rfid door system doesnt work succesfully
hi.
this is my first topic.
i want to make a "rfid door system".
something i have done.
When I run the system, the system is running at startup.
but after a few minutes, the system is not reading the cards.
The interesting thing is that if I open the serial screen, the system is triggered and started working.
to solve problem,
i changed arduino, lcd, rfid rc5522..
but all time the same problem.
I took the role.but the same problem.
//#include <LiquidCrystal_I2C_AvrI2C.h>
#include <SPI.h>
#include <MFRC522.h>
constexpr uint8_t RST_PIN = 9;
constexpr uint8_t SS_PIN = 10;
LiquidCrystal_I2C lcd(0x27, 16, 2); //Parameters: (rs, enable, d4, d5, d6, d7)
//LiquidCrystal_I2C_AvrI2C lcd(0x27,16,2);  // 16 karakter 2 satır için - 20x4 satır için (0x27,20,4) yazın
MFRC522 mfrc522(SS_PIN, RST_PIN);  // Create MFRC522 instance
int buzzerPin = 8;
int relayPin = 2;
  pinMode(buzzerPin, OUTPUT);
  pinMode(relayPin, OUTPUT);
  digitalWrite(relayPin, LOW);
  lcd.begin();   // LCD screen
  SPI.begin();      // Init SPI bus
  mfrc522.PCD_Init();   // Init MFRC522
  lcd.setCursor(0, 0);
  lcd.print("RFID KAPI Kilidi");
  lcd.setCursor(0, 1);
  lcd.print("  by ATAMAN");
  delay(3000);
  lcd.clear();
  lcd.print(" KARTINI OKUT ");
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent()) {
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial()) {
    return;
  //Reading from the card
  String tag = "";
  for (byte i = 0; i < mfrc522.uid.size; i++)
    tag.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
    tag.concat(String(mfrc522.uid.uidByte[i], HEX));
  tag.toUpperCase();
  //Checking the card
  if (tag.substring(1) == "1A A6 74 63") //change here the UID of the card/cards that you want to give access
    lcd.clear();
    lcd.print("ERISIM IZNI VERILDI");
    lcd.print("  KAPI ACILDI");
    digitalWrite(relayPin, HIGH);
    delay(3000);
    lcd.clear();
    lcd.clear();
    lcd.print("  YETKISIZ KART");
    lcd.print("Erisim Izni Yok");
    digitalWrite(buzzerPin, HIGH);
    delay(3000);
    digitalWrite(buzzerPin, LOW);
    lcd.clear();
thanks.
I would try
SPI.begin(SS_PIN);      // Init SPI bus
opening the serial monitor sends a reset via software. same thing as hitting the reset button
Opening the Serial Monitor application resets the Arduino.
 String tag = "";
There's your culprit. Stop using the String class!
There is NO reason to convert a byte array to a String, so you can compare it with another byte array converted to a String. Just compare the byte arrays.
thanks.
produced error message when I tried.
error:
no matching function for call to 'SPIClass::begin(const uint8_t&)'
PaulS:
 String tag = "";
thanks.
like that ?
if(mfrc522.uid.uidByte[0] == 0x1A)
                if(mfrc522.uid.uidByte[1] == 0xA6)
                  if(mfrc522.uid.uidByte[2] == 0x74)
                    if(mfrc522.uid.uidByte[3] == 0x63)
                        lcd.clear();
                        delay(3000);
                        lcd.clear();
can-inlife:
like that ?
With memcmp() you could do it in one fell swoop.
dougp:
or learn what && is for.
dougp:
thanks.
I dont know enough information about it. but i wil work on.
PaulS:
thanks.
i cut off connection with relay
and also lcd.
so i just try with serial screen. and do not create any problem.
so. i think. the problem is that : using RFID-RC522 and 16*2 LCD MONITOR together !
how can i fix it.
