Hi Everyone,
This is my first time posting on the forum, and I'm relatively new to using arduinos. This year for Halloween I'm modifying my Iron Man helmet to be wireless. I've been using this wonderful tutorial on instructable created by Honus to try and accomplish that: http://www.instructables.com/id/Animatronic-Iron-Man-Mk-III-suit/ . I've manage to make the wireless set up by having the rfid reader in my hand reading the tags which would be located at my finger tips. The signal would be sent through the xbee to another xbee located at my helmet. With the current code for the helmet, the helmet opens for 4 seconds, then closes again after you swipe the tag. This is the code:
#include "Servo.h" // include the servo library
Servo faceplateServo;
Servo chinServo;
int ledPin1 = 4; // control pin for LED eyes
int servoPin1 = 2; // control pin for face plate servo
int servoPin2 = 3; // control pin for chin
faceplateServo.attach(servoPin1); // attaches the servo on pin 2 to the servo object
chinServo.attach(servoPin2); // attaches the servo on pin 3 to the servo object
faceplateServo.write(30); // rotate face plate servo to 30 degrees
chinServo.write(95); // rotate chin servo to 95 degrees
pinMode(ledPin1, OUTPUT); // sets the LED pin as output
digitalWrite(ledPin1, HIGH); // turn on LED eyes
// look for a capital A over the serial port and turn off LED
if (Serial.available() > 0) {
if (Serial.read() == 'A') { // reads tag over XBee
digitalWrite(ledPin1, LOW); // turn off LED eyes
delay(500); // wait half a second
faceplateServo.write(95); // rotate the face plate servo to 95 degrees
chinServo.write(20); // rotate the chin servo to 20 degrees
delay(4000); // wait 4 seconds
chinServo.write(95); // rotate the chin servo to 95 degrees
faceplateServo.write(30); // rotate the face plate servo to 30 degrees
My question is; is there anyway to modify the code so that when I swipe the rfid tag the helmet opens and stays open. When I swipe the tag again, it will close and stay like that until I swipe it again?
Thanks everyone for reading.
As an added bonus here is me with my friends last year with our costumes:
