFID data
pinMode(txPin, OUTPUT); //this is not important
pinMode(ledpin, OUTPUT);
digitalWrite(ledpin, HIGH);for(int i=0; i<tagCnt; i++)
pinMode(LOCK, OUTPUT);
}void loop()
val = 0;
bytesread = 0;
if (Serial.available() > 0)
while(bytesread < 12)
// read 12 digit codeval = Serial.read();
if(val == 3)
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
}if(val != 2)
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
code[bytesread] = '\0'; // add the NULL
}if(bytesread >= 12)
{ // if 12 digit read is complete
Serial.print("Tag: [");
for(int i=0; i<bytesread; i++)
Serial.print(code*);*
- Serial.println("]"); //print the whole 13 bytes*
- int tag = FindValidTag(code);*
- Serial.print("Tag number: ");*
- Serial.println(tag);*
- digitalWrite(LOCK, LOW);*
- if(tag > 0 && tag <= tagCnt)*
- digitalWrite(LOCK, HIGH);*
- delay(5000);*
char key = kpd.getKey();
if(key) // same as if(key != NO_KEY)
{- switch (key)*
_ case '*':_- digitalWrite(ledpin, LOW);*
- break;*
- case '#':*
- digitalWrite(ledpin, HIGH);*
- break;*
- default:*
- Serial.println(key);*
int FindValidTag(char *code)
if(strcmp(code, Red) == 0)- return 1;*
else if(strcmp(code, Blue) == 0)- return 2;*
else if(strcmp(code, Yellow) == 0)- return 3;*
else if(strcmp(code, Card1) == 0)- return 4;*
else if(strcmp(code, Card2) == 0)- return 5;*
else- return 0;*
}[/quote]
Well I finally got my new Seeduino Mega after waiting nearly 3 weeks! It sure takes things awhile to get here from china! I'm gonna see if I can get the code working faster on it since it has more Hardware serial. It's a nice board, only slightly larger than the Arduino. I'll definately have plenty of I/O's on this board ;D
Ok I think I know what the problem is, it's the delay to allow people time to open the door! but how do I relocate it so it doesn't slow the read time down too???
Use millis to capture the time the door is unlocked. Set a time 5 seconds (or 10 or 15 would be better) in the future (timeToRelock) when the door should be locked again. Then, remove the delay(5000); statement.
Add a test in loop:
if(millis() - timeToRelock > 0)
Put this after the code that unlocks the door.
If the door is open do you still need to read?
Thanks I'll give that a try.
So how do I declare "timeToRelock"? or better yet is there a better description of the use of millis somewhere besides the reference page??
here is what I tried.
timeToRelock = millis();
The timeToRelock variable is a long.
long timeToRelock = 0;
Your code should look more like this
timeToRelock = 0;
Thanks and Merry Xmas!
Can you point me to someplace that better explains millis and other C programming?
Ok hereoute] is what I did
long timeToRelock = millis();
timeToRelock = 0;if(millis() - timeToRelock > 0)
I put this before Void setup
But it now only reads a null card and won't read a valid card it justs reads it as a null card??
Ok I think I know what the problem is. Because it's reading a null before reading the card, millis is stoping it from reading the card number??
I think I'm going to give up! and just use it without the LCD or keypad! Because I really need this finished. I'm a quadraplegic bound to a wheelchair, which makes unlocking and opening my front door very difficult. At least with basic function I can use it and maybe keep working on the program.
There just isn't enough info on programming the Arduino unless you already have programming experience! Which is very frustrating, I wish there were classes for the Arduino in my area!!!! I have nothing to do all day but work on this and still I'm stumped aarrrrgggg!
Broken and defeated
SubMicro :-[
What you have done should not have affected the reading of an RFID card. Please post your code again, and I'll have a look.
Your right I went through and re did everything and now it reads very fast however it still isn't working properly now the lock stays high instead of low. I tried changing millis to 5000 but that just kept it low for 5 seconds on startup. heres the code.
#include <Keypad.h>
#define rxPin 19
#define txPin 18
#define ledpin 13long timeToRelock = 0;
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'#','0','*'}
Keypad kpd = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );#define ledpin 7
char code[20];
int val = 0;
int LOCK = 6;void setup()
Serial1.begin(9600); //open serial softwarepinMode(rxPin, INPUT); //set pin on arduino for receiving RFID data
}void loop()
val = 0;
bytesread = 0;
if (Serial1.available() > 0)
// read 12 digit codeval = Serial1.read();
if(val == 3)
}if(val != 2)
- timeToRelock = millis();*
- else*
- timeToRelock = 5000;*
- if(millis() - timeToRelock > 0)*
- char key = kpd.getKey();*
- if(key) // same as if(key != NO_KEY)*
- switch (key)*
- break;*
- case '#':*
- break;*
- default:*
{- if(strcmp(code, Red) == 0)*
- return 1;*
- else if(strcmp(code, Blue) == 0)*
- return 2;*
- else if(strcmp(code, Yellow) == 0)*
- return 3;*
- else if(strcmp(code, Card1) == 0)*
- return 4;*
- else if(strcmp(code, Card2) == 0)*
- return 5;*
- else*
- return 0;*
[/quote]
Also if you find the problem don't just post the fix please try to explain it to me if you have the time. I really want to learn this!
I'm still going to use the simple version until I get this working I post pics of the setup sometime after Xmas.
Thanx
SubMicro
// Lock the door (this should be done in setup, not here
// Check if the RFID tag was valid
// It was, so unlock the door
// Define when to relock the door (5 seconds after unlocking it)
timeToRelock = millis()[glow] + 5000[/glow];
// Tag was not valid. The time to relock the door is NOW
timeToRelock = [glow]millis(); // was 5000[/glow]
} // End of serial.available loop
[glow] // Move this outside of the Serial.available() loop.
// We want to lock the door regardless of whether
// or not there is Serial data available to read
// See if the door has been unlocked long enough
[/glow]
I added some comments to a portion of the code, and highlighted some changes that need to be made. I think the comments explain why the changes are needed. If something isn't clear, ask again.
ooo...useful info,thanks...
PaulS
Ok I tried what you suggested, but there still seems to be a problem. I sure it's something I'm missing but I can't figure it out.
The program continually prints a single digit in sequence when no card is near, and when a card is presented it reads it then right back to what it was doing.
#include <Keypad.h>
#define rxPin 19
#define txPin 18
#define ledpin 13
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'#','0','*'}
#define ledpin 7
char code[20];
int val = 0;
int bytesread = 0;
int tagCnt = 5;
int LOCK = 6;
val = 0;
bytesread = 0;
if(val == 3)
if(val != 2)
if(bytesread >= 12)
Serial.print(code[i]);
timeToRelock = millis() + 5000;
switch (key)
case '*':
case '#':
default:
return 1;
return 2;
return 3;
return 4;
return 5;
return 0;
What does the output look like? The serial output should show stuff like:
Tag: [xxxxxxxxxxx]
Tag number: x
x
The Tag: and Tag number: lines should only be printed when a tag is read. The x lines should only be printed when a key is pressed.
Add
Serial.print("Key pressed: ");
after the default: line in the switch statement, so we know for certain what the number means.
Now it prints "key pressed " with a number but it goes so fast I cant read it. Could this be because I don't have the keyboard hooked up right now?
It looks like you described but now with key pressed being printed constantly scrolling down it never stops
