RFID Question
Hello everyone quick ? I'm as bout green as you can get with this stuff so, I bought the starter kit Arduino Uno and a Radio Shack RFID with two key fobs, I'm using a script from someone elses setup. I can get one key working but not the other they both come up in the monitor, so am I missing something here? Any help many thanks..
#define CODE_COUNT 2
#define MIN_ROTATION 150
#define MAX_ROTATION 30
int  val = 0;
char code[10];
int bytesread = 0;
int ledPin =  13;
int speakerOut = 5;
int firstworked = 0;
char *goodCode1 = "1700BD4917";
char *goodCode2 = "1700BD4876";
int  Cnote = 1915;
int  Dnote = 1000;
#include <Servo.h>
Servo servo;
void soundwave(int note, int howHard ) {                        // function that takes 2 parameters, the note we want to play and how hard the sensor has been hit
  unsigned long endSoundWave = micros() + (35000 * howHard);    // start a count from the microseconds currently registered since the program first ran. And add on an arbitary value multiplied by howHard value
    while(micros() < endSoundWave){                               // while the count is not reached
    analogWrite(speakerOut, 1023);                              // set the speaker to on/ high
    delayMicroseconds(note);                                    // wait the number of microseconds for the note
    analogWrite(speakerOut, 0);                                 // set the speaker to off/ low
    delayMicroseconds(note);                                    // wait for the same number again to complete our oscillation/ soundwave.
  }                                                             // repeat for the length of time.
  Serial.begin(2400); // RFID reader SOUT pin connected to Serial RX pin at 2400bps
  pinMode(2,OUTPUT);   // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
  digitalWrite(2, LOW);                  // Activate the RFID reader
  pinMode(ledPin, OUTPUT);
  servo.attach(3);
  pinMode(speakerOut,OUTPUT);
  if(Serial.available() > 0) {          // if data available from reader
    if((val = Serial.read()) == 10) {   // check for header
      bytesread = 0;
      while(bytesread<10) {              // read 10 digit code
        if( Serial.available() > 0) {
          val = Serial.read();
          if((val == 10)||(val == 13)) { // if header or stop bytes before the 10 digit reading
            break;                       // stop reading
          code[bytesread] = val;         // add the digit
          bytesread++;                   // ready to read next digit
      if(bytesread == 10) {              // if 10 digit read is complete
        Serial.print("TAG code is: ");   // possibly a good TAG
       Serial.println(code);            // print the TAG code
        boolean success = true;
        firstworked = 1;
        for(int i=0;i<10;i++) {
          if(goodCode1[i] != code[i]) {
            success = false;
            Serial.print("BAD TAG SUKKA");
            firstworked = 0;
        if(success){
          digitalWrite(ledPin, HIGH);
          soundwave(500, 5);
          servo.write(MAX_ROTATION);
        else {
          soundwave(2000, 20);
      bytesread = 0;
  digitalWrite(ledPin, LOW);
  servo.write(MIN_ROTATION);
if true (
This isn't syntactically valid...
char *goodCode2 = "1700BD4876"; // Can't get this one to work
Where do you try? goodCode2 is never used anywhere else.
Sorry I forgot to remove this line. if true (
this should be in the code... I just don't no what to do with the
again thank you for your help on this.
This is the code you have for checking the first tag.
           success = false;
           firstworked = 0;
Copy this, and change goodCode1 to goodCode2. You might want to have a secondworked variable, if it matters WHICH valid tag was read.
No luck still can't get it to work, I copy this and now the first key doesn't work, and the second one does... Thanks again
Show your new code...
Show your new code
But please please use the # button when you post it.
Sorry about that I see the button now... But still don't know if this is what you wanted.[/code]
int  val = 0;
char code[10];
int bytesread = 0;
int ledPin =  13;
int speakerOut = 5;
int  Cnote = 1915;
int  Dnote = 1000;
#include <Servo.h>
Servo servo;
  servo.attach(3);
      bytesread = 0;
        firstworked = 1;
            success = false;
            firstworked = 0;
         if(goodCode2[i] != code[i]) {
           success = false;
           firstworked = 0;
        if(success){
          soundwave(500, 5);
        else {
      bytesread = 0;
What you are doing here:-
char goodCode1 = "1700BD4917";
is generating a pointer to the start of a string.
Then you use that as if it were an array:-
if(goodCode1 _!= code
)*_
If I was writing this I would declare it as an array to begin with then I think you would find the test would work correctly.
@Grumpy_Mike
That method of allocation and pointer assignment, and then using array notation works just fine. There is nothing wrong with it. There would be if the code was incrementing the pointer.
What happens when you scan the first tag? Does it print BAD TAG SUKKA? If that is the "problem", the solution is to change the message(s). Print "This is not tag 1" and "This is not tag 2" where you currently print "BAD TAG SUKKA". I think that you will see that it is telling you that the tag 1 is not tag 2.
This is what I get from the serial monitor I did what you said and change the names, neither card will work now. Thanks again for the help..
TAG code is: 1700BD4917
this is not tag 2TAG code is: 1700BD4917
this is not tag 2TAG code is: 1700BD4876
this is not tag 1TAG code is: 1700BD4876
this is not tag 1
I scan both cards
So, when you scan tag 1, it tells you that it is not tag 2, and when you scan tag 2, it tells you that it is not tag 1. What is the problem?
It seems to me that you want to print a message only when the tag is valid.
Or, set a boolean variable to false. Set it to true if either loop completes (the tag is valid). After both loops, if it is still false, the tag is not valid. If it is true, the tag is valid.
Thank you Paul for your wisdom.....It's up and running.
Not sure if anyone would like it but here is the working code just add
your own key fob numbers.. Thanks again everyone for the help.
int  val = 0;
char code[10];
int bytesread = 0;
int ledPin =  13;
int speakerOut = 5;
char *goodCode1 = ""; // Enter your key fob numbers here
char *goodCode2 = ""; // Enter your key fob numbers here
int  Cnote = 1915;
int  Dnote = 1000;
#include <Servo.h>
Servo servo;
  servo.attach(3);
      bytesread = 0;
        firstworked = 1;
            success = true;
            Serial.print("this is not tag 1");
            firstworked = 0;
           success = true;
           Serial.print("this is not tag 2");
           firstworked = 0;
        if(success){
          soundwave(500, 5);
        else {
      bytesread = 0;
