Hello! I am using a code to sender the RFID informations, but the receiver don't work. I had tested with examples of heltec.h and there were comunication, but just with LoRa.h not.
Sender
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
#define LORA_SCK 5
#define LORA_MISO 19
#define LORA_MOSI 27
#define LORA_SS 18
#define LORA_RST 14
#define LORA_DI0 26
#define LORA_BAND 915E6
#include <SPI.h>
#include <MFRC522.h>
#define RFID_SDA 5
#define RFID_SCK 18
#define RFID_MOSI 23
#define RFID_MISO 19
#define RFID_RST 22
MFRC522 mfrc522(RFID_SDA, RFID_RST); // Create MFRC522 instance
int current_spi = -1; // -1 - NOT STARTED 0 - RFID 1 - LORA
Serial.begin(9600); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
bool card_present = RFID_check();
if (card_present) LORA_send();
void spi_select(int which) {
if (which == current_spi) return;
SPI.end();
switch(which) {
case 0:
SPI.begin(RFID_SCK, RFID_MISO, RFID_MOSI);
mfrc522.PCD_Init();
case 1:
SPI.begin(LORA_SCK,LORA_MISO,LORA_MOSI,LORA_SS);
LoRa.setPins(LORA_SS,LORA_RST,LORA_DI0);
current_spi = which;
int RFID_check() {
spi_select(0);
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent()) {
delay(100);
return false;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial()) {
return false;
// Dump debug info about the card; PICC_HaltA() is automatically called
mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
return true;
void LORA_send() {
spi_select(1);
Serial.println("LoRa Sender Test");
if (!LoRa.begin(915E6)) {
Serial.println("Starting LoRa failed!");
while (1);
Serial.println("init ok");
delay(1500);
// send packet
LoRa.beginPacket();
LoRa.print("hello ");
LoRa.endPacket();
Serial.println("sent one");
delay(2000); // wait for a second
Receiver
#include <SPI.h>
#include <LoRa.h>
#define LORA_SCK 5
#define LORA_SS 18
#define LORA_RST 14
#define LORA_DI0 26
while (1);
delay(1500);
int packetSize = LoRa.parsePacket();
if (packetSize) {
// received a packet
Serial.print("Received packet '");
// read packet
while (LoRa.available()) {
Serial.print((char)LoRa.read());
// print RSSI of packet
Serial.print("' with RSSI ");
Serial.println(LoRa.packetRssi());
