My project is using the uno and the ethernet shield with the rfid-rc522 reader and I have been trying to get my project to scan my rfid card but it keeps saying this: (image attached). I dont know how to fix it I have already tried making some of the code elseif statements and that still didn't work. I already know the numbers are correct because I scanned my card with different code and got the hex form and converted it to fit the code of this project that this fella made. Maybe a fresh set of eyes could tell me what I am doing wrong--- code below
/* Arduino Code which sends data to google spreadsheet */
#include<SPI.h>
#include<MFRC522.h>
#include <Ethernet.h>
#define SS_PIN 4 //FOR RFID SS PIN BECASUSE WE ARE USING BOTH ETHERNET SHIELD AND RS-522
#define RST_PIN 9
#define No_Of_Card 3
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
char server[] = "api.pushingbox.com"; //YOUR SERVER
IPAddress ip(24, 124, 10, 6);
EthernetClient client;
MFRC522 rfid(SS_PIN,RST_PIN);
MFRC522::MIFARE_Key key;
byte id[No_Of_Card][4]={
{204,389,56,51}, //RFID NO-1
{3010,9,31,52}, //RFID NO-2
{142,76,58,42} //RFID NO-3
byte id_temp[3][3];
byte i;
int j=0;
// the setup function runs once when you press reset or power the board
void setup(){
SPI.begin();
rfid.PCD_Init();
for(byte i=0;i<6;i++)
key.keyByte[i]=0xFF;
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
Ethernet.begin(mac, ip);
Serial.println("connecting...");
// the loop function runs over and over again forever
void loop(){
int m=0;
if(!rfid.PICC_IsNewCardPresent())
return;
if(!rfid.PICC_ReadCardSerial())
return;
for(i=0;i<4;i++)
id_temp[0][i]=rfid.uid.uidByte[i];
delay(50);
for(i=0;i<No_Of_Card;i++)
if(id[i][0]==id_temp[0][0]) {
Serial.print("your card no :");
for(int s=0;s<4;s++)
Serial.print(rfid.uid.uidByte[s]);
Serial.print(" ");
Serial.println("\nValid Person");
Sending_To_spreadsheet();
j=0;
rfid.PICC_HaltA(); rfid.PCD_StopCrypto1(); return;
else if(id[i][1]==id_temp[0][1]) {
Serial.print(" ");
j=0;
else if(id[i][2]==id_temp[0][2]) {
Serial.print(" ");
j=0;
else if(id[i][3]==id_temp[0][3])
Serial.print(" ");
j=0;
{j++;
if(j==No_Of_Card)
Serial.println("Not a valid Person");
j=0;
// Halt PICC
rfid.PICC_HaltA();
// Stop encryption on PCD
void Sending_To_spreadsheet() //CONNECTING WITH MYSQL
if (client.connect(server, 80)) {
Serial.println("connected");
// Make a HTTP request:
client.print("GET /pushingbox?devid=v4C30CA17D5F64E2&allowed_members="); //YOUR URL
if(j!=No_Of_Card)
client.print('1');
// Serial.print('1');
client.print('0');
client.print("&Member_ID=");
client.print(rfid.uid.uidByte[s]);
client.print(" "); //SPACE BEFORE HTTP/1.1
client.print("HTTP/1.1");
client.println();
client.println("Host: api.pushingbox.com");
client.println("Connection: close");
client.println();
// if you didn't get a connection to the server:
Serial.println("connection failed");
