Hi guys,
im having trouble with my loop including rfid and ultrasonic sensor. It's about a parking place you can access both when you put the right tag AND the car is close enough to the ultrasonic sensor.. Once the car leave the parking place (and not in front of the ultrasonic sensor anymore), i would like the gate to close... It's probably super easy but i don't get it... actually the gate stays opened even though the car left..
thanks for your time
#include <SPI.h>
#include <MFRC522.h>
#include <Servo.h>
#include <HCSR04.h>
#define SS_PIN 10
#define RST_PIN 9
#define LED_Verte 5 //define green LED pin
#define LED_Rouge 4 //define red LED
#define BUZZER 2 //buzzer pin,
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
Servo myServo; //define servo name
UltraSonicDistanceSensor capteur_distance(6, 7);
Serial.begin(9600); // Initiate a serial communication
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
myServo.attach(3); //servo pin
myServo.write(0); //servo start position
pinMode(LED_Verte, OUTPUT);
pinMode(LED_Rouge, OUTPUT);
pinMode(BUZZER, OUTPUT);
noTone(BUZZER);
Serial.println("Put your card to the reader...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content = "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " "));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
int distance = capteur_distance.measureDistanceCm();
Serial.print("Message : ");
Serial.print("Distance: ");
Serial.println(distance);
content.toUpperCase();
if (content.substring(1) == "E9 CA 97 98" && distance < 40 ) //change here the UID of the card/cards that you want to give access
Serial.println("Authorized access");
digitalWrite(LED_Verte, HIGH);
tone(BUZZER, 500);
delay(300);
noTone(BUZZER);
myServo.write(90);
return 0;
else {
Serial.println(" Access denied");
digitalWrite(LED_Rouge, HIGH);
digitalWrite(LED_Rouge, LOW);
tone(BUZZER, 300);
delay(300);
noTone(BUZZER);
myServo.write(0);
delay (1000);
delay (2000);
