RFID prize box
Hello world…fast learning noob here.
I’ve been working on a project based on this one:
I’m looking to find the slotID of the picc and use it to determine which relay to trigger. I’ve started adding the “findIDSLOT” into row 264(bottom of the loop function).
So basically…
The next slot after the master would trigger relayOne
next one - relayTwo
nextone - relayThree
all others(there should only be three) – lastWinner, relayFour
I’ve also added several functions at the bottom to correspond to the appropriate relays. I’m using the Seeed Studios relay shield. I have also commented out all of the led lines temporarily for future pin configurations.
Thanx in advance.
#include <EEPROM.h>  // We are going to read and write PICC's UIDs from/to EEPROM
#include <SPI.h>      // RC522 Module uses SPI protocol
#include <MFRC522.h>   // Library for Mifare RC522 Devices
#define wipeB 3 // Button pin for WipeMode
#define relayOne 4
#define relayTwo 5
#define relayThree 6
#define relayFour 7
//#define someThing 8
boolean match = false; // initialize card match to false
boolean programMode = false; // initialize programming mode to false
int successRead; // Variable integer to keep if we have Successful Read from Reader
byte storedCard[4];   // Stores an ID read from EEPROM
byte readCard[4];           // Stores scanned ID read from RFID Module
byte masterCard[4]; // Stores master card's ID read from EEPROM
#define SS_PIN 10
#define RST_PIN 9
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance.
  pinMode(relayOne, OUTPUT);
  pinMode(relayTwo, OUTPUT);
  pinMode(relayThree, OUTPUT);
  digitalWrite(relayOne, HIGH); // Make sure door is locked
  digitalWrite(relayTwo, HIGH); // Make sure door is locked
  digitalWrite(relayThree, HIGH); // Make sure door is locked
  //Protocol Configuration
  Serial.begin(9600); // Initialize serial communications with PC
  SPI.begin();           // MFRC522 Hardware uses SPI protocol
  mfrc522.PCD_Init();    // Initialize MFRC522 Hardware
  mfrc522.PCD_SetAntennaGain(mfrc522.RxGain_max); //Set Antenna Gain to Max- this will increase reading distance
  //Wipe Code if Button Pressed while setup run (powered on) it wipes EEPROM
  pinMode(wipeB, INPUT_PULLUP);  // Enable pin's pull up resistor
void loop () {
  do {
    successRead = getID(); // sets successRead to 1 when we get read from reader otherwise 0
    if (programMode) {
    else {
      normalModeOn(); // Normal mode, blue Power LED is on, all others are off
  while (!successRead); //the program will not go further while you not get a successful read
  if (programMode) {
    if ( isMaster(readCard) ) {  //If master card scanned again exit program mode
      Serial.println("This is Master Card");
      Serial.println("Exiting Program Mode");
      Serial.println("-----------------------------");
      return;
    else {
      if ( findID(readCard) ) { //If scanned card is known delete it
        Serial.println("I know this PICC, so removing");
        deleteID(readCard);
      else {                    // If scanned card is not known add it
        Serial.println("I do not know this PICC, adding...");
        writeID(readCard);
  else {
    if ( isMaster(readCard) ) {  // If scanned card's ID matches Master Card's ID enter program mode
      programMode = true;
      Serial.println("Hello Master - Entered Program Mode");
      int count = EEPROM.read(0); // Read the first Byte of EEPROM that
      Serial.print("I have ");    // stores the number of ID's in EEPROM
      Serial.print(count);
      Serial.print(" record(s) on EEPROM");
      Serial.println("");
      Serial.println("Scan a PICC to ADD or REMOVE");
    else {
    int place;
    place = findIDSLOT( a );
    if (place = 1)
         firstPlace(300);
       else {
       if (place = 2)
       secondPlace(300);
        else{
         if (place = 3)
         thirdPlace(300)
        else{}
      else { // If not, show that the ID was not valid
        Serial.println("You're no daisy");
        lastWinner();
int findIDSLOT( byte find[] ) {
  for ( int i = 1; i <= count; i++ ) { // Loop once for each EEPROM entry
    readID(i); // Read an ID from EEPROM, it is stored in storedCard[4]
    if( checkTwo( find, storedCard ) ) { // Check to see if the storedCard read from EEPROM
      // is the same as the find[] ID card passed
      return i; // The slot number of the card
      break; // Stop looking we found it
boolean findID( byte find[] ) {
      return true;
    else {  // If not, return false
  return false;
So, what IS the problem? What does the code do that you don't want? What does it not do that you do want?
Sorry, if this wasn't clear enough. I had typed it all up, and when I clicked "preview post", it previewed me a blank page and lost everything I had typed. The second time around seems to have lost some detail, as it was 4:30 AM.....LOL Also, when I tried to include the entire sketch, my post was too long and I had to edit lots out in order for it to fit.
The original sketch scanned a tag to be the programming tag, then it scans and adds other piccs to to Eeprom. That resulted in a programming picc(works great), several programmed in as authorized(I want to split these up), and the rest of the piccs fail.
Elsewhere in the sketch I notice that it was retrieving the "slotID" in order to remove the picc from the "authorized" list, which is stored on eeprom. I'm trying to use the slotID in order to decide which relay/door is triggered, instead of having them all just trigger one door.
The original loop function:
void loop () {
  do {
    if (programMode) {
//lbh      cycleLeds(); // Program Mode cycles through RGB waiting to read a new card
    else {
  if (programMode) {
      return;
    else {
        deleteID(readCard);
        writeID(readCard);
  else {
      programMode = true;
      Serial.println("");
    else {
      if ( findID(readCard) ) {        // If not, see if the card is in the EEPROM
        Serial.println("Winner, Winner, Chicken dinner");
        openDoor(300);                // Open the door lock for 300 ms
        failed();
    int place;
There is no reason to create an uninitialized local variable in one statement and then assign a value to it in the next statement.
    int place = findIDSLOT( a );
    if (place = 1)
Having assigned place a value by calling the findIDSLOT() function, it hardly makes sense to assign it another value in an if statement. = != ==.
Thanks PaulS,
That is the question, how do I code this? That's where I'm stuck at.
Every line you picked are my temporary place holders right this second....and that's where my question lies.
I am in the process of stripping comment lines from the code, so I can post it all. Looks like I'm going to have to do it in two post though.
Setup& loop function, abbreviated to fit(second half to follow) :cold_sweat:
#define relayOne 4
#define relayTwo 5
#define relayFour 7
#define SS_PIN 10
#define RST_PIN 9
  pinMode(relayFour, OUTPUT);
  digitalWrite(relayFour, HIGH); // Make sure door is locked
  if (digitalRead(wipeB) == LOW) {     // when button pressed pin should get low, button connected to ground
    Serial.println("!!! Wipe Button Pressed !!!");
    Serial.println("You have 5 seconds to Cancel");
    Serial.println("This will be remove all records and cannot be undone");
    delay(5000);    // Give user enough time to cancel operation
    if (digitalRead(wipeB) == LOW) {  // If button still be pressed, wipe EEPROM
      Serial.println("!!! Starting Wiping EEPROM !!!");
      for (int x=0; x<1024; x=x+1){ //Loop end of EEPROM address
        if (EEPROM.read(x) == 0){ //If EEPROM address 0
        else{
          EEPROM.write(x, 0); // if not write 0, it takes 3.3mS
      Serial.println("!!! Wiped !!!");
    else {
      Serial.println("!!! Wiping Cancelled !!!");
  if (EEPROM.read(1) != 1) {  // Look EEPROM if Master Card defined, EEPROM address 1 holds if defined
    Serial.println("No Master Card Defined");
    Serial.println("Scan A PICC to Define as Master Card");
    do {
    for ( int j = 0; j < 4; j++ ) { // Loop 4 times
      EEPROM.write( 2 +j, readCard[j] ); // Write scanned PICC's UID to EEPROM, start from address 3
    EEPROM.write(1,1); //Write to EEPROM we defined Master Card.
    Serial.println("Master Card Defined");
  Serial.println("##### RFID Door Acces Control v2.0.8 #####"); //For debug purposes
  Serial.println("Master Card's UID");
  for ( int i = 0; i < 4; i++ ) {     // Read Master Card's UID from EEPROM
    masterCard[i] = EEPROM.read(2+i); // Write it to masterCard
    Serial.print(masterCard[i], HEX);
  Serial.println("");
  Serial.println("Waiting PICCs to be scanned :)");
void loop () {
  do {
    if (programMode) {
    else {
  if (programMode) {
      return;
    else {
        deleteID(readCard);
        writeID(readCard);
  else {
      programMode = true;
      Serial.println("");
    else {
//lbh        This is where I'm having the issue, I added the next several lines, but it's not complete.
//lbh        How can I find the IDSLOT and use it to decide which door/relay to activate?
    int place;
    if (place = 1)
         firstPlace(300);        // Open the door lock for 300 ms
       else {
       if (place = 2)
       secondPlace(300);
        else{
         if (place = 3)
         thirdPlace(300)
        else{}
//lbh     The original code starts back
        lastWinner();
The rest…
int getID() {
  if ( ! mfrc522.PICC_IsNewCardPresent()) { //If a new PICC placed to RFID reader continue
    return 0;
  if ( ! mfrc522.PICC_ReadCardSerial()) { //Since a PICC placed get Serial and continue
    return 0;
  Serial.println("Scanned PICC's UID:");
  for (int i = 0; i < 4; i++) {  //
    readCard[i] = mfrc522.uid.uidByte[i];
    Serial.print(readCard[i], HEX);
  Serial.println("");
  mfrc522.PICC_HaltA(); // Stop reading
  return 1;
void normalModeOn () {
  digitalWrite(relayOne, HIGH); // Make sure Door is Locked
  digitalWrite(relayTwo, HIGH); // Make sure Door is Locked
  digitalWrite(relayThree, HIGH); // Make sure Door is Locked
  digitalWrite(relayFour, HIGH); // Make sure Door is Locked
void readID( int number ) {
  int start = (number * 4 ) + 2; // Figure out starting position
  for ( int i = 0; i < 4; i++ ) { // Loop 4 times to get the 4 Bytes
    storedCard[i] = EEPROM.read(start+i); // Assign values read from EEPROM to array
void writeID( byte a[] ) {
  if ( !findID( a ) ) { // Before we write to the EEPROM, check to see if we have seen this card before!
    int num = EEPROM.read(0); // Get the numer of used spaces, position 0 stores the number of ID cards
    int start = ( num * 4 ) + 6; // Figure out where the next slot starts
    num++; // Increment the counter by one
    EEPROM.write( 0, num ); // Write the new count to the counter
      EEPROM.write( start+j, a[j] ); // Write the array values to EEPROM in the right position
    successWrite();
  else {
    failedWrite();
void deleteID( byte a[] ) {
  if ( !findID( a ) ) { // Before we delete from the EEPROM, check to see if we have this card!
    failedWrite(); // If not
  else {
    int slot; // Figure out the slot number of the card
    int start;// = ( num * 4 ) + 6; // Figure out where the next slot starts
    int looping; // The number of times the loop repeats
    int j;
    int count = EEPROM.read(0); // Read the first Byte of EEPROM that stores number of cards
    slot = findIDSLOT( a ); //Figure out the slot number of the card to delete
    start = (slot * 4) + 2;
    looping = ((num - slot) * 4);
    num--; // Decrement the counter by one
    for ( j = 0; j < looping; j++ ) { // Loop the card shift times
      EEPROM.write( start+j, EEPROM.read(start+4+j)); // Shift the array values to 4 places earlier in the EEPROM
    for ( int k = 0; k < 4; k++ ) { //Shifting loop
      EEPROM.write( start+j+k, 0);
    successDelete();
boolean checkTwo ( byte a[], byte b[] ) {
  if ( a[0] != NULL ) // Make sure there is something in the array first
    match = true; // Assume they match at first
  for ( int k = 0; k < 4; k++ ) { // Loop 4 times
    if ( a[k] != b[k] ) // IF a != b then set match = false, one fails, all fail
      match = false;
  if ( match ) { // Check to see if if match is still true
    return true; // Return true
  else  {
    return false; // Return false
      return true;
  return false;
void successWrite() {
  Serial.println("Succesfully added ID record to EEPROM");
void failedWrite() {
  Serial.println("Failed! There is something wrong with ID or bad EEPROM");
void successDelete() {
  Serial.println("Succesfully removed ID record from EEPROM");
boolean isMaster( byte test[] ) {
  if ( checkTwo( test, masterCard ) )
    return true;
    return false;
void firstPlace( int setDelay ) {
  digitalWrite(relayOne, LOW); // Unlock door!
  delay(setDelay); // Hold door lock open for given seconds
  digitalWrite(relayOne, HIGH); // Relock door
  delay(2000); // Hold green LED on for 2 more seconds
void secondPlace( int setDelay ) {
  digitalWrite(relayTwo, LOW); // Unlock door!
  digitalWrite(relayTwo, HIGH); // Relock door
void thirdPlace( int setDelay ) {
  digitalWrite(relayThree, LOW); // Unlock door!
  digitalWrite(relayThree, HIGH); // Relock door
void lastWinner( int setDelay ) {
  digitalWrite(relayFour, LOW); // Unlock door!
  digitalWrite(relayFour, HIGH); // Relock door
void failed() {
  delay(1200);
