Hello,
Sorry I made you wait.
Since I couldn't receive any goods from the code earlier, I tried something different, and I found a post from Arduino where explains the RS232 conecction and code. So I remove the library "SoftwareSerial" and replicate this one with some minors changes.
#include <ctype.h>
byte rx = 6;
byte tx = 7;
byte NewVal;
char sx[14];
char nx[14];
int j = 0;
int limit = 0;
unsigned char commConfig[9] = { 0x0a, 0x00, 0x35, 0x01, 0x02, 0x04, 0x00, 0x01, 0x00 };
unsigned char commBaud[4] = { 0x05, 0x00, 0x28, 0x00 };
unsigned char commAdd[4] = { 0x05, 0x00, 0x24, 0xFF };
//Serial.println(crc_cal(commAdd,4), HEX);
pinMode(rx, INPUT);
pinMode(tx, OUTPUT);
digitalWrite(tx, HIGH);
delay(2);
sendInfo();
//sendConfig();
//sendBaudRate();
//sendAddress();
void WriteFunc(int data) {
byte mask;
digitalWrite(tx, LOW);
delayMicroseconds(100);
for (mask = 0x01; mask > 0; mask <<= 1) {
if (data & mask) {
else {
int Read2Bin() {
byte val = 0;
while (digitalRead(rx));
if (digitalRead(rx) == LOW) {
delayMicroseconds(50);
for (int i = 0; i < 8; i++) {
val |= digitalRead(rx) << i;
return val;
NewVal = Read2Bin();
sx[j] = NewVal;
if (j == 0) {
limit = sx[j];
j++;
if (j >= limit + 1) {
for (j = 0; j <= limit ; j++) {
nx[j] = sx[j] & 0xFF;
Serial.print(nx[j], HEX);
Serial.print(" ");
Serial.println("");
j = 0;
And It worked!!!
I got the result expected, still...I'm not really sure why it didn't work with Software Serial.
Now the issue seems that some unnexpected values are getting printed.
The result I printed is:
D 0 21 0 3 3F 9 3 3E 0 1E A FFFFFFC6 FFFFFFAA
The result I expect is:
D 0 21 0 3 3F 9 3 3E 0 1E A C6 AA
So those FFFFFF are messing me up. I dont know where they come from.
