Hello! I have some experience with arduino (sensors, motor control) and would like to control a guillotie-style door via rfid or nfd, eg: "../ All chickens inside then close door"
and also monitoring which chicken uses what nesting box (4 boxes), eg: "../ chicken X is in box1" . The center-on-center distance for each box is 16" (to assess possible interference issues).
Based on my initial research, I'm thinking that I'd have to use 1+4 (5 total: 1 for the door, 4 for the nesting boxes.) "sub" arduinos, each with a PN532 shield due to the difficulty of using multiple antenna's with one RFID card PLUS one "Master" arduino to collect the data from each sub.
I need to have rfid tag-specific data from each antenna collected to be transmitted via wifi and ideally, display on iphone.
My thought is that each arduino could transmit the tag data to a "master" arduino via wifi (or wired if easier), something like "SUB21:RFIDTAG001", and then the master arduino would transmit via wifi where the output could be formatted and displayed.
My questions are:
- Are the "subs" indeed required for each RFID data collection point(antenna)?
- Could I use independent PN532's only and route the output to just the master thereby negating the need for the sub arduino's?
- Am I under-appreciating the complexity of this project...or overcomplicating as there might be a selection of more efficient hardware/software options?
Thank-you for your feedback!
