RFID LED application
I'm making a simple application through processing + arduino and my parallex USB rfid reader. I basically just want an LED to light up when the correct RFID is read.
This is my processing code which transmits the RFID code through to the arduino:
import processing.serial.*;
Serial rfidPort;
Serial arduinoPort;
int val;
println(Serial.list());
rfidPort = new Serial(this, Serial.list()[0], 2400);
rfidPort.setDTR(true);
arduinoPort = new Serial(this, Serial.list()[1], 2400);
arduinoPort.setDTR(true);
void draw() {
while (rfidPort.available() > 0) {
String inString = rfidPort.readString();
print(inString);
arduinoPort.write(inString);
and this is the code I have running on my arduino:
const int ledPin = 6;
int inByte;
char Str = '25005F3B1F';
  pinMode(ledPin, OUTPUT);
if (Serial.available() > 0)
inByte = Serial.read();
if (inByte == Str) {
    digitalWrite(ledPin, HIGH);
else {
      digitalWrite(ledPin, LOW);
So far it seems as if I'm getting the RFID code over to the arduino fine, however I can't get the LED to light up so I must be doing something wrong.
Any suggestions?
(if it isn't already patently obvious, this is one of my first arduino experiments and my first experience in coding too)
Trying to squeeze that many characters into a single byte isn't a good idea.
char Str[] = "25005F3B1F";
if (inByte == Str)
You can't compare a single byte to a string.
You need to read a string and compare it to a string.
I think you'll find it simpler to get it going by chopping the problem into parts.
  1. read the RFID, and match it in a processing program (and write out a message to say that it is matched) without the Ardiuno.
  2. write a processing program to tell the Arduino to light a LED
  3. figure out a way to pass the RFID from processing to the Arduino, and light an LED.
I assumed you want to match the RFID on the Arduino .
You might want to share with us why, because I don't think it's essential.
GB
