Rfid not accepting valid input help
Hello, I am doing a project that involves using the arduino uno and the ethernet shield 2 with the sunfounder rfid-rc522 reader for my project. This involves me scanning the card and it uploads to a google spreadsheet. I think it works but it simply does not scan my card as valid even though I typed it in. I basically got this project from this link
https://create.arduino.cc/projecthub/embedotronics-technologies/attendance-system-based-on-arduino-and-google-spreadsheet-105621?ref=search&ref_id=rfid&offset=54
I would ask the creator but he won't respond to me. The code is attached of his that I modified to meet my standards.
I also attached the screenshot of what happens when I scan the tags.
If you help me on this I appreciate you. :slight_smile:
Testbeta2.ino (3.3 KB)
Read How to use this forum, and post your sketch on the forum using code tags.
You will never recognize a tag or card- because that's the way the code is written.
Consider the logic of your nested if statements.
if card 1 matches, AND card 2 matches, AND card 3 matches, AND card 4 matches, then you have a match.
Try changing the second through the third if to elseif, then the logic reads card 1 OR card 2 OR card 3 OR card 4.
void loop(){
    int m=0;
    if(!rfid.PICC_IsNewCardPresent())
    return;
    if(!rfid.PICC_ReadCardSerial())
    return;
    for(i=0;i<4;i++)
     id_temp[0][i]=rfid.uid.uidByte[i];
               delay(50);
     for(i=0;i<No_Of_Card;i++)
            if(id[i][0]==id_temp[0][0])
              if(id[i][1]==id_temp[0][1])
                if(id[i][2]==id_temp[0][2])
                  if(id[i][3]==id_temp[0][3])
                    Serial.print("your card no :");
                    for(int s=0;s<4;s++)
                      Serial.print(rfid.uid.uidByte[s]);
                      Serial.print(" ");
I don't really know how to setup elseif (I am a student), but I don't know why there are ids 0-3 when it only has three card data slots, and Im only using 2 valid ones, the 3rd one was already there from the guys project.
This is the card code
byte id[No_Of_Card][4]={
  {204,389,56,51},             //RFID NO-1
  {3010,9,31,52},             //RFID NO-2
  {142,76,58,42}              //RFID NO-3
byte id_temp[3][3];
byte i;
int j=0;
I appreciate your help with me, as I don't know much about this code.
RTFM
I won't write the code for you, but I will answer specific questions. I already showed you where your problem is and how to fix it.
            if(id[i][0]==id_temp[0][0]) {
                      Serial.print(" ");
                    Serial.println("\nValid Person");
                    Sending_To_spreadsheet();
                    j=0;
                              rfid.PICC_HaltA(); rfid.PCD_StopCrypto1();   return;
              else if(id[i][1]==id_temp[0][1]) {
                      Serial.print(" ");
                    j=0;
                else if(id[i][2]==id_temp[0][2]) {
                      Serial.print(" ");
                    j=0;
                  else if(id[i][3]==id_temp[0][3])
                      Serial.print(" ");
                    j=0;
     {j++;
      if(j==No_Of_Card)
        Serial.println("Not a valid Person");
        j=0;
I changed them to elseif statements and it still is saying that it is not a valid person so I dont know what Im doing wrong
