I downloaded this Arduino code online
enum {INIT_LCD, SCAN_TAG, KEY_IN_PASSWORD} state = INIT_LCD;
int ledToggle = 1;
// define for nfc
#include <SPI.h>
#include <MFRC522.h>
#define NOT_FOUND -1
#define RST_PIN 9
#define SS_PIN 10
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
#define NR_KNOWN_CARDS 2
#define CARD_SIZE 4
// init paralle arrays
byte knownCards[NR_KNOWN_CARDS][CARD_SIZE] = {
{0x93, 0x47, 0xe0, 0x00},
{0xe5, 0xa2, 0x9c, 0x2c}
char name[NR_KNOWN_CARDS][10] = {
"James",
"Richard"
char password[NR_KNOWN_CARDS][5] = {
"1234",
"8888"
int n; // current tag index
// define for keypad
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 3;
//define the cymbols on the buttons of the keypads
char hexaKeys[ROWS][COLS] = {
{'1','2','3'},
{'4','5','6'},
{'7','8','9'},
{'*','0','#'}
byte rowPins[ROWS] = {5, 6, 7, 8};
byte colPins[COLS] = {2, 3, 4};
int count = 0;
char keys[5];
unsigned long time;
Keypad customKeypad = Keypad( makeKeymap(hexaKeys), rowPins, colPins, ROWS, COLS);
// define for lcd
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27, 16, 2); // Set the LCD I2C address
// define for led
int ledPin = A3;
// setup nfc
while (!Serial);
SPI.begin();
mfrc522.PCD_Init();
// setup keypad (assumed serial began)
keys[4] = 0;
// setup lcd
lcd.init();
lcd.backlight();
// setup led
pinMode(ledPin, OUTPUT);
if(ledToggle == -1)
{digitalWrite(ledPin,HIGH);}
{digitalWrite(ledPin,LOW);}
init_lcd();
scan_new_card();
key_in_password();
void scan_new_card() {
if (state != SCAN_TAG) {
return;
if ( ! mfrc522.PICC_IsNewCardPresent()) {
return;
if ( ! mfrc522.PICC_ReadCardSerial()) {
return;
mfrc522.PICC_HaltA();
dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
Serial.print(F(" ("));
Serial.print(mfrc522.uid.size, DEC);
Serial.println(F(")"));
n = indexOf(mfrc522.uid.uidByte, mfrc522.uid.size);
if ( n != NOT_FOUND) {
Serial.println(name[n]);
show_user(name[n]);
time = millis();
Serial.println(time);
state = KEY_IN_PASSWORD;
user_not_found();
state = INIT_LCD;
void dump_byte_array(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
int indexOf(byte *buffer, byte bufferSize) {
if (CARD_SIZE == bufferSize) {
for (byte i = 0; i < NR_KNOWN_CARDS; i++) {
byte j;
for (j = 0; j < CARD_SIZE; j++) {
if (buffer[j] != knownCards[i][j]) break;
if (j == CARD_SIZE) return i;
return NOT_FOUND;
void key_in_password() {
if (state != KEY_IN_PASSWORD) {
return;
char customKey = customKeypad.getKey();
if (customKey){
//Serial.println(customKey);
keys[count] = customKey;
count++;
if (count == 4) {
Serial.println(keys);
if (strcmp(keys, password[n]) == 0) {
toggle_led();
state = INIT_LCD;
count = 0;
if (millis() - time > 10000) { // exceed 10 seconds ?
state = INIT_LCD;
void init_lcd() {
if (state != INIT_LCD) {
return;
lcd.clear();
// for(int i = 0; i< 3; i++)
// lcd.backlight();
// delay(250);
// lcd.noBacklight();
// delay(250);
lcd.backlight();
lcd.setCursor(0,0);
lcd.print("Tag a NFC card");
lcd.setCursor(0,1);
lcd.print(" To Set Master!");
state = SCAN_TAG;
void user_not_found() {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("User not found!");
delay(3000);
void show_user(char name[10]) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Hi ");
lcd.print(name);
lcd.setCursor(0,1);
lcd.print("Key in your PIN");
void toggle_led() {
ledToggle *- -1;
And especially this part here:
I need to insert the rfid value but IDK how to, I tried using the example DumpInfo, but it shows digits and I dont know what 0x27 means
Pls Help ASAP,
Thanks
