RFID code
I still fairly new to electronics and the Arduino. I just got a Parallax RFID reader module and tags kit from Radio shack, and I can’t get the code to verify. I get a error for the “digitalWrite(2, LOW);” from the code below. please help I want to play with my new toys.
// RFID reader for Arduino
// Wiring version by BARRAGAN <http://people.interaction-ivrea.it/h.barragan>
// Modified for Arudino by djmatic
int  val = 0;
char code[10];
int bytesread = 0;
Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
 digitalWrite(2, LOW);                  // Activate the RFID reader
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
        Serial.println(code);            // print the TAG code
      bytesread = 0;
           delay(500);                       // wait for a second
// extra stuff
// digitalWrite(2, HIGH);             // deactivate RFID reader
int  val = 0;
char code[10];
int bytesread = 0;
void activateReader() {
      bytesread = 0;
      bytesread = 0;
Sorry, that was wrong - give this a whizz
int  val = 0;
char code[10];
int bytesread = 0;
      bytesread = 0;
      bytesread = 0;
OK, stupid question. on the RFID reader the pins are VCC, ENABLE, SOUT, GND
so, from the this page :
http://www.arduino.cc/playground/Learning/PRFID
it says the hook up:
Arduino RX to RFID TX
Arduino GND to RFID GND
Arduino Digital pin 2 to RFID enable
Arduino +5V to RFID Vcc pin
I take it the SOUT is the RFID TX pin ??
I don’t know what is going on. The code verifies and uploads to the board just fine. I put the tag in front of the reader and nothing happens.
here is the code i’m using:
int  val = 0;
char code[10];
int bytesread = 0;
      bytesread = 0;
      bytesread = 0;
Maybe i'm wrong but i think that if you are using the RX and TX (Arduino pins 0 and 1) then you can not use serial communication with the computer over the "usb" connection.
Do you know for sure that someone else have had the code you use working ?
The RX and TX pins are shared with the USB to serial interface so you are basically trying to do serial communications with two dirrerent devices at the same time over the same line, which i think is not possible.
If someone knows better let me know :-X
The code from post #4 was right. user error, i wired it up wrong. it's hard being me :-/
thanx for the help anyways
