Hello Community,
I am reaching out seeking assistance with a challenge I am encountering while attempting to write data onto an RFID tag using NodeMCU8266. Despite multiple attempts, I consistently encounter an "Authentication failed!" error message.
Below, I've provided the code I'm currently using:
#include <ESP8266WiFi.h>
#include <SPI.h>
#include <MFRC522.h>
#define WIFI_SSID "DIGITALUX"
#define WIFI_PASSWORD "OfficeNet22"
#define RST_PIN D3
#define SS_PIN D8
MFRC522 mfrc522(SS_PIN, RST_PIN);
Write Function!
void writeData(byte* buffer, byte block, const char* prompt) {
Serial.println(prompt);
byte len = Serial.readBytesUntil('#', (char *)buffer, 16);
for (byte i = len; i < 16; i++) buffer[i] = ' ';
MFRC522::MIFARE_Key key;
for (byte i = 0; i < 6; i++) key.keyByte[i] = 0xFF;
if (mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, block, &key, &(mfrc522.uid)) == MFRC522::STATUS_OK) {
if (mfrc522.MIFARE_Write(block, buffer, 16) == MFRC522::STATUS_OK) {
Serial.println("Data written successfully");
Serial.println("Failed to write data");
Serial.println("Authentication failed");
setup Function!
SPI.begin();
mfrc522.PCD_Init();
WiFi.begin(WIFI_SSID, WIFI_PASSWORD);
Serial.println("Connecting");
while (!WiFi.isConnected()) {
Serial.print(".");
delay(50);
Serial.print("Connected with IP : ");
Loop Function!
if (!mfrc522.PICC_IsNewCardPresent()) {
return;
if (!mfrc522.PICC_ReadCardSerial()) {
return;
Serial.print(F("Card UID:"));
for (byte i = 0; i < mfrc522.uid.size; i++) {
Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
Serial.print(mfrc522.uid.uidByte[i], HEX);
byte buffer[18];
byte block;
MFRC522::StatusCode status;
Serial.setTimeout(20000L);
// Write user data to RFID card
writeData(buffer, 1, "Enter Your Name: ");
mfrc522.PICC_HaltA();
mfrc522.PCD_StopCrypto1();
Here is the output I got every time.
I've tried different cards, but every time I get the same error. I'm not sure if there is a problem in my code because I've carefully checked all my hardware connections multiple times.
Thank you very much in advance for your time and assistance.
Best regards,
Ali
