Rfid based pulse oximeter checking for employees
Can any one help me? I'm new to Arduino ,my project is rfid (RC522) based SpO2 checking using MAX30100 for employees in this covid19.I am facing issue in my code.when I put rfid in loop and then max30100 code ,rfid works good,but oximeter reads only 0.when I put oximeter code first in void loop,it works well but rfid not read.please help to solve the issueIm new to Arduino
#include <SPI.h>
#include <MFRC522.h>
#include <MAX30100_PulseOximeter.h>
#define SS_PIN 10 //RX slave select
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#define Sec 1000
int level;
PulseOximeter pox;
uint32_t tsLastReport = 0;
byte card_ID[4]; //card UID size 4byte
byte Name1[4]={0x47,0x08,0x15,0x4F};//first UID card
byte Name2[4]={0x7A,0x9F,0x69,0x7F};//second UID card
int NumbCard[2];//this array content the number of cards. in my case i have just two cards.
int j=0;
int const RedLed=6;
int const GreenLed=5;
int const Buzzer=8;
const int trigPin = 5;
const int echoPin = 6;
long duration;
int distance;
String Name;//user name
long Number;//user number
int n ;//The number of card you want to detect (optional) void onBeat()
    pox.begin();
    display.begin(SSD1306_SWITCHCAPVCC, 0x3C);
    display.clearDisplay();
  display.display();
  display.setTextColor(WHITE); // or BLACK);
  display.setTextSize(2);
  display.setCursor(10,0);
  display.print(" NO LOVE ");
  display.display(); // Initialize serial communications with the PC
  SPI.begin();  // Init SPI bus
  mfrc522.PCD_Init(); // Init MFRC522 card
  Serial.println("CLEARSHEET");                 // clears starting at row 1
  Serial.println("LABEL,Date,Time,Name,Number");// make four columns (Date,Time,[Name:"user name"]line 48 & 52,[Number:"user number"]line 49 & 53)
  pinMode(RedLed,OUTPUT);
  pinMode(GreenLed,OUTPUT);
  pinMode(Buzzer,OUTPUT);
  pinMode(trigPin, OUTPUT);
  pinMode(echoPin, INPUT);
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  duration = pulseIn(echoPin, HIGH);
  distance = duration * 0.0340 / 2;
 // Serial.println("Distance");
  //Serial.println(distance);
  if (distance <= 15)
        digitalWrite(Buzzer,HIGH);
      delay(30);
      digitalWrite(Buzzer,LOW);
  //look for new card
   if ( ! mfrc522.PICC_IsNewCardPresent()) {
  return;//got to start of loop if there is no card present
 // Select one of the cards
 if ( ! mfrc522.PICC_ReadCardSerial()) {
  return;//if read card serial(0) returns 1, the uid struct contians the ID of the read card.
 for (byte i = 0; i < mfrc522.uid.size; i++) {
     card_ID[i]=mfrc522.uid.uidByte[i];
       if(card_ID[i]==Name1[i]){
       Name=" SRINATH ";//user name
       Number=18106096;
    display.setCursor(0,0);
    display.print(Name);
    display.display();
       j=0;//first number in the NumbCard array : NumbCard[j]
      else if(card_ID[i]==Name2[i]){
       Name=" UDHAYA ";
            onBeat();//user name
            delay(10000);
       Number=87654496;
               display.clearDisplay(); display.setTextColor(WHITE); // or BLACK);
    display.display();//user number
       j=1;//Second number in the NumbCard array : NumbCard[j]
      else{
          digitalWrite(GreenLed,LOW);
          digitalWrite(RedLed,HIGH);
          goto cont;//go directly to line 85
      if(NumbCard[j] == 1){//to check if the card already detect
      //if you want to use LCD
     // Serial.println("Already Exist");
      else{
      NumbCard[j] = 1;//put 1 in the NumbCard array : NumbCard[j]={1,1} to let the arduino know if the card was detecting
      n++;//(optional)
      Serial.print("DATA,DATE,TIME," + Name);//send the Name to excel
      Serial.print(",");
      Serial.println(Number); //send the Number to excel
      digitalWrite(GreenLed,HIGH);
      digitalWrite(RedLed,LOW);
      delay(30);
      Serial.println("SAVEWORKBOOKAS,Names/WorkNames");
cont:
delay(2000);
//if you want to close the Excel when all card had detected and save Excel file in Names Folder. in my case i have just 2 card (optional)
//if(n==2){
  //  Serial.println("FORCEEXCELQUIT");
void onBeat()
   if (!pox.begin()) {
Serial.println("FAILED");
display.setTextSize(1);
display.setTextColor(1);
display.setCursor(0, 0);
display.println("FAILED");
display.display();
for(;;);
else {
display.println("SUCCESS");
display.display();
Serial.println("SUCCESS");
onlevel();
void onlevel()
Serial.println("Beat!");
display.display();
    pox.update();
if (millis() - tsLastReport > Sec){}
Serial.print("Oxygen Percent:");
Serial.print(pox.getSpO2());
Serial.println("\n");
display.println("Spo2");
[color=#ffffff]display[/color][color=#ffffff].[/color][color=#ffffff]setTextSize[/color][color=#ffffff]([/color][color=#d8b100]1[/color][color=#ffffff])[/color][color=#ffffff];[/color]
[color=#ffffff]display[/color][color=#ffffff].[/color][color=#ffffff]setTextColor[/color][color=#ffffff]([/color][color=#d8b100]1[/color][color=#ffffff])[/color][color=#ffffff];[/color]
[color=#ffffff]display[/color][color=#ffffff].[/color][color=#ffffff]setCursor[/color][color=#ffffff]([/color][color=#d8b100]0[/color][color=#ffffff],[/color][color=#d8b100]30[/color][color=#ffffff])[/color][color=#ffffff];[/color]
[color=#ffffff]display[/color][color=#ffffff].[/color][color=#ffffff]println[/color][color=#ffffff]([/color][color=#ffffff]pox[/color][color=#ffffff].[/color][color=#ffffff]getSpO2[/color][color=#ffffff]([/color][color=#ffffff])[/color][color=#ffffff])[/color][color=#ffffff];[/color]
[color=#ffffff]display[/color][color=#ffffff].[/color][color=#ffffff]display[/color][color=#ffffff]([/color][color=#ffffff])[/color][color=#ffffff];[/color]
[color=#ffffff]tsLastReport[/color] [color=#2dbda4]=[/color] [color=#ffffff]millis[/color][color=#ffffff]([/color][color=#ffffff])[/color][color=#ffffff];[/color]
[color=#ffffff]}[/color]
I would suggest you work on getting rid of the delays, they are blocking your code. You can use the mills() function. A simple schematic may help validate things are connected correctly.
Non-blocking timing tutorials:
Several things at a time.
Beginner's guide to millis().
Blink without delay().
