RFID Door Lock System plus Temperature Scanning System
Electronics Student Here!
I am planning to make a door lock system with a temperature scanning system project. I have a few concerns with this project:
  1. Can I use one 16x2 LCD module to display the temperature scanned and the status of the scanned RFID (like "Door Opened" and "Access Denied")?
  2. Can I use one RGB LED on both systems?
  3. Can I use one Arduino module? Is it possible to be programmed together?
My overall problem is should I make this project work as one system or should I separate them?
Please give me some advice.
  1. probably
  2. not engough information.
  3. a) not enough information. b) what does that mean?
I'm sure the answer to all your questions 1-3 is "yes" from a technical point. But does it make logical sense for them to co-exist, let's say from a user experience point of view?
For example using one rgb led (q2) to indicate two un-related conditions might not be very good for the user. If you wanted the user to know that (say) the door was unlocked and the temperature was over limit, two separate red leds might be more valuable.
So to me, that depends how related or separate the things are in your and your users' minds.
@RFID door lock: The RGB is supposed to light up 'red' when access is denied and 'green' when the door is opened.
@temperature Scanner: The RGB is supposed to light up 'red' when the temperature is high, 'green' when the temperature is normal and 'orange' when the temperature is slightly high.
That's exactly my point... you could technically use the red of the rgb to mean two different things, but that's a crap user interface.
Okay, so using two RGBs is better. How about the LCD since the two systems have different purposes, can I use only one for both of them?
What I mean is can I connect all of the needed parts for the door lock system and the temperature scanner on one Arduino module? BUT, connecting them in one Arduino means I have to code them to function as one system right (like one program code for both systems). Will that work?
You can, sure. (Or I should say, "almost certainly" without knowing the exact details.) And since a screen is quite expensive you would probably want to save some money and not have two. I suppose you could have the top line for the door and the bottom for the temperature. Only you can say if that's ok from a user experience point of view though, technicalities aside.
Check out the planning an Arduino project and doing more than one thing at a time threads in the stickies at the top of the forum.
If doing this is possible then I will opt to use one LCD because this is only a project for one of my subjects. Thank you for explaining.
If during development you find you need two, you can always buy another one! But don't spend double the money until you know it's worth it....
Read these links @miyukiharuto:
Planning a project
Several things at once
Yes. One MCU can do more than one thing.
I have an ESp32 doing WiFi stuff and measuring stuff and displaying stuff and even calculates data sent from another ESP and sends the calculated data off to another ESP. All on one ESP32.
Why just look at all the different things going on.
  https://github.com/G6EJD/ESP32-e-Paper-Weather-Display/blob/master/examples/Waveshare_4_2/Waveshare_4_2.ino
  Stole some code from that guy.
#include "MyBitmap.h"
#include <WiFi.h>
#include <PubSubClient.h>
#include "certs.h"
#include "sdkconfig.h"
#include "esp_system.h"
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include "Adafruit_BME680.h"
#include <GxEPD2_BW.h>
#include <U8g2_for_Adafruit_GFX.h> // Select u8g2 font from here: https://github.com/olikraus/u8g2/wiki/fntlistall
#include <Fonts/FreeMonoBold9pt7b.h> //https://learn.adafruit.com/adafruit-gfx-graphics-library/using-fonts
#include <Fonts/FreeMono9pt7b.h>
#include <HardwareSerial.h>
#include <SimpleKalmanFilter.h>
#include "MHZ19.h"
#include <ESP32Time.h>
#include <SolarCalculator.h>
ESP32Time rtc;
MHZ19 myMHZ19;
GxEPD2_BW<GxEPD2_420, GxEPD2_420::HEIGHT> display(GxEPD2_420(/*CS=5*/ SS, /*DC=*/ 17, /*RST=*/ 16, /*BUSY=*/ 4)); // GDEW042T2
Adafruit_BME680 bme( GPIO_NUM_15 );
WiFiClient   wifiClient; // do the WiFi instantiation thing
PubSubClient MQTTclient( mqtt_server, mqtt_port, wifiClient );
U8G2_FOR_ADAFRUIT_GFX u8g2Fonts;
#define evtStoreAirPressure   ( 1 << 0 )
#define evtWaitForBME         ( 1 << 1 )
#define evtParseMQTT          ( 1 << 3 )
#define evtDisplayUpdate      ( 1 << 4 )
#define evtDoBME              ( 1 << 5 )
#define evtDewPoint           ( 1 << 6 )
#define OneMinuteGroup ( evtDoBME )
EventGroupHandle_t eg;
QueueHandle_t xQ_WindChillDewPoint;
QueueHandle_t xQ_eData;
struct stu_eData
  float  oTemperature = 0.0f;
  float  oHumidity    = 0.0f;
  float  oPressure    = 0.0f;
  float  Temperature  = 0.0f;
  float  Pressure    = 0.0f;
  float  Humidity    = 0.0f;
  float  IAQ         = 0.0f; // Index Air Quality
  float  RM0         = 0.0f; // Remaining Moisture from sensor 0
  //float  PM2         = 0.0f; // particles in air
  float  WS          = 0.0f; // wind speed
  String WD          = "";   // wind direction
  float  RF          = 0.0f; // rainfall
  //float  WSV         = 0.0f; // weather station volts
  //float  WSC         = 0.0f; // weather station current
  //float  WSP         = 0.0f; // weather station power
  float  WindChill   = 0.0f; //windchill
  float  DewPoint    = 0.0f; //dew point or dew index
  int    SunRiseHr   = 0;    // sunrise hour
  int    SunRiseMin  = 0;    //sunrise minute
  int    SunSetHr    = 0;    //sunset hour
  int    SunSetMin   = 0;    //sunset minute
  int    DuskHr      = 0;    //dusk
  int    DuskMin     = 0;    //dusk
  int    DawnHr      = 0;    // dawn
  int    DawnMin     = 0;    // dawn
  int    TransitHr   = 0;    // 'noon' time
  int    TransitMin  = 0;    // 'noon' time
  double azimuth     = 0.0f;   // Sun's azimuth, in degrees
  double elevation   = 0.0f;     // Sun's elevation, in degrees
  float  CO2         = 0.0f;
  float  PressureH   = 0.0f;
  float  PressureL   = 10000.0f;
  int    cngPress    = 0; // pressure change 0= no change, -1 slow change +1 fast change
} x_eData; // environmental data
QueueHandle_t xQ_Message; // payload and topic queue of MQTT payload and topic
const int payloadSize = 100;
struct stu_message
  char payload [payloadSize] = {'\0'};
  String topic ;
} x_message;
const float oGasResistanceBaseLine = 149598.0f;
int mqttOK = 0;
volatile bool TimeSet = false;
const int BufferCount = 60;
float CollectionPressure[BufferCount] = {0.0f};
boolean LargeIcon = true, SmallIcon = false;
//bool CollectionDone = false;
#define Large  11           // For icon drawing, needs to be odd number for best effect
#define Small  5            // For icon drawing, needs to be odd number for best effect
enum alignment {LEFT, RIGHT, CENTER};
SemaphoreHandle_t sema_MQTT_KeepAlive;
SemaphoreHandle_t sema_PublishPM;
SemaphoreHandle_t sema_mqttOK;
SemaphoreHandle_t sema_CollectPressure;
SemaphoreHandle_t sema_eData;
//serial(2) = pin25 RX, pin26 TX
HardwareSerial co2Serial ( 2 );
void IRAM_ATTR onTimer()
  BaseType_t xHigherPriorityTaskWoken;
  xEventGroupSetBitsFromISR(eg, OneMinuteGroup, &xHigherPriorityTaskWoken);
} // void IRAM_ATTR onTimer()
// interrupt service routine for WiFi events put into IRAM
void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
  switch (event) {
    default: break;
} // void IRAM_ATTR WiFiEvent(WiFiEvent_t event)
void IRAM_ATTR mqttCallback(char* topic, byte * payload, unsigned int length)
  memset( x_message.payload, '\0', payloadSize ); // clear payload char buffer
  x_message.topic = ""; //clear topic string buffer
  x_message.topic.concat( topic ); //store new topic
  int i = 0; // extract payload
  for ( i; i < length; i++)
    x_message.payload[i] = ((char)payload[i]);
  x_message.payload[i] = '\0';
  xQueueOverwrite( xQ_Message, (void *) &x_message );// send data to queue
} // void mqttCallback(char* topic, byte* payload, unsigned int length)
  // hardware timer 4 set for one minute alarm
  hw_timer_t * timer = NULL;
  timer = timerBegin( 3, 80, true );
  timerAttachInterrupt( timer, &onTimer, true );
  timerAlarmWrite(timer, 60000000, true);
  timerAlarmEnable(timer);
  co2Serial.begin( 9600 , SERIAL_8N1, 25, 26 ); // pin25 RX, pin26 TX
  x_eData.WD.reserve(50);
  x_message.topic.reserve( payloadSize );
  xQ_WindChillDewPoint = xQueueCreate( 1, sizeof(stu_eData) );
  xQ_Message  = xQueueCreate( 1, sizeof(stu_message) );
  xQ_eData    = xQueueCreate( 1, sizeof(stu_eData) ); // sends a queue copy of the structure
  sema_PublishPM = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_PublishPM );
  sema_mqttOK    =  xSemaphoreCreateBinary();
  xSemaphoreGive( sema_mqttOK );
  sema_CollectPressure = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_CollectPressure );
  sema_eData = xSemaphoreCreateBinary();
  xSemaphoreGive ( sema_eData );
  eg = xEventGroupCreate(); // get an event group handle
  xTaskCreatePinnedToCore( fparseMQTT, "fparseMQTT", 7000,  NULL, 5, NULL, 1 );
  xTaskCreatePinnedToCore( MQTTkeepalive, "MQTTkeepalive", 5000, NULL, 6, NULL, 1 );
  xTaskCreatePinnedToCore( DoTheBME680Thing, "DoTheBME280Thing", 20000, NULL, 5, NULL, 1);
  xTaskCreatePinnedToCore( fmqttWatchDog, "fmqttWatchDog", 5000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fDoTheDisplayThing, "fDoTheDisplayThing", 30000, NULL, 3, NULL, 1 );
  xTaskCreatePinnedToCore( fGetCO2, "fGetCO2", 4500, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fParseDewPointWindChill, "fParseDewPointWindChill", 4500, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fSolarCalculations, "fSolarCalculations", 10000, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fProcessAirPressure, "fProcessAirPressure", 5000, NULL, 2, NULL, 1 );
  xTaskCreatePinnedToCore( fFindDewPointWithHumidity, "fFindDewPointWithHumidity", 5000, NULL, 2, NULL, 1 );
} //void setup()
void fFindDewPointWithHumidity( void *pvParameters )
  float temperature = 0.0f;
  for ( ;; )
    xEventGroupWaitBits (eg, evtDewPoint, pdTRUE, pdTRUE, portMAX_DELAY );
    temperature = (x_eData.oTemperature - 32) / 1.8f; // Celsius (°C) = (Fahrenheit - 32) / 1.8  convert to C
    xSemaphoreTake( sema_eData, portMAX_DELAY );
    x_eData.DewPoint = log(x_eData.oHumidity / 100) + (17.62 * temperature) / (243.12 + temperature);
    x_eData.DewPoint =  243.12 * x_eData.DewPoint / (17.62 - x_eData.DewPoint);
    x_eData.DewPoint = (x_eData.DewPoint * 1.8f) + 32.0f; // convert back to F
  vTaskDelete( NULL );
String PressureRateOfChange ()
  String s = "";
  s.reserve( 10 );
  xSemaphoreTake ( sema_eData, portMAX_DELAY );
  switch ( x_eData.cngPress )
    case 0:
      s = "Slow";
    case 1:
      s = "Unsettled";
    case 2:
      s = "Fast";
    case 3:
      s = "Steady";
  return s;
   Approaching storms and wind cause barometric pressure to decrease.
   Rising pressure indicates fair weather.
   The longer it takes barometric pressure to change,
   the longer the coming weather pattern can be expected to last.
   It is possible that a small weather event, such as a passing shower, may trigger no change in barometric pressure.
   slow rate of change .0762mmHg - 1.016mmHg < 3 hours
   fast rate of change 4.572mmHg in < 3 hours
   steady <=.0762Hg in <= 3 hours
int CalculatePressureFactors( float pastPressure, float currentPressure )
  float rateChange = abs(pastPressure - currentPressure);
  //log_i ( " pressure rate of change %f", rateChange );
  if ( (rateChange >= .0762f) && (rateChange <= 1.016f ) )
    //log_i( "slow %f", rateChange );
    return 0; //slow
  if ( (rateChange > 1.016f) && (rateChange < 4.572f) )
    //log_i( "unsettled %f", rateChange );
    return 1;
  if ( rateChange >= 4.572f )
    //log_i( "fast %f", rateChange );
    return 2;//fast
  if ( rateChange <= .0762 )
    //log_i( "steady %f", rateChange );
    return 3;//steady
} //void CalculatePressureFactors()
void fProcessAirPressure ( void *pvParemeters )
  int   Ticks     = 118; // Tick counter
  bool  Filled    = false; // array has been filled before?
  float *ptr      = CollectionPressure; // pointer to the array
  const int ticksTrigger = 120; // triggered at 1 minute intervals
  for (;;)
    //triggered by BME which is triggered by the 1 minute hardware timer.
    xEventGroupWaitBits (eg, evtStoreAirPressure, pdTRUE, pdTRUE, portMAX_DELAY );
    xSemaphoreTake( sema_CollectPressure, portMAX_DELAY );
    if ( !Filled )
      //if array has not been filled before, fill array with the same base value
      for ( int j = 0; j < BufferCount; j++ )
        *( ptr + j ) = x_eData.oPressure;
      Filled = true;// array has been initially filled
      if ( Ticks == ticksTrigger )
        //when tick counter reaches the trigger level
        //shift contents left and insert new value at the end
        for ( int i = 0; i <= BufferCount - 2; i++ )
          *( ptr + i ) = *( ptr + (i + 1) );
      *( ptr + (BufferCount - 1) ) = x_eData.oPressure;//new value to be inserted
    // find and store highest and lowest value
    if ( x_eData.oPressure > x_eData.PressureH )
      x_eData.PressureH = x_eData.oPressure;
    if ( x_eData.oPressure < x_eData.PressureL )
      x_eData.PressureL = x_eData.oPressure;
    Ticks++;
    if ( Ticks > ticksTrigger )
      Ticks = 1;
    //log_i( "ticks %d" , Ticks );
    x_eData.cngPress = CalculatePressureFactors(  *( ptr + 57), *( ptr + 59) ); // going back 4 hours
    xSemaphoreGive( sema_eData );
    //log_i( " high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  } //for (;;)
} //void fStoreAirPressure ( void *pvParemeters )
void fSolarCalculations ( void *pvParameters )
  double sunrise;  // Sunrise, in hours (UTC)
  double transit;  // Solar noon, in hours (UTC)
  double sunset;   // Sunset, in hours (UTC)
  double dawn;     // Civil dawn, in hours (UTC)
  double dusk;     // Civil dusk, in hours (UTC)
  //double rt_ascension;  // Sun's right ascension, in degrees
  //double declination;   // Sun's declination, in degrees
  const  float time_zone = -7.0f;
  TickType_t xLastWakeTime = xTaskGetTickCount();
  const TickType_t xFrequency = 1000; //delay for mS
  int count  = 3590;
  int monthX = 1;
  int dayX   = 1;
  for (;;)
    if ( count % 60 == 0 )
      if ( (rtc.getHour(true) >= 12) & (rtc.getHour(true) <= 23) )
        dayX = 0;
        dayX = 1;
      calcSunriseSunset( rtc.getYear(), (rtc.getMonth() + monthX) , (rtc.getDay() + dayX), latitude, longitude, transit, sunrise, sunset );  // Calculate the times of sunrise, transit and sunset
      sunrise += time_zone;
      sunset  += time_zone;
      SolarTimeFormat( sunrise, 0 );
      SolarTimeFormat( sunset, 1 );
      calcCivilDawnDusk( rtc.getYear(), (rtc.getMonth() + monthX) , rtc.getDay(), latitude, longitude, transit, dawn, dusk); // Calculate the times of civil dawn and dusk (UTC)
      transit += time_zone;
      dawn    += time_zone;
      dusk    += time_zone;
      SolarTimeFormat( dawn, 2 );
      SolarTimeFormat( dusk, 3 );
      SolarTimeFormat( transit, 4 );
      calcHorizontalCoordinates( rtc.getYear(), (rtc.getMonth() + monthX) , rtc.getDay(),  rtc.getHour(true) , rtc.getMinute(), rtc.getSecond(), latitude, longitude, x_eData.azimuth, x_eData.elevation );
      if (count >= 3600 )
        SolarTimeFormat( 0.0f, 5 ); // publish MQTT
        //log_i( "Hour:%d Azimuth %f, elevation %f, transit %dhr %dmin, dawn %dhr %dmin, dusk %dhr %dmin", rtc.getHour(true), x_eData.azimuth, x_eData.elevation, x_eData.TransitHr, x_eData.TransitMin, x_eData.DawnHr, x_eData.DawnMin, x_eData.DuskHr, x_eData.DuskMin );
        count = 0;
    vTaskDelayUntil( &xLastWakeTime, xFrequency );
    count++;
  } //for (;;)
} //void fSolarCalculations ( )
void SolarTimeFormat( double h, int i  )
  int hours   = 0;
  int minutes = 0;
  if ( h != 0.0f )
    int m = int(round(h * 60));
    hours = (m / 60) % 24;
    minutes = m % 60;
  switch ( i )
    case 0:
      x_eData.SunRiseHr = hours;
      x_eData.SunRiseMin = minutes;
    case 1:
      x_eData.SunSetHr = hours;
      x_eData.SunSetMin = minutes;
    case 2:
      x_eData.DawnHr = hours;
      x_eData.DawnMin = minutes;
    case 3:
      x_eData.DuskHr = hours;
    case 4:
      x_eData.TransitHr = hours;
      x_eData.TransitMin = minutes;
    case 5:
      struct stu_eData px_eData = x_eData;
      String sTopic = "";
      sTopic.reserve( 35 );
      sTopic.concat( String(px_eData.SunRiseHr) + "," );
      sTopic.concat( String(px_eData.SunRiseMin) + "," );
      sTopic.concat( String(px_eData.SunSetHr) + "," );
      sTopic.concat( String(px_eData.SunSetMin) + "," );
      sTopic.concat( String(px_eData.DawnHr) + "," );
      sTopic.concat( String(px_eData.DawnMin) + "," );
      sTopic.concat( String(px_eData.TransitHr) + "," );
      sTopic.concat( String(px_eData.TransitMin) );
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY );
      MQTTclient.publish( topicSRSSDDT, sTopic.c_str() );
      xSemaphoreGive( sema_MQTT_KeepAlive );
      sTopic = "";
      px_eData.azimuth   = double(round(px_eData.azimuth * 100)) / 100; // Round to two decimal places
      px_eData.elevation = double(round(px_eData.elevation * 100)) / 100;
      sTopic.concat( String(px_eData.azimuth) + "," + String(px_eData.elevation) );
      MQTTclient.publish( topicAzEle, sTopic.c_str() );
      sTopic = "";
  } // switch ( i ) {
} // void SolarTimeFormat( double h, int i  )
  250-400ppm Normal background concentration in outdoor ambient air
  400-1,000ppm  Concentrations typical of occupied indoor spaces with good air exchange
  1,000-2,000ppm  Complaints of drowsiness and poor air.
  2,000-5,000 ppm Headaches, sleepiness and stagnant, stale, stuffy air. Poor concentration, loss of attention, increased heart rate and slight nausea may also be present.
  5,000 Workplace exposure limit (as 8-hour TWA) in most jurisdictions.
  >40,000 ppm Exposure may lead to serious oxygen deprivation resulting in permanent brain damage, coma, even death.
void fParseDewPointWindChill( void *pvParameters )
  while ( !MQTTclient.connected() )
    vTaskDelay( 250 );
  struct stu_message px_message;
  String sDewPoint = "";
  String sWindChill = "";
  sDewPoint.reserve( payloadSize );
  sWindChill.reserve( payloadSize );
  for (;;)
    if ( xQueueReceive(xQ_WindChillDewPoint, &px_message, portMAX_DELAY) == pdTRUE )
      sDewPoint = px_message.payload;
      int commaIndex = sDewPoint.indexOf(',');
      sWindChill.concat ( sDewPoint.substring(0, commaIndex) );
      sDewPoint.remove( 0, (commaIndex + 1) );
      x_eData.WindChill = sWindChill.toFloat();
      xEventGroupSetBits( eg, evtDewPoint );
      sDewPoint = "";
      sWindChill = "";
void fGetCO2 ( void *pvParameters )
  uint64_t TimePastKalman  = esp_timer_get_time();
  myMHZ19.begin( co2Serial );
  myMHZ19.autoCalibration();
  SimpleKalmanFilter KF_CO2( 1.0f, 1.0f, .01f );
  float temp = 0.0f;
  for ( ;; )
    KF_CO2.setProcessNoise( (esp_timer_get_time() - TimePastKalman) / 1000000.0f );
    temp = KF_CO2.updateEstimate( myMHZ19.getCO2() ); // apply simple Kalman filter
    temp = round(temp);
    x_eData.CO2 = temp;
    MQTTclient.publish( topicCO2, String(temp).c_str() );
} //void fMHZ19B ( void *pvParameters )
void fparseMQTT( void *pvParameters )
  for (;;)
    if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
      xSemaphoreTake( sema_mqttOK, portMAX_DELAY );
      mqttOK = 0;
      if (px_message.topic == topicAQIndex )
      if ( px_message.topic == topicOutsidePressure )
        x_eData.oPressure = String(px_message.payload).toFloat();
      if ( px_message.topic == topicOutsideHumidity )
        x_eData.oHumidity = String(px_message.payload).toFloat();
      if ( px_message.topic == topicOutsideTemperature )
        x_eData.oTemperature = String(px_message.payload).toFloat();
      if ( px_message.topic == topicRemainingMoisture_0 )
        x_eData.RM0  = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindSpeed )
        x_eData.WS = String(px_message.payload).toFloat();
      if ( px_message.topic == topicWindDirection )
        x_eData.WD = "";
        x_eData.WD = String(px_message.payload);
      if ( px_message.topic == topicRainfall )
        x_eData.RF = String(px_message.payload).toFloat();
      //      if ( px_message.topic == topicWSVolts )
      //        x_eData.WSV = String(px_message.payload).toFloat();
      //      if ( px_message.topic == topicWSCurrent )
      //        x_eData.WSC = String(px_message.payload).toFloat();
      //      if ( px_message.topic == topicWSPower )
      //        x_eData.WSP = String(px_message.payload).toFloat();
      if ( px_message.topic == topicDPnWI )
        xQueueSend( xQ_WindChillDewPoint, (void *) &px_message, 1 );
      if ( String(px_message.topic) == topicOK )
        if ( !TimeSet)
          String temp = "";
          temp.reserve(50);
          temp.concat( String(px_message.payload[0]) );
          temp.concat( String(px_message.payload[1]) );
          temp.concat( String(px_message.payload[2]) );
          temp.concat( String(px_message.payload[3]) );
          int year =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[5]) + String(px_message.payload[6]) );
          int month =  temp.toInt();
          temp =  "";
          temp.concat(String(px_message.payload[8]) + String(px_message.payload[9]) );
          int day =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[11]) + String(px_message.payload[12]) );
          int hour =  temp.toInt();
          temp = "";
          temp.concat( String(px_message.payload[14]) + String(px_message.payload[15]) );
          int min =  temp.toInt();
          rtc.setTime( 0, min, hour, day, month, year );
          log_i( "rtc  %s Year %d month %d day %d", rtc.getTime(), rtc.getYear(), (rtc.getMonth() + 1), rtc.getDay() );
          TimeSet = true;
    } //if ( xQueueReceive(xQ_Message, &px_message, portMAX_DELAY) == pdTRUE )
  } //for(;;)
} // void fparseMQTT( void *pvParameters )
void fDoTheDisplayThing( void * parameter )
  int yIncrement = 18;
  int CurrentY = 20;
  int CurrentX = 5;
  String temp1 = "";
  temp1.reserve(10);
  String temp2 = "";
  temp2.reserve(10);
  int boxSpacing = 80;
  size_t item_size;
  for (;;)
    xEventGroupWaitBits (eg, evtDisplayUpdate, pdTRUE, pdTRUE, portMAX_DELAY );
    CurrentY = 20;
    display.init();
    //display.setFont(&FreeMonoBold9pt7b);
    display.setFont(&FreeMono9pt7b);
    //u8g2Fonts.setFont(u8g2_font_helvB08_tf);
    display.setTextColor(GxEPD_BLACK);
    display.setFullWindow();
    display.fillScreen(GxEPD_WHITE); // set the background to white (fill the buffer with value for white)
    display.setCursor( CurrentX, CurrentY );
    // first line
    display.drawRect( CurrentX, CurrentY , 70, 55, GxEPD_BLACK);
    display.drawBitmap( CurrentX + 10, CurrentY + 5, temperature_icon16x16, 16, 16, GxEPD_BLACK);
    display.setCursor( CurrentX + 30, CurrentY + 15 );
    //display.print( char(223) + "F" );
    display.print( "F" );
    display.setCursor( CurrentX + 10, CurrentY + 40);
    display.print( String(px_eData.oTemperature) );
    display.drawRect( CurrentX + boxSpacing, CurrentY , 70, 55, GxEPD_BLACK);
    display.setCursor( CurrentX + 90, CurrentY + 15 );
    display.print( "R.H.");
    display.setCursor( CurrentX + 90, CurrentY + 35 );
    display.print( String((int)px_eData.oHumidity) + "%" );
    display.setCursor( CurrentX, CurrentY + 40);
    display.drawRect( CurrentX + (boxSpacing * 2 ), CurrentY , 70, 55, GxEPD_BLACK);
    display.setCursor( CurrentX + 163, CurrentY + 15 );
    display.print( "Dew Pt" );
    display.setCursor( CurrentX + 165, CurrentY + 35 );
    display.print( String(px_eData.DewPoint) );
    display.drawRect( CurrentX + (boxSpacing * 3 ), CurrentY , 70, 55, GxEPD_BLACK);
    display.setCursor( CurrentX + 246, CurrentY + 15 );
    display.print( "AQI" );
    display.setCursor( CurrentX + 246, CurrentY + 35 );
    display.print( String(int(px_eData.IAQ)) + "%" );
    display.drawRect( CurrentX + (boxSpacing * 4 ), CurrentY , 70, 55, GxEPD_BLACK);
    display.setCursor( CurrentX + 327, CurrentY + 15 );
    display.print( "R.M." );
    display.setCursor( CurrentX + 327, CurrentY + 35 );
    display.print( String(int(px_eData.RM0)) + "%" );
    // end of first line
    if ( px_eData.SunRiseMin < 10 )
      temp1.concat( "0" + String(px_eData.SunRiseMin) );
      temp1.concat( String(px_eData.SunRiseMin) );
    if ( px_eData.SunSetMin < 10 )
      temp2.concat( "0" + String(px_eData.SunSetMin) );
      temp2.concat( String(px_eData.SunSetMin) );
    CurrentY += yIncrement;
    display.print( "Wind: " );
    display.print( "Speed " + String(px_eData.WS) + "KPH, Dir " + String(px_eData.WD) + " Chill " + String(px_eData.WindChill) + "F" );
    addsun( 35, CurrentY + 30 , Small, SmallIcon );
    display.setCursor( CurrentX + 5, CurrentY + 15 );
    display.print( "0" + String(px_eData.SunRiseHr) + ":" + temp1 );
    display.setCursor( CurrentX + 5, CurrentY + 50 );
    display.print( String(px_eData.SunSetHr) + ":" + temp2 );
    addraindrop(CurrentX + 110, CurrentY + 15, 7);
    display.print( String(px_eData.RF) );
    display.setCursor( CurrentX + 100, CurrentY + 50 );
    display.print( "mm" );
    display.setCursor( CurrentX + 177, CurrentY + 15 );
    display.print( "C02" );
    display.print( String(int(px_eData.CO2)) );
    display.setCursor( CurrentX + 165, CurrentY + 50 );
    display.print( "PPM" );
    //make graph
    CurrentY += yIncrement * 6;
    display.setCursor( CurrentX, CurrentY); //set cursor position
    //display.drawLine( CurrentX, CurrentY, CurrentX + 200, CurrentY, GxEPD_BLACK);
    //int BaseLine = (int)CollectionPressure[0];
    int BaseLine = (int) * ptr;
    int offsetX = 0;
      if ( *(ptr + j) != 0.0f )
        int yAdj = BaseLine - (int) * (ptr + j);
        display.setCursor( CurrentX + offsetX, CurrentY + yAdj );
        display.print( "-" );
        offsetX += 5;
        // log_i( "pressure %f item %d", CollectionPressure[j], j );
    display.print( String(px_eData.oPressure) + "mmHg" );
    int Xone = 48;
    int Yone = 59;
    display.print( PressureRateOfChange() );
    temp2 = "";
    temp1 = "";
    display.display(false); // full update
    display.hibernate();
    //log_i( "DoTheBME280Thing high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  } //for (;;)
} //void fDoTheDisplayTHing( void * parameter )
void fmqttWatchDog( void * paramater )
  int UpdateImeTrigger = 86400; //seconds in a day
  int UpdateTimeInterval = 86300; // 1st time update in 100 counts
  int maxNonMQTTresponse = 120;
  for (;;)
    vTaskDelay( 1000 );
    if ( mqttOK >= maxNonMQTTresponse )
      ESP.restart();
    mqttOK++;
    UpdateTimeInterval++; // trigger new time get
    if ( UpdateTimeInterval >= UpdateImeTrigger )
      TimeSet = false; // sets doneTime to false to get an updated time after a days count of seconds
      UpdateTimeInterval = 0;
float fCalulate_IAQ_Index( int gasResistance, float Humidity)
  float hum_baseline = 40.0f;
  float hum_weighting = 0.25f;
  float gas_offset = 0.0f;
  float hum_offset = 0.0f;
  float hum_score = 0.0f;
  float gas_score = 0.0f;
  gas_offset = oGasResistanceBaseLine - float( gasResistance );
  hum_offset = float( Humidity ) - hum_baseline;
  // calculate hum_score as distance from hum_baseline
  if ( hum_offset > 0.0f )
    hum_score = 100.0f - hum_baseline - hum_offset;
    hum_score /= ( 100.0f - hum_baseline );
    hum_score *= ( hum_weighting * 100.0f );
    hum_score = hum_baseline + hum_offset;
    hum_score /= hum_baseline;
    hum_score *= ( 100.0f - (hum_weighting * 100.0f) );
  //calculate gas score as distance from baseline
  if ( gas_offset > 0.0f )
    gas_score = float( gasResistance ) / oGasResistanceBaseLine;
    gas_score *= ( 100.0f - (hum_weighting * 100.0f ) );
    gas_score = 100.0f - ( hum_weighting * 100.0f );
  return ( hum_score + gas_score );
} //void fCalulate_IAQ_Index( int gasResistance, float Humidity):
void DoTheBME680Thing( void *pvParameters )
  SPI.begin(); // initialize the SPI library
  vTaskDelay( 10 );
  if (!bme.begin()) {
    log_i("Could not find a valid BME680 sensor, check wiring!");
    while (1);
  // Set up oversampling and filter initialization
  bme.setTemperatureOversampling(BME680_OS_8X);
  bme.setHumidityOversampling(BME680_OS_2X);
  bme.setPressureOversampling(BME680_OS_4X);
  bme.setIIRFilterSize(BME680_FILTER_SIZE_3);
  bme.setGasHeater(320, 150); // 320*C for 150 ms
  //wait for a mqtt connection
    vTaskDelay( 250 );
  xEventGroupSetBits( eg, evtWaitForBME );
  String bmeInfo = "";
  bmeInfo.reserve( 100 );
  for (;;)
    xEventGroupWaitBits (eg, evtDoBME, pdTRUE, pdTRUE, portMAX_DELAY );
    x_eData.Temperature  = bme.readTemperature();
    x_eData.Temperature  = ( x_eData.Temperature * 1.8f ) + 32.0f; // (Celsius x 1.8) + 32
    x_eData.Pressure     = bme.readPressure();
    x_eData.Pressure     = x_eData.Pressure / 133.3223684f; //converts to mmHg
    x_eData.Humidity     = bme.readHumidity();
    x_eData.IAQ          = fCalulate_IAQ_Index( bme.readGas(), x_eData.Humidity );
    bmeInfo.concat( String(x_eData.Temperature, 2) );
    bmeInfo.concat( "," );
    bmeInfo.concat( String(x_eData.Pressure, 2) );
    bmeInfo.concat( String(x_eData.Humidity, 2) );
    bmeInfo.concat( String(x_eData.IAQ, 2) );
    if ( MQTTclient.connected() )
      MQTTclient.publish( topicInsideInfo, bmeInfo.c_str() );
    xSemaphoreGive( sema_PublishPM ); // release publish of dust density
    mqttOK ++;
    bmeInfo = ""; // empty the string buffer
    xEventGroupSetBits( eg, evtStoreAirPressure );
    vTaskDelay( 50 );
    xEventGroupSetBits( eg, evtDisplayUpdate );
    // log_i( "DoTheBME280Thing high watermark % d",  uxTaskGetStackHighWaterMark( NULL ) );
  vTaskDelete ( NULL );
  Important to not set vTaskDelay/vTaskDelayUntil to less then 10. Errors begin to develop with the MQTT and network connection.
  makes the initial wifi/mqtt connection and works to keeps those connections open.
void MQTTkeepalive( void *pvParameters )
  sema_MQTT_KeepAlive   = xSemaphoreCreateBinary();
  xSemaphoreGive( sema_MQTT_KeepAlive ); // found keep alive can mess with a publish, stop keep alive during publish
  MQTTclient.setKeepAlive( 90 ); // setting keep alive to 90 seconds makes for a very reliable connection, must be set before the 1st connection is made.
  const TickType_t xFrequency = 250; //delay for ms
  for (;;)
    //check for a is-connected and if the WiFi 'thinks' its connected, found checking on both is more realible than just a single check
    if ( (wifiClient.connected()) && (WiFi.status() == WL_CONNECTED) )
      xSemaphoreTake( sema_MQTT_KeepAlive, portMAX_DELAY ); // whiles MQTTlient.loop() is running no other mqtt operations should be in process
      MQTTclient.loop();
    else {
      log_i( "MQTT keep alive found MQTT status % s WiFi status % s", String(wifiClient.connected()), String(WiFi.status()) );
      if ( !(wifiClient.connected()) || !(WiFi.status() == WL_CONNECTED) )
        connectToWiFi();
      connectToMQTT();
void connectToMQTT()
  byte mac[5]; // create client ID from mac address
  WiFi.macAddress(mac); // get mac address
  String clientID = String(mac[0]) + String(mac[4]) ; // use mac address to create clientID
    MQTTclient.connect( clientID.c_str(), mqtt_username, mqtt_password );
    vTaskDelay( 250 );
  MQTTclient.setCallback ( mqttCallback );
  MQTTclient.subscribe   ( topicOK );
  MQTTclient.subscribe   ( topicRemainingMoisture_0 );
  MQTTclient.subscribe   ( topicWindSpeed );
  MQTTclient.subscribe   ( topicWindDirection );
  MQTTclient.subscribe   ( topicDPnWI );
  MQTTclient.subscribe   ( topicOutsideTemperature );
  MQTTclient.subscribe   ( topicOutsideHumidity );
  MQTTclient.subscribe   ( topicOutsidePressure );
  MQTTclient.subscribe   ( topicRainfall );
} //void connectToMQTT()
void connectToWiFi()
  int TryCount = 0;
  while ( WiFi.status() != WL_CONNECTED )
    TryCount++;
    WiFi.disconnect();
    WiFi.begin( SSID, PASSWORD );
    vTaskDelay( 4000 );
    if ( TryCount == 10 )
      ESP.restart();
  WiFi.onEvent( WiFiEvent );
void addraindrop(int x, int y, int scale)
  display.fillCircle(x, y, scale / 2, GxEPD_BLACK);
  display.fillTriangle(x - scale / 2, y, x, y - scale * 1.2, x + scale / 2, y , GxEPD_BLACK);
  x = x + scale * 1.6; y = y + scale / 3;
void addsun(int x, int y, int scale, bool IconSize)
  int linesize = 3;
  if (IconSize == SmallIcon) linesize = 1;
  display.fillRect(x - scale * 2, y, scale * 4, linesize, GxEPD_BLACK);
  display.fillRect(x, y - scale * 2, linesize, scale * 4, GxEPD_BLACK);
  display.drawLine(x - scale * 1.3, y - scale * 1.3, x + scale * 1.3, y + scale * 1.3, GxEPD_BLACK);
  display.drawLine(x - scale * 1.3, y + scale * 1.3, x + scale * 1.3, y - scale * 1.3, GxEPD_BLACK);
  if (IconSize == LargeIcon) {
    display.drawLine(1 + x - scale * 1.3, y - scale * 1.3, 1 + x + scale * 1.3, y + scale * 1.3, GxEPD_BLACK);
    display.drawLine(2 + x - scale * 1.3, y - scale * 1.3, 2 + x + scale * 1.3, y + scale * 1.3, GxEPD_BLACK);
    display.drawLine(3 + x - scale * 1.3, y - scale * 1.3, 3 + x + scale * 1.3, y + scale * 1.3, GxEPD_BLACK);
    display.drawLine(1 + x - scale * 1.3, y + scale * 1.3, 1 + x + scale * 1.3, y - scale * 1.3, GxEPD_BLACK);
    display.drawLine(2 + x - scale * 1.3, y + scale * 1.3, 2 + x + scale * 1.3, y - scale * 1.3, GxEPD_BLACK);
    display.drawLine(3 + x - scale * 1.3, y + scale * 1.3, 3 + x + scale * 1.3, y - scale * 1.3, GxEPD_BLACK);
  display.fillCircle(x, y, scale * 1.3, GxEPD_WHITE);
  display.fillCircle(x, y, scale, GxEPD_BLACK);
  display.fillCircle(x, y, scale - linesize, GxEPD_WHITE);
void loop() { }
On one micro controller.
I think the point has been made, but the answer is that it is perfectly sensible and indeed, using multiple microcontrollers would be a foolish design.
The whole point about using a microcontroller is that it is capable of doing many things - apparently simultaneously since it is so fast - we are talking about millions of processing steps every second.
The only problems are
  1. Are the devices themselves compatible with a microcontroller? Clearly the ones you select must be and almost certainly will.
  2. Does the microcontroller - presumably an Arduino board such as a Nano (try and avoid the UNO) - have enough I/O pins to connect all the devices? There are ways to minimise I/O use such as an I²C "backpack" on a 1602 display which uses only the two I²C pins and using "NeoPixel" LEDs of which many can be controlled by a single I/O pin.
  3. Do you have the programming skills to write the code? Clearly the tricky one. :grin:
