Hello ,
Quick question. I have an Arduino uno with ethernet shield 2 + I have a PIR SENSOR attached on pin 2 ( wich is an interrupt pin).
I found a bug in the program but i'm not sure how to solve this. When the program first sees motion detection when I open the serial monitor it doesn't listen anymore to any RFID cards anymore.
But when I wait and first put an RFID tag to the reader and then trigger my motion sensor only then it can combine both signals together.
All the resources for this project: https://www.hackster.io/Aritro
Modified by Aritro Mukherjee
#include <Ethernet2.h> //Load Ethernet Library
#include <EthernetUdp2.h> //Load UDP Library
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 4
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xEE};
IPAddress ip(192, 168, 0, 220); //Assign my IP adress , not necessary
unsigned int localPort = 5006; //Assign a Port to talk over
EthernetUDP Udp; //Define UDP Object
int inputPin = 2;
int pirState = LOW;
int val = 0;
Ethernet.begin(mac, ip); // Begins Ethernet
Udp.begin(localPort); // Makes UDP connection possible on the assigned port
Serial.begin(9600); // Initiate a serial communication
pinMode(inputPin, INPUT); // Tell the arduino to make pin 2 an INPUT
attachInterrupt(digitalPinToInterrupt(inputPin), detection, CHANGE); // When there is a change on pin 2 the detection code
SPI.begin(); // Initiate SPI bus
mfrc522.PCD_Init(); // Initiate MFRC522
Serial.println("Approximate your card to the reader...");
// Look for new cards
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
//Show UID on serial monitor
Serial.print("UID tag :");
String content = "";
byte letter;
for (byte i = 0; i < mfrc522.uid.size; i++)
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
content.concat(String(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : ""));
content.concat(String(mfrc522.uid.uidByte[i], HEX));
Serial.print("Message : ");
content.toUpperCase();
Serial.println("Sending to Python");
Udp.beginPacket("192.168.0.219", 5005); // Begin packet with the client
Udp.print(content); // Send the string
Udp.endPacket(); // Terminate packet
delay(3000);
void detection() { // the function "detection"
val = digitalRead(inputPin); // reads the digital state on pin 2 ( HIGH OR LOW )
if (val == HIGH) { // if this value is HIGH
if (pirState == LOW) { // And the variable is LOW
Serial.println("Motion detected!"); // Then there is motion , write this to the serial monitor
Udp.write("trigger"); // Send the string
pirState = HIGH; // Make variable HIGH
else {
if (pirState == HIGH) { // if the variable is HIGH
Serial.println("Motion ended!"); // Then there is no detection
pirState = LOW; // Make variable LOW
