RFID MFRC522 + LCD 1602a + Servo
I am having difficulties with this code I have edited, the portions that operate the servo and the RFID tag reader (MFRC522), but the screen is not printing the messages onto the the LCD display.
When I run the arduino example “Hello World”, the LCD displays the text perfectly fine, this leads me to believe the wiring is correct as I have duplicated the output/input pins used for Hello World and put it into the program I am using.
When the program is ran, it occasionally displays the characters “ff”
Here is the code I am using;
   Typical pin layout used:
               MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
               Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
   Signal      Pin          Pin           Pin       Pin        Pin              Pin
   RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
   SPI SS      SDA(SS)      10            53        D10        10               10
   SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
   SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
   SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
#include <SPI.h>
#include <MFRC522.h>
#include <LiquidCrystal.h>
#include <Servo.h>
#define RST_PIN         9        // Configurable, see typical pin layout above
#define SS_PIN          10          // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
Servo myservo;  // create servo object to control a servo
String read_rfid;
String ok_rfid_1 = "6722323b";
String ok_rfid_2 = "99be859e";
int posClosed = 180;    // variable to store the servo position for locked
int posOpen = 0;    //same for open...
   Initialize.
  Serial.begin(9600);         // Initialize serial communications with the PC
  while (!Serial);            // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  SPI.begin();                // Init SPI bus
  mfrc522.PCD_Init();         // Init MFRC522 card
  lcd.begin(16, 2);
  lcd.clear();
  lcd.print("Scan your card:");
  Serial.println("Scan your card:");
   //Choose which lock below:
  myservo.attach(7);  // attaches the servo on pin 7 to the servo object
   Helper routine to dump a byte array as hex values to Serial.
void dump_byte_array(byte *buffer, byte bufferSize) {
  read_rfid = "";
  for (byte i = 0; i < bufferSize; i++) {
    read_rfid = read_rfid + String(buffer[i], HEX);
void open_lock() {
  //Use this routine when working with Servos.
  //lcd.clear();
  lcd.print("Servo Unlocking");
  myservo.write(posOpen);
  Serial.println("Servo Unlocking");
  delay(10000);
  myservo.write(posClosed);
  lcd.clear();
  lcd.print("Servo Locking");
  Serial.println("Servo Locking");
  lcd.clear();
  lcd.print("test");
  // Look for new cards
  if ( ! mfrc522.PICC_IsNewCardPresent())
    return;
  // Select one of the cards
  if ( ! mfrc522.PICC_ReadCardSerial())
    return;
  dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
  if (read_rfid == ok_rfid_1) {
    open_lock();
    lcd.clear();
    lcd.print(read_rfid + " (FRED FARMER)" + " -Access Granted");
    Serial.println(read_rfid + " (FRED FARMER)" + " -Access Granted");
    delay(10000);
    lcd.clear();
    lcd.print("Scan a card:");
    Serial.println("Scan a card:");
  if (read_rfid == ok_rfid_2) {
    open_lock();
    lcd.clear();
    lcd.print(read_rfid + " (JOHN DOE) " + " -Access Granted");
    Serial.println(read_rfid + " (JOHN DOE) " + " -Access Granted");
    delay(10000);
    lcd.clear();
  else {
    lcd.clear();
    lcd.print(read_rfid + " -Access Denied");
    Serial.println(read_rfid + " -Access Denied");
    delay(10000);
    lcd.clear();
The RFID reader is an SPI device. On the UNO, and other 328-based Arduinos, that means that is uses pins 11, 12, and 13. You can't use them for the LCD, too.
